6 Replies Latest reply on Apr 2, 2011 4:00 PM by CacheTrade
    Flash catalyst didn't meet my expectations
    GeneralMarketingService
      I am no Flash expert nor a Catalyst pro by any means, so this is just my take on an average guy who tried and was less than happy with my results.
      I was really hopeful of having a hybrid program that would bridge the gap between the complexities of Flash and my alternatives which have been SwishMax and a few other fill ins.
      I found the import PSD function to work well and my start up went fairly well.
      I managed my pages just fine and got the structure of my roughly 10 page interactive going ok.
      Where i ran into headaches was the transition from page to page.
      As i worked within the timeline and transitions windows, I found a lot of inconsistancies.
      In several cases items that were on the page did not show in the transitions window
      and i had  multiple problems getting items to enter and exit the way i had envisioned.
      i would have also wished for more various transition options.
      Conceptually i love the idea, but functionally my expectations were not met.
      Granted, my trial was on version 1.0..  maybe things are better now.
      But I still love the folks at Adobe and all the products they continue to produce.
        • 1. Re: Flash catalyst didn't meet my expectations
          topelovely Level 4
          I'll advise you look at some Lynda.com training videos. They could help solve so many challenges you a facing.
          • 2. Re: Flash catalyst didn't meet my expectations
            sangdn
            Currentlly I just see Catalyst supports "Fade" "Sound" "Move" "Rotate" "Rotate3D" effect.
            You could make your custome effect in your code insteead.
            Catalyst is just make a simple transition from page to page with a smooth Transition feature.
            I am facing many problem with it but I think it's good to make a quick - simple effect.
            I see a Action Sequences but I don't find a way to use it too. don't you ?
            • 3. Re: Flash catalyst didn't meet my expectations
              GeneralMarketingService Level 1
              Thank you for both of your repllies.
              Actually I did use the Lynda training which was very helpful, and I pretty much followed their type of model for my project.
              But as i said, several of the objects on their own layers did now show up in the transitions window,  this became frustrating and so I chose not to go forward wit the project here.
              Regarding the idea to program new transitions.  That is a great option and idea but I think the concept of Catalyst is to simplify the process.
              I posted this mostly because I thought the Adobe folks may benefit from the feedback
              Regards
              • 4. Re: Flash catalyst didn't meet my expectations
                cachefinder
                A lot of the bugs you describe sound similar to what I faced...
                For one thing, how you actually move content etc and work the layers can create some unexpected results.  Also you can 'break' past navigations if the navigation is complex enough.
                I find that by using transparent button (0:% opacity) with all the needed interactions, and also having nicely layered file at the outset, help a lot.
                Learning to (partially) manage the state issue by building custom components correctly is also helping me a lot .
                My biggest gripe with the transitions or moving layers etc, is that bulk transitions can't be done at once, and also the layers/library planels do not let you move more than one line-item at a time (say, grabbing a few layres and moving them at once.).I think Catalyst is sort of 'deceptively simple'.
                Not sure if that encourages you... or makes it worse!
                • 5. mysery loves company
                  Hi...and thanks for your reply.
                  I appreciate your comments and figure there had to be more people than me with some issues.
                  The program itself is fairly easy to use....and i agree with your various points about fixes as well.
                  I suppose the Real question is... will Adobe put forth the effort to fix everything, or will they let it fade into the sunset.
                  I'm willing to try out a new version, but want to wait a little longer   I've gone back to Swishmax4 for my more basic flash projects
                  but i really miss the Photoshop import feature.  That is a great feature of Catalyst.
                  • 6. Illustrator...
                    CacheTrade
                    I love how I can pick out small elements of an illustrator file drawing (like stroke or fill, etc) and attached all kind of info.
