I'm using RH8, and when I create a numbered list, what displays when I use the "View Selected Item" button and when I actually generate the WebHelp project is different from the Designer view. The font used is Calibri, but only the numbers in the numbered list display a different font: Times New Roman. The text that follows the number is Calibri, which is correct. How can I get the numbers in a numbered list to be the same as the text that follows the number?
It's likely a style issue; that is, there is no style specifically assigned to the list HTML element, so the browser uses the default TNR. You'll probably see (none) in the Style box of the Formatting toolbar.
Leon
See Lists in the RoboHelp Tour on my site. This explains what Leon is referring to and how to work with Lists in RoboHelp 8.
