I have a spark list with this ActionScript referencing it:
choicesList.doubleClickEnabled = true;
choicesList.addEventListener(ItemClickEvent.ITEM_CLICK, choiceDown);
It works fine in the Android emulator and on a Tablet but it does not work on the BlackBerry Playbook Simulator.
I don't see a doubleTap event to try so just wondering if anyone has advice before I kludge a timed two click event work around.
The rest of the app works amazingly perfect ;-).
Dan
PS - here is the Android Market link:
I did a simple test on the double click issue and took the short example from RIM and changed the button click to a double click:
closeButton.doubleClickEnabled = true;
closeButton.addEventListener(MouseEvent.DOUBLE_CLICK, closeWindow);
//closeButton.addEventListener(MouseEvent.CLICK, closeWindow);
And it does not work in the Playbook simulator whereas the click does.
I can make a custom handler to figure out when a click is a doubleclick - but just wondering if there is any news on this. I will post in the blackberry forum too.
Just found the answer on the RIM forum: Yes, it's still a problem in 0.9.3. In the issue tracker, RIM has acknowledged this. It was supposed to be fixed but, not quite yet and it is an issue with the Simulator only, I believe.
