3 Replies Latest reply on Mar 31, 2011 8:22 PM by fhfghgfh434
    Custom shader help
    fhfghgfh434 Level 1
      Hello  I've been trying to build a pixel bender filter for Flash player, but cant figure out the last part. The code supposed to display a black (or custom color) line, where a white area moves trough the line (like a pulsating line animation). My problem is, that i cant figure out, how to change the central part's color to black.
      heres my code until now:
      The .as file:
      package{
      import flash.display.Shader;
      import flash.display.Sprite;
      import flash.events.Event;
      import flash.filters.ShaderFilter;
      import flash.utils.ByteArray;
      public class test extends Sprite{
      [Embed(source = 'PBfilter2.pbj', mimeType = "application/octet-stream")]
      public var RB2:Class;
      private var shader2:Shader;
      private var bg:Sprite = new Sprite();
      public function test(){
      shader2 = new Shader(new RB2() as ByteArray);
      addChild(bg);
      bg.x = bg.y = 200
      addEventListener(Event.ENTER_FRAME,onFrame);
      graphics.clear();
      graphics.beginFill(0xff0000)
      graphics.drawRoundRect(1,1,400,400,20,20)
      var cnt:Number = 0
      private function onFrame(e:Event):void{
      var lw:Number = mouseX-200;
      var lh:Number = mouseY-200;
      var high:Number = Math.abs(lh);
      if ( Math.abs(lw)>high ) high = Math.abs(lw);
      var len:Number = Math.sqrt(lw*lw+lh*lh)+100
      if (cnt> len) cnt =0
      shader2.data.center.value = [cnt-50];
      shader2.data.rotation.value = [Math.atan2( lh,lw )];
      shader2.data.attenuationDelta.value = [40];
      bg.graphics.clear();
      bg.graphics.lineStyle(2);
      bg.graphics.moveTo(0,0);
      bg.graphics.curveTo(mouseX-200,mouseY-200,mouseX-200,mouseY-200);
      bg.filters = [new ShaderFilter(shader2)]
      cnt = cnt+9;
      the shader:
      <languageVersion : 1.0;>
      kernel SimplePointLight
      <   namespace : "noo";
          vendor : "me";
          version : 0;
          description : "aaaaaa";
          parameter float center<
              minValue: float(0.0);
              maxValue: float(4096.0);
              defaultValue: float(0.0);
          parameter float attenuationDelta<
                  maxValue: float(500.0);
                  defaultValue: float(15.0);
          parameter float attenuationSpeed<
                  maxValue: float(2.0);
                  defaultValue: float(1.0);
          parameter float attenuationDecay<
          parameter float rotation<
                  minValue: float(0.001);
                  maxValue: float(6.282);
                  defaultValue: float(0.01);
          #if !AIF_FLASH_TARGET
           parameter float2 size<
              minValue:float2(0,0);
              maxValue:float2(1024,1024);
              defaultValue:float2(1024, 512);
          region generated(){
              return region(float4(0, 0, size.x, size.y));
          #endif
          parameter float bgred<
                  maxValue: float(1);
                  defaultValue: float(0);
          parameter float bggreen<
                  maxValue: float(1);
          parameter float bgblue<
                  maxValue: float(1);
          output pixel4 dst;
          input image4 src;
          void evaluatePixel() {
              float2 out_pixel_coord = outCoord();
              float dist = cos(rotation)*( out_pixel_coord.x-tan(rotation)*(center/sin(rotation)-out_pixel_coord.y) );
              //??rosszfloat dist = sin(rotation)*( out_pixel_coord.x-center.x*(tan(rotation)-out_pixel_coord.y)/tan(rotation) );
              float att = pow(attenuationDelta/pow(abs(dist), attenuationDecay), attenuationSpeed);
             //  dst =  pixel4(bgred,bggreen,bgblue,0)+attenuation*pixel4(1,1,1,1);
              //dst =  attenuation*sampleNearest(src,outCoord());
              float4 colorAccumulator=float4(0.0, 0.0, 0.0, 0.0);
              float2 singlePixel=pixelSize(src);
              colorAccumulator +=sampleNearest(src, outCoord());
              colorAccumulator +=sampleNearest(src,outCoord()-(float2(0,1) * singlePixel ));
              colorAccumulator +=sampleNearest(src,outCoord()+(float2(0,1) * singlePixel ));
              colorAccumulator +=sampleNearest(src,outCoord()-(float2(0,1) * singlePixel*2.0 ));
              colorAccumulator +=sampleNearest(src,outCoord()+(float2(0,1) * singlePixel*2.0  ));
              colorAccumulator +=sampleNearest(src,outCoord()-(float2(1,0) * singlePixel ));
              colorAccumulator +=sampleNearest(src,outCoord()+(float2(1,0) * singlePixel ));
              colorAccumulator +=sampleNearest(src,outCoord()-(float2(1,0) * singlePixel*2.0 ));
              colorAccumulator +=sampleNearest(src,outCoord()+(float2(1,0) * singlePixel*2.0  ));
              //the part affected by att*colorAccumulator/5.0 should be white..
              dst=pixel4(0,0,0,0)+att*colorAccumulator/5.0+sampleNearest(src,outCoord());
      Thanks for help
        • 1. Re: Custom shader help
          unique_screenname_here Level 3
          Is the Pixel Bender filter doing what you want when run from the Pixel Bender Toolkit?
          • 2. Re: Custom shader help
            fhfghgfh434 Level 1
            No, i dont really rely on the output, since i use it for a special case. I am using it to shade a line drawn in actionscript.
            I noticed, that the image i see in pixel bender differs a lot from what i see in flash player (for example alphas behave different)
            What i want to do is basically a combination of filters:
            i want a filter, that affects only a part of a line, the part it affects wil be thicker (this works OK), and has a different color (this does not work)  - here is one of my other unsuccesful approaches (substitute this in the place of dst=pixel4(0,0,0,0)+att*colorAccumulator/5.0+sampleNearest(src,outCoord());):
            float4 localGlow = att*colorAccumulator/5.0;
            float4 lineColor = sampleNearest(src,outCoord());
            dst=pixel4(1,1,1,localGlow.w)+pixel4(0,0,0,lineColor.w);
            if i change dst to:
            dst=pixel4(1,1,1,localGlow.w);
            The a part of the line gets colored white, while other parts stay opaque - this is OK.
            if i change dst to:
            dst=pixel4(0,0,0,lineColor.w);
            Then the whole line gets colored to black - this is what i want
            BUT if i add these two together the whole line will be white:
            why dont i see black color, at parts, where localGlow.w is almost 0?  (or is it higher than 1 everywhere? then why has my line transparent parts if i only use this part of the sum?)
            Thanks for help
            • 3. Re: Custom shader help
              fhfghgfh434 Level 1
              I could solve my problem, the changed line is:
                   dst=pixel4(localGlow.w-0.1,localGlow.w-0.1,localGlow.w,localGlow.w)+pixel4(0,0,0,lineColo r.w-0.3);
              but i ran into a new problem, ill post it as a separate thread
