5 Replies Latest reply on Mar 31, 2011 12:37 AM by Lilybiri
    How get more widgets?
    balnco
      Hi
      My default widget panel only has one widget. Please can someone tell me how do I  get more widget to display in theis panel ?
      Thanks.
        • 1. Re: How get more widgets?
          Sagarika Kengunte Level 1
          Hi balnco,
          Can you please check the following?
          1. Is the widget panel wide enough to see all the items? If not, undock it and maximise it to see all the items.
          2. What is chosen in the Filter widget dropdown at the bottom of the panel? Is it showing 'All'? If not, can you select 'All' and check?
          3. If none of the above works, can you try adding more widgets to the panel by clicking on the 'Browse' button at the bottom of the Widget panel and selecting the widgets you want to add. You can find the widgets in 'Adobe Captivate\Gallery\Widgets' location.
          Sagarika
          • 2. Re: How get more widgets?
            balnco
            Thanks,3 works, but it only let me add 1 at a time. how do add multiples widget to the panel in one go
            • 3. Re: How get more widgets?
              balnco
              Thanks,3 works, but it only let me add 1 at a time. how do add multiples at once ?
              Date: Wed, 30 Mar 2011 23:00:19 -0600
              To: stephen_white22@hotmail.com
              Subject: How get more widgets?
              Hi balnco,
              Sagarika
              • 4. Re: How get more widgets?
                Hi balnco,
                You can follow one of the following to add multiple widgets to the panel in one go.
                1. Copy all the required widgets to the default folder 'Adobe Captivate\Gallery\Widgets' and click on the 'Refresh' button at the bottom of  Widget panel. All the widgets in this default folder will be listed in the panel.
                (or)
                2. Place all the required widgets in a folder and click on 'Change Path' button at the bottom of Widget panel. Select this folder in the Browse dialog. All the widgets in this folder will be listed in the panel.
                Sagarika
                • 5. Re: How get more widgets?
                  Lilybiri MVP & Adobe Community Professional
                  Hello,
                  If you want the widgets in all your projects, please do the following when not having any project open:
                  • Open the panel Widgets, or choose the workspace Widgets and you'll find the panel in the left docking station
                  • Open the folder icon at the bottom (highlighted in yellow in screenshot)
                  • Point to the path <captivate folder>\Gallery\Widgets
                  • All the widgets will show up, you can eventually filter on type of widget (Static; Interactive, Question), by default all widgets are in the panel
