3 Replies Latest reply on Aug 14, 2006 7:40 AM by kglad
    TextField Help!
    Daniel_Leonard
      Hey,
      I'm still new to action script in Flash 8. I want to be able to add a paragraph of text to an empty text field via action script. Heres what I'm typing in the action panel. News_txt is the instance name on the stage.
      this.Recent_mc.onPress = function() {
      News_txt.text = "This is the text I am typing to show in the SWF and
      its not working. I really want this to work. Blah blah blah blah. I'm
      just filling up space";
      Heres what the output panel says...
      **Error** Scene=Scene 1, layer=Actions, frame=1:Line 26: String literal was not properly terminated
      **Error** Scene=Scene 1, layer=Actions, frame=1:Line 27: Syntax error.
      **Error** Scene=Scene 1, layer=Actions, frame=1:Line 28: Syntax error.
      **Error** Scene=Scene 1, layer=Actions, frame=1:Line 29: Syntax error.
      Total ActionScript Errors: 4 Reported Errors: 4
      How do I fix this? How do I make it so that when I type text in the action script panel it doesnt carry all the way across the screen out of view? I want to be able to type it in the panel like I was typing it as a normal paragraph. Any help is appreciated. Thanks guys.
      Dan
        • 1. Re: TextField Help!
          don't use the enter key in your string. if you want to indicate a new line (or carriage return) for the textfield use \n (or \r ).
          • 2. Re: TextField Help!
            Daniel_Leonard Level 1
            Hey thanks for the response. I still can't get it to work though. I tried the style sheet method and its not working either. Do you mind repasting the actionscript I put here with corrections?
            var ourStylesheet = new TextField.StyleSheet();
            ourStylesheet.setStyle("p", {fontFamily:'_sans', fontSize:'12 px', color:'#000000'});
            newsTextArea.styleSheet = ourStyleSheet;
            newsTextArea.html = true;
            newsTextArea.text = "<p> what happens when the viewer is placed into a
            movie title? An interesting example of Flash/Freehand connection.</p>";
            output = **Error** Scene=Scene 1, layer=Actions, frame=1:Line 32: String literal was not properly terminated
            newsTextArea.text = "<p> what happens when the viewer is placed into a </n>
            **Error** Scene=Scene 1, layer=Actions, frame=1:Line 33: Syntax error.
            **Error** Scene=Scene 1, layer=Actions, frame=1:Line 31: Statement block must be terminated by '}'
            **Error** Scene=Scene 1, layer=Actions, frame=1:Line 35: Syntax error.
            • 3. Re: TextField Help!
              it looks like you still are using an enter key after "into a". copy and paste either of the two codes below:
