3 Replies Latest reply on Dec 19, 2007 5:20 AM by kloshih
    internal build error
    vinnie.vivace
      im using the plugin, and have a small library project (around 10 .as files). i can no longer build, getting an internal build error.
      ive tried cleaning, deleting and recreating project etc. Any ideas?
      the error log file reads:
      !ENTRY com.adobe.flexbuilder.project 4 43 2007-06-14 15:31:05.968
      !MESSAGE Uncaught exception in compiler
      !STACK 0
      java.lang.VerifyError: (class: flash/swf/TagDecoder, method: decodeStyleChangeRecord signature: (ZZZZZI[I[I)Lflash/swf/types/StyleChangeRecord;) Unable to pop operand off an empty stack
      at flex2.compiler.swc.SwcLibrary.parse(SwcLibrary.java:134)
      at flex2.compiler.swc.SwcScript.getDoABC(SwcScript.java:46)
      at flex2.compiler.swc.SwcGroup.updateMaps(SwcGroup.java:267)
      at flex2.compiler.swc.SwcGroup.<init>(SwcGroup.java:46)
      at flex2.compiler.swc.SwcCache.getSwcGroup(SwcCache.java:78)
      at flex2.compiler.swc.SwcCache.getSwcGroup(SwcCache.java:65)
      at flex2.compiler.CompilerSwcContext.load(CompilerSwcContext.java:56)
      at flex2.tools.oem.Library.recompile(Library.java:697)
      at flex2.tools.oem.Library.compile(Library.java:1036)
      at flex2.tools.flexbuilder.BuilderLibrary.compile(BuilderLibrary.java:343)
      at com.adobe.flexbuilder.multisdk.compiler.internal.FlexLibraryBuilder$MyLibrary.mybuild(Fle xLibraryBuilder.java:233)
      at com.adobe.flexbuilder.multisdk.compiler.internal.FlexLibraryBuilder.build(FlexLibraryBuil der.java:104)
      at com.adobe.flexbuilder.multisdk.compiler.internal.ASBuilder.build(ASBuilder.java:100)
      at com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.buildItem(Unknown Source)
      at com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.build(Unknown Source)
      at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:603)
      at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
      at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:167)
      at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:201)
      at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:230)
      at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:233)
      at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:252)
      at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:285)
      at org.eclipse.core.internal.resources.Workspace.build(Workspace.java:271)
      at org.eclipse.ui.actions.GlobalBuildAction$1.run(GlobalBuildAction.java:183)
      at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
