1 Reply Latest reply on Mar 31, 2011 3:04 PM by Peter Grainge
    Need to produce all webhelp files as UTF-8 No BOM - RH-7 does not do that.
    rschwarz100 Level 1
      RoboHelp 7 seems to produce some HTML files  and javascript files (*.js) in ANSI European encoding. My company needs all the webhelp code to be UTF-8 no BOM. The webhelp is managed through Perforce.
      I tried on my own to use FAR 4.3 to change the encoding from ANSI to UTF-8 no BOM for all of my htm and js webhelp files for a particular webhelp – I used Auto-detect using BOM signature. FAR changed the files to UTF-8 with BOM. I tried to turn off the BOM by converting with Assume UTF-8 if no BOM signature – that did not work at all (FAR assumed all files were already UTF-8 and did not convert them).
      Is there some way to change this in RoboHelp 7? Can RoboHelp 9 solve this problem?
      If not, is there a post webhelp production solution that can convert all the webhelp in one “batch?”
