1. Re: Premiere Elements nine questions
Steve Grisetti Mar 31, 2011 4:54 PM (in response to KYBloodstaineD)I would not recommend using WMVs as your source video. They'll bog the whole program down.
What kind of camcorder is your video coming from? There's probably a much more efficient workflow that won't require nearly so much rendering.
Meantime, if you're looking to learn this basics of this program, check out my free 8-part Basic Training tutorials at Premiere Elements support site Muvipix.com.
And, if you'd like more detailed, step-by-step instruction, you can check out my books.
2. Re: Premiere Elements nine questions
KYBloodstaineD Mar 31, 2011 4:58 PM (in response to Steve Grisetti)it's a handycam made by sony, i'll just find a video format converter or something, what format should i use? avi?
3. Re: Premiere Elements nine questions
John T Smith Mar 31, 2011 7:00 PM (in response to KYBloodstaineD)1 person found this helpfulConvert your files to DV-AVI Type II with 48KHz 16-bit Audio
4. Re: Premiere Elements nine questions
Steve Grisetti Apr 1, 2011 5:49 AM (in response to John T Smith)Can you be more specific about what model of Sony? Sony makes camcorders in virtually every format -- plus a couple of multi-format models.
We can't give you specific directions until we know specifically what you're working with.
5. Re: Premiere Elements nine questions
KYBloodstaineD Apr 1, 2011 1:22 PM (in response to Steve Grisetti)it says DCR-SR68
sorry im new to everything about movies, and before i go to collage for this i wanna learn atleast all the basics,
it took me a long while to dicide that when i grow up that i wanna be working with movies in all sorts of fields
and also i tryed converting the files to AVI, it say's it doesnt support it, idk,
the sony cam i got came with this PMB software, should i keep that or use something else?
6. Re: Premiere Elements nine questions
Steve Grisetti Apr 1, 2011 1:51 PM (in response to KYBloodstaineD)That camcorder produces standard resolution MPEG files.
The best solution is to convert these MPEGs to DV-AVIs using MPEG Streamclip and the specs described in this FAQ.Not just any AVIs will do. You need to follow the exact instructions in this article in order for the video to work in this program.
http://forums.adobe.com/thread/415317?tstart=0
You will then be able to edit this video using the standard DV project presets.
The link in my first post will take you through the basics of how to do this and use the program to edit your video.
7. Re: Premiere Elements nine questions
KYBloodstaineD Apr 1, 2011 3:10 PM (in response to Steve Grisetti)i got it downloaded, but it doesn't say i can convert it to DV-AVI
8. Re: Premiere Elements nine questions
Steve Grisetti Apr 1, 2011 8:16 PM (in response to KYBloodstaineD)1 person found this helpfulIt will if you follow the instructions in the above link.
9. Re: Premiere Elements nine questions
KYBloodstaineD Apr 1, 2011 9:10 PM (in response to Steve Grisetti)ahh ok, im starting to get it, thanks =]
