3 Replies Latest reply on Apr 1, 2011 9:31 AM by calbara
    motion ease not working
    Lee@foremost
      Hi, I have created a motion tween in Flash and want to slow the speed of the tween towards the end, so my image doesnt stop suddenly. I applied a slow ease which was working previously but has now decided to stop working and I cannot get it to work again. The strange thing is when I change the ease value from 100 to -100, so the ease is applied to the start of the motion, that works fine, but when I change it back to 100 the ease wont apply to the end of the motion
        • 1. Re: motion ease not working
          nocturnal YL Level 1
          Ease applies to the entire classic/shape tween, not part of it.
          100 means move more at the beginning (stop slowly), -100 means move more at the end (stop abruptly).
          If you want the object to move slowly at both ends, break the tween into two tweens by inserting a keyframe in the middle, apply 100 ease at the latter half and -100 ease at the first half.
          • 2. Re: motion ease not working
            Lee@foremost Level 1
            Thank you for your reply, unfortunately that isnt my problem. What I am seeing is that the ease will not apply to the motion when the value is set to 100. I did a test by changing the value to -100 to see if the ease would apply at all, which worked and the motion eased in. This isnt what I want however, I want the motion to ease out, but cannot get it to do so.
            • 3. Re: motion ease not working
              calbara
              you try to use methods of easing in it.
              you create a variable of type Tween.
              then you create a function in which there are variables.
              as an example I created in AS 3.0 a variable
              inTween = new Tween (pic_mc, "y", Back.easeOut, 0,250,1, true);
              and do not forget to import a class :
              import fl.transitions.Tween;
              import fl.transitions.easing.*;
