1. Re: Sequence Setting For Stills - How to Get Sepia Look?
joe bloe premiere Apr 1, 2011 6:18 AM (in response to Rkenosha)Could someone make a sequence setting suggestion as I start this project.
You should use a sequence setting that matches your intended delivery format.
Also, is there a sepia filter in Ppro
You can get a decent sepia look using "Tint" along with "Brightness and Contrast".
Effects > Video Effects > Color CorrectionIf you need more control of your tinting, you might consider doing your
color correction / tinting in After Effects. -
2. Re: Sequence Setting For Stills - How to Get Sepia Look?
Todd_Kopriva Apr 1, 2011 9:48 PM (in response to Rkenosha)Richard Harrington shows one of many ways to do sepia tinting here:
http://library.creativecow.net/harrington_richard/Premiere-Pro_BW-Conversion/1
3. Re: Sequence Setting For Stills - How to Get Sepia Look?
cvid01 Apr 2, 2011 8:19 AM (in response to Rkenosha)Also, Photoshop can do a great job changing your photos to sepia tint. Photoshop CS5 even has an action for doing so.
4. Re: Sequence Setting For Stills - How to Get Sepia Look?
shooternz Apr 2, 2011 2:40 PM (in response to joe bloe premiere)You should use a sequence setting that matches your intended delivery format
You can do that but it is kind of restrictive down the track if you need a delivery in a higher rez or dimension..
Match your Sequence settings to your source with a consideration to your end delivery format and possible future formats.
5. Re: Sequence Setting For Stills - How to Get Sepia Look?
joe bloe premiere Apr 2, 2011 3:36 PM (in response to shooternz)Match your Sequence settings to your source with a consideration to your end delivery format and possible future formats.
You're right.
He may want to do an IMAX version down the line.
