3 Replies Latest reply on Apr 2, 2011 6:51 AM by Harm Millaard
    Rendering Problems
    EagleEyePro
      I have a new system built for adobe specs:
      00026 Xi®  MTower™ 64 Workstation (Base Configuration) $959.00
      01664 AMD® Phenom™ II  X6 1090T 3.2GHz 64Bit Black Edition Six-Core 45nm 9MB L2+L3 Cache HyperTransport™ 125W $169.00
      02242 16384MB DDR3 @1333MHz 4x4GB Dual Rank Interleave (Dual RAM Channel MoBo only) $349.00
      04385 nVidia® Quadro® 4000 2GB DDR5 PCIe 16x 2.0-1x DVI-DL-2xDP-1x Stereo-Dual Head 3D Pro Support-DX11-OGL 4.0- Shad.M 5.0 $749.00
      05015 No Monitor (credit) ($140.00)
      03136 640GB 7200RPM SATA 6.0Gb/s 64MB Cache 11ms avg. seek. (no RAID) $49.00
      32109 Optional 640GB 7200RPM SATA 6.0Gb/s 64MB Cache 11ms avg. seek. (No RAID) $99.00
      17012 HD Ctrl. According To Motherboard and HD Type Selected Incl. w/ Base
      06061 DVD+RW/DL/+R-R/CD-RW Double Media 4.7/8.5GB 18x w/Software-media $49.00
      09010 Digital multichannel sound accordingly to motherboard selected Incl. w/ Base
      12024 On board 1GB Ethernet (10/100/1000) on board LAN Incl. w/ Base
      13017 No Keyboard ($8.00)
      14001 No mouse ($8.00)
      16084 Genuine Microsoft® Windows® 7 Professional Edition 64Bit on DVD (32Bit & XP Pro downgrade avail. on request) $59.00
      20090 Resource CD - contains Diagnostic links & Drivers Incl. w/ Base
      20091 Quick Reference Guide and @Xi Computer Manual (PDF) Incl. w/ Base
      20160 Belkin® Hi-Speed USB 2.0 15-in-1 FlashCard Reader/Writer External $45.00
      22212 Asus® M4A77TD AMD770/SB710 1xPCIe 16x 2.0 1x PCIe x1 3xPCI DDR3  1066/1600(O.C.) 1x1Gb Ethernet-5xSATA3Gb-RAID/JBOD-12USB ports-7.1CH  Digital Audio Incl. w/ Base
      44036 850W Cooler Master™ SilentProM™ Quiet BB 12cm Fan 80%+efficiency 99% APFC UL $79.00
      18012 One Year On Site Service + Std. Xi Warranty 1 year on System, Mfg. on Monitor $59.00
      27157 Xi® MTower™ CM-Elite™ 430 2x12cm Quiet Fans-Front Grid-2x Front USB- 3x 5 1/4" 7x 3 1/2"
      My problem is. I have a DV project NTSC. I am exporting to DVD. I first used dynamic link to encore. Took 5 days to render a 3.5 hour DVD; it errored and did not burn it??? I am now exporting as MPG2 DVD to my third hard drive. I am exporting a 55 minute clip as such. It is now 10 hours later, and I am at 24%
      I have 13 GB ram dedicated to Premiere and 3 GB dedicated to background programs
      Any advice please??
        • 1. Re: Rendering Problems
          Harm Millaard Level 7
          I know this is not the kind of feedback you were waiting for, but here it is:
          1. What a waste of money. Way overpriced with nothing more than mediocre specs.
          2. AMD's are always slow in comparison to Intel, because of the lacking SSE4.1+ support. See PPBM5 Benchmark
          3. If you don't want to upgrade to an Intel system (I can understand that is not your first priority), try tuning your system, which also applies to Win7: Adobe Forums: Guide for installing and tuning a Vista...
          This system should be more than adequate for DV material, not for AVCHD, but for your purposes and your material it should be fine. Tuning your system ought to give much better results. If you are still unsuccessful, go to the link "How to get Help Quickly" topic under the Help tab on the right hand of the page and look at the second part of that article. It details further details required in order to help you.
          • 2. Re: Rendering Problems
            EagleEyePro Level 1
            Thanks for the advice. I do appreciate it, and it could have future use-but wasn't the issues here.
            Well, Intel was on recall when I ordered; so AMD it was. Also this was the cheapest of 5 quotes. Adobe support helped me to get ahold of the main issues. Setting the memory preference to memory from performance; and setting task manager priority as high for premiere from normal-took my render from 4 days to 4 hours.
            Problem solved.
            • 3. Re: Rendering Problems
              Setting priority to high and having such an impact on performance is very likely caused by background processes that steal CPU/memory under normal priority. I suggest you check with Process Explorer how many processes are running and if more than 40 - 50, clean up. Also check the memory footprint of these processes.
