I am putting video into presenter slides, the playback
default size is rather small. Can the screen viewing area be
altered to fill the entire screen? If so how? Thanks in advance.
Becky in Sydney.
Becky: As you may already be aware, The swf format in the
power point slide can be the same size as the power point about
520x470 - but you can look that up in the on-line manual.
Presenter only plays back at 800x600. The best way to get
more real estate for your video in the power Point slide is too
enable full screen mode as the default mode in the theme editor. I
hope that helps
FLVs can't be placed in the main slide area, but only in the
upper part of the side bar and there is no way to make these
larger. SWFs can be placed in the main slide area, see "jonturkle"s
advice above for that tweak.
