4 Replies Latest reply on Apr 4, 2011 9:12 AM by lahglc
    Date/Time field format not wysiwyg
    lahglc
      I have a date field in my form that I formatted as m/d/yyyy hh:mm.  I thought that because it formats that field in that way my script would get passed down that way however it is not.  I want to manipulate it so the value is in the format I want it to be....
      I enter this in the date/time field: April 1, 2011 1:40PM
      When I click out of the field and I see: 4/1/2011 13:40
      Then I have a script that uses this field to make the file name but because I have a comma in there it will not save, if I take the comma out it will save.  So the main question is how do I format my field to pass down the value that I am seeing not the value that I am typing in.  You will notice I have a replace in there but I can't account for the comma because it reads it as part of the syntax.
      // Get the field value
      var dtentered = getField("datetime").value;
      //replace any odd characters that will not allow the file to save
      var fdt = dtentered.replace(/[!@#$%^&*()+=|\:;"'<>?/{}]/g,"_");
      // Specify the folder
      var fldr = "/c/WO Completed/";
      // Determine the full name and path
      var fp = fldr +  fdt + ".pdf";
        • 1. Re: Date/Time field format not wysiwyg
          You need to escape it with a back-slash. Also, you need to escape all the
          other special characters.
          • 2. Re: Date/Time field format not wysiwyg
            lahglc Level 1
            Thanks for the response...I'm not sure that I understand what you mean back-slash...I went ahead and did this but now it is giving me an odd file name
            var dt = getField("datetime").value;
            var mydt = escape(dt);
            var fdt = mydt.replace(/[!@#$%^&*()+=|\:;"'<>?/{}]/g,"_");
            Returns a file name as
            April_201_2C_202011_201_3A40PM.pdf
            I was looking more for
            4_1_2011_13_40.pdf
            or
            April_1_2011_1_40PM.pdf
            • 3. Re: Date/Time field format not wysiwyg
              George_Johnson MVP & Adobe Community Professional
              If you want to get the formatted data as it appears in the field, set up a document-level function:
              function getFormattedDate(sFieldname, cFormat) {
                  var sDate = getField(sFieldname).valueAsString;
                  var date = AFParseDateEx(sDate, cFormat);
                  if (!date) {
                      return "";
                  } else {
                      return util.printd(cFormat, date);
              and call it like this:
              var dt = getFormattedDate("datetime", "m/d/yyyy HH:MM");
              • 4. Re: Date/Time field format not wysiwyg
                lahglc Level 1
                Thank you George and Try67.  This last date format function works like magic!
