1. Re: Any ideas why I got this build error?
Giorgio1957 Apr 2, 2011 9:02 AM (in response to zorrocbr)Hi Zorro,
The first thing that makes me confused is your movie bitrate.
Ok for size and framerate but 6000 is very low.
Usually I work with 25000 or 28000.
Hope this helps.
Ciao
Giorgio
2. Re: Any ideas why I got this build error?
Stan Jones Apr 2, 2011 6:53 PM (in response to Giorgio1957)He's putting SD on a bluray.
3. Re: Any ideas why I got this build error?
zorrocbr Apr 7, 2011 2:01 PM (in response to Stan Jones)Turns out that Encore didn't like the source file. I also had audio sync issues. I started to break the original file down in Womble into each edited point and then export that file to determine which specific part of the asset it didn't like and also to solve the sync issues. Then I played a hunch and simply imported the whole Womble file (the same file I had originally imported into Encore) into TMP (project set to Blu-ray), set the project to no menus and set it so it would not transcode. I then imported this file into Encore and all the problems were solved- No audio sync issues and the file burned properly. Weird that the same file would be interpreted so differently in two different programs.
