12 Replies Latest reply on Apr 6, 2011 4:06 AM by try67
    Reposition field using combo box value
    MadMich
      I have an error at line 18 on this code?
      When a combo box selection is made it is supposed to move the 3 fields?
      Any advice would be greatly appreciated.
      var d = this.getField("Step.0.1");
      var e = this.getField("Step.1.1");
      var f = this.getField("Step.2.1");
      var aFields = ["Step.0.1", "Step.1.1", "Step.2.1"];
      switch (event.value) {
      case "0":
          d.rect = [474.31298828125,505.59600830078125,602.52197265625,450.64898681640625];
          e.rect = [474.31298828125,449.385986328125,602.52197265625,394.4389953613281];
          f.rect = [474.31298828125,393.1759948730469,602.52197265625,338.22900390625];
      case "10%":
          for(i = 0; i < aFields.length; i++) {
          var aRect = aFields.rect;
          aRect[1] += -10;
          aRect[3] += -10;
          aFields.rect = aRect;
      case "20%":
          aRect[1] += -20;
          aRect[3] += -20;
      case "30%":
          aRect[1] += -30;
          aRect[3] += -30;
      default:
        • 1. Re: Reposition field using combo box value
          You need to add a "break" command at the end of each case block.
          The error is that you're trying to access aFields.rect instead of
          this.getField(aFields[i]).rect
          • 2. Re: Reposition field using combo box value
            MadMich Level 1
            Cheers for your help, i've added your comments but still get an error at line 18?
            Here is the code amended:
            case "0":
                break;
            case "10%":
                var aRect = this.getField(aFields[i]).rect;
                aRect[1] += -10;
                aRect[3] += -10;
                this.getField(aFields[i]).rect = aRect;
                break;
            case "20%":
                aRect[1] += -20;
                aRect[3] += -20;
                break;
            case "30%":
                aRect[1] += -30;
                aRect[3] += -30;
                break;
            default:
            • 3. Re: Reposition field using combo box value
              Post the exact error message you're getting.
              • 4. Re: Reposition field using combo box value
                MadMich Level 1
                Here is the error, (sorry since i added the bits the error line has moved up!)
                JavaScript error at line 17: SyntaxError: illegal character
                16:. Fix it?
                • 5. Re: Reposition field using combo box value
                  Not sure if it's that, but in the last parameter of d.rect you have a space
                  in the middle of the number.
                  • 6. Re: Reposition field using combo box value
                    MadMich Level 1
                    I think it's just the way it's viewing, still no luck!
                    My coding must be getting better, i thought it may have been a more obvious mistake.
                    • 7. Re: Reposition field using combo box value
                      MadMich Level 1
                      I think I've fixed it but i cant seem to get it to work outside the console?
                      The code is under custom validation scripts in a combo box, and is set to move 3 boxes in 10 increments.
                      When i make a selection nothing happens?
                      Here is my amended script, any ideas would be appreciated.
                      var aFields = [d,e,f];
                      case "0":
                      d.rect = [474.31298828125,505.59600830078125,602.52197265625,450.6489868164062 5];
                      break;
                      case "10%":
                      var aRect = aFields[i].rect;
                      aRect[1] -= 10;
                      aRect[3] -= 10;
                      aFields[i].rect = aRect}
                      break;
                      case "20%":
                      aRect[1] -= 20;
                      aRect[3] -= 20;
                      break;
                      case "30%":
                      aRect[1] -= 30;
                      aRect[3] -= 30;
                      break;
                      default:
                      • 8. Re: Reposition field using combo box value
                        It doesn't make sense that this will work in the console (there's no event.value) and not from the field itself.
                        There must be something else wrong.
                        • 9. Re: Reposition field using combo box value
                          MadMich Level 1
                          Sorry I only used part of the code in the console.
                          As you can gather i'm still stuck?
                          • 10. Re: Reposition field using combo box value
                            I can't help you if I don't know which exact code you're using, from which
                            context, and what error messages you're getting.
                            • 11. Re: Reposition field using combo box value
                              MadMich Level 1
                              Hi try67,
                              This is part of my code i checked in the console:
                              aRect[1] -= 10;
                              aRect[3] -= 10;
                              I don't understand how this part works in the console but not as part of the entire script (submitted above which errors at "
                              var aRect = aFields[i].rect;").
                              The error code  is:
                              15:AcroForm:Subject.3:Validate
                              15:
                              The script as mentioned is part of a combo box vlidation script.
                              Thanks for your time, I'd upload the pdf example (as i have on another site) but don't seem to have the option on this site?
                              • 12. Re: Reposition field using combo box value
                                I put this script in a button action and it works fine.
