1 Reply Latest reply on Apr 2, 2011 12:37 PM by the_wine_snob
    PE8 unable to play 5.1 sound from an imported .m2ts
    kkekoa
      I import an .1080i 5.1 m2ts into PE8 and drag it onto the timeline.  The video lays out ok and the audio track indicates 5.1.  However, no sound track is displayed and no sound occurs during playback.  The m2ts plays fine from Windows Media Player.  I completely wiped my machine back to factory Win7 HP and the latest MS updates with a fresh install of PE8.0.1 but still no sound.  I've tried two presets:  NTSC/AVCHD/Full 1080i 30 5.1 channel and 1080i 30 5.1 channel with no luck.  What am I doing wrong?
      1080i 5.1 recording is stored on a Scientific Atlanta Explorer 8300HDC PVR STB.  STB is connected via component video and optical audio cable to Hauppauge HD-PVR.  .m2ts is created using Total Media Extreme video capture from STB playback through HD-PVR.  Workstation is a Gateway NV7923u laptop i5 M430 2.27GHz, 4GB RAM, 500GB HDD (300GB free), Windows 7 Home Premium 64-bit.
      MediaInfo 0.7.43 shows the following attributes for the .m2ts:
      General
      Complete name                    : F:\2011\KS2011SC\KS2011SC.M2TS
      Format                           : MPEG-TS
      File size                        : 15.0 GiB
      Duration                         : 2h 29mn
      Overall bit rate                 : 14.3 Mbps
      Maximum Overall bit rate         : 18.0 Mbps
      Video
      Menu ID                          : 1 (0x1)
      Format                           : AVC
      Format/Info                      : Advanced Video Codec
      Format profile                   : Main@L4.0
      Format settings, CABAC           : Yes
      Format settings, ReFrames        : 4 frames
      Format settings, GOP             : M=1, N=64
      Codec ID                         : 27
      Duration                         : 2h 29mn
      Bit rate mode                    : Variable
      Bit rate                         : 13.2 Mbps
      Maximum bit rate                 : 20.0 Mbps
      Width                            : 1 920 pixels
      Height                           : 1 080 pixels
      Display aspect ratio             : 16:9
      Frame rate                       : 29.970 fps
      Color space                      : YUV
      Chroma subsampling               : 4:2:0
      Bit depth                        : 8 bits
      Scan type                        : Interlaced
      Scan order                       : Top Field First
      Bits/(Pixel*Frame)               : 0.212
      Stream size                      : 13.8 GiB (92%)
      Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
      Transfer characteristics         : BT.709-5, BT.1361
      Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
      Audio
      Menu ID                          : 1 (0x1)
      Format                           : AC-3
      Format/Info                      : Audio Coding 3
      Mode extension                   : CM (complete main)
      Codec ID                         : 129
      Duration                         : 2h 29mn
      Bit rate mode                    : Constant
      Bit rate                         : 384 Kbps
      Channel(s)                       : 6 channels
      Channel positions                : Front: L C R, Side: L R, LFE
      Sampling rate                    : 48.0 KHz
      Bit depth                        : 16 bits
      Compression mode                 : Lossy
      Delay relative to video          : -100ms
      Stream size                      : 412 MiB (3%)
        • 1. Re: PE8 unable to play 5.1 sound from an imported .m2ts
          the_wine_snob Level 9
          Did you create a New Project with the AVCHD - 5.1 SS Audio Preset?
          If so, then the Audio should go onto Audio 1 Track. If not, then it will go to a higher numbered Audio Track, and you will need to scroll the Timeline vertically to see that Audio Clip.
          Also, when you Imported that Clip, did you allow it to Conform the Audio? This ARTICLE will give you some background.
          PS - note that the above is for editing in Timeline View Mode, and not in Sceneline View Mode.
