1 Reply Latest reply on Jun 14, 2007 11:41 AM by sharonma
    Windows - No Disk Modal Dialog
    Zed_Dev
      When porting a project from Flex2 to Moxie under 2.1 build I am receiving a error "Exception Processing Message c0000013 Parameters 75b6bf9c 75b6bf9c". This code is a mix of classes, packages and MXML code which does compile in Flex2. I have a screen grab available of the error. Has anyone experience this lock up? The dialog cannot be closed under any circumstances.
      Thoughts and advice welcome.
        • 1. Re: Windows - No Disk Modal Dialog
          sharonma Level 1
          Hi Zed_Dev,
          Searching through our bugbase, I found this bug which sounds like the issue you're having: https://bugs.adobe.com/jira/browse/FB-5488
          We're still looking into it. It'd be very helpful if you can add your info to the bug comment. For example:
          - which platform are you running FB3/Moxie?
          - how did you port your FB2 project to FB3/Moxie (e.g. by importing or creating a new project)?
          - are you using the same workspace and/or project folder for FB2 and FB3/Moxie?
          - do you get the error for all the FB2 projects or just certain ones?
          thanks,
          Sharon
