I use the Java API of the livecycle ES to encrypt a dynamic, reader extended PDF. I get the error message:
ALC-ENC-100-015 Can not encrypt reader extended document.
My use case is the following:
A document is sent to some users. It is encrypted with a certificate. The users enter data into the document, encrypt it again and send it back via email. The document is never sent unencrypted. A server receives the email, extracts the document and reads the data the user entered.
How can I implement this use case when I cannot encrypt reader extended documents?
Thanks in advance for your answer.
Regards,
Arne
Solved! Go to Solution.
Views
Total Likes
The order of operations is always Encrypt (first), Reader Extend (second), (and if you are also certifying the document) Certify (third) (when you certify a document, an "Author" digital signature is applied to the document).
There is no way around this, the document must be encrypted first, then RE applied.
Regards
Steve
Views
Total Likes
Regards
Steve
Views
Total Likes
oh, I can add RE to an encrypted document? that is good to know. Plus I did not realize that I can add RE with the Java API.
Thank you very much for your answer, this helped a lot.
Views
Total Likes
I implemented encryption and reader extension and I get the following error when I add reader extensions to my formerly encrypted document:
Caused by: com.adobe.livecycle.readerextensions.client.ProcessingException: ALC-RES-001-022: The input PDF document is encrypted and needs to be unlocked for this operation.
When I do it the other way round, I get the error message I described above. So, how can I encrypt and reader extend my document?
There is a thread here but it does not solve my problem.
Thanks in advance for your help.
Cheers,
Arne
Views
Total Likes
Problem solved, you have to unlock the pdf before adding reader extensions.
There is a difference between unlocking and removing encryption. When you unlock a pdf you just open it up for some operations. After that (precisely: when you call the getInputStream() method) it will be locked (encrypted) again.
When you add encryption to a document, it is added when you persist the doc somehow. From the document's point of view persisting means calling the getInputStream() method. That method is used when you copy the document to a file. This means that you can encrypt a document and add reader extension right after that without unlocking the pdf. When you save it afterwards the encryption wil be applied.
When you encrypt a document, save it and then add RE, you have to unlock it first, because the encryption is already applied.
I hope this helps someone to save the time I needed to figure that out.
Happy encrypting,
Arne
Views
Total Likes
