1 Reply Latest reply on Apr 5, 2011 7:04 PM by cut-copy-paste
    Need advice on how to approach interactive timeline/chart Component
    cut-copy-paste Level 1
      For my application I need a component (or combination of components) that shows a number of different types of events along a timeline, displays them in different ways as specified and allows you to click/hover along the timeline to add/modify/get details on events.
      I'm not sure if I should attempt to extend the flex advanced datagrid, or use one of the several vaguely similar component types I've found online (http://www.gantt4flex.com/, http://flexlib.googlecode.com/svn/trunk/docs/index.html?flexlib/scheduling/), or how best to approach, but I need to get this on its feet fairly quickly.
      Basically I want a timeline across the top, always showing a  24hour period, but starting at variable points.
      I need to have different rows of variable height to display different types of data in different ways.
      for instance
      - row 1 will display the 'value' attribute as a circle whose diameter reflects value amount and change color based on a 'typecode' attribute.
      - row 2 will display a line graph and plot chart based on different numbers, but will also chart out trend of following or previous data if it exists.
      - behind row 2 will display the same thing but for 5 previous days progressively more transparent
      -row 3 will display the number values from row 2
      -row 4 will display another type of data, this one with duration, as bar lines. you will be able to click with in this row once to set startpoint of new entry and once to set endpoint to create new entry. onclick..
      -row 4 will display color coded squares for a number of different datatypes and hovering will reveal details.
      all rows need to share the same timespan, and I'd like to be able to have click/hover events that target the data object/values of the data being displayed.
      I have a data model and can come up with whatever data I need no problem (working from sqlite). But I haven't built a component from scratch before and am wondering how to approach something like this.. how to break it down etc.. any advice is greatly appreciated
