2 Replies Latest reply on Apr 4, 2011 1:07 PM by saisri2k2
    CSS in Modules
    bidon47
      I work on a large Flex Project that includes now Modules.
      Just now there is a css-File in the Main Application.
      <mx:Application ...>
      <mx:Style source="css/main.css"/>
      </mx:Application
      In the CSS-File:
      Application{
      Panel{
      Button{
      The CSS-File is only referenced in the Main Application.
      When I add the Module to the Application I get some Warns:
      CSS type selectors are not supported in components: 'Application'
      CSS type selectors are not supported in components: 'Panel'
      CSS type selectors are not supported in components: 'Button'
      Since there are only warnings, you could just get the idea to ignore it.
      But all Compents in the Module with property label <mx:Button label"Adobe Flex"/>
      or the Label Componente with Property text  <mx:Label text="Adobe Flex"/>
      lose their value.
      After 1 day research I am now very confused about the StyleManager and find lot more information
      on Flex 4 then Flex 3.
      I have no solution found for Flex 3.
      Does anyone know a solution for this problem?
