1. Re: How do you change the FILE >"print code" resulting printed font size?
AllDayDev Apr 4, 2011 6:18 PM (in response to Jayperkins)If you change the size of the font for Code View in the Preferences, this change should be reflected when printing:
http://help.adobe.com/en_US/dreamweaver/cs/using/WScbb6b82af5544594822510a94ae8d65-7f70a.h tml
HTH
2. Re: How do you change the FILE >"print code" resulting printed font size?
Jayperkins Apr 4, 2011 7:55 PM (in response to AllDayDev)Thank you for responding. I agree, the documentation shows that changing the font size for screen should change the font size for print.
However, it doesn't on 11.0.3 running Mac OSX.
See screen shot:
Therefore, there must be another location that contains the code that sets the style for printing?
3. Re: How do you change the FILE >"print code" resulting printed font size?
AllDayDev Apr 4, 2011 8:33 PM (in response to Jayperkins)There are no other settings in Dreamweaver that would affect this.
The code on the right (in Print Preview) is clearly larger than the code on the left (Code View), which I can see clearly.
What are you trying to achieve? Do you want the code smaller? Bigger? The same?
Note that most Print Previews are not scaled accurately. That is, you can't reasonably compare what you see on the screen to it.
Also, many printers have options to "scale to fit paper" (or something to that effect) which is enabled by default. You might try finding and disabling this setting and see if that would affect your output.
HTH
4. Re: How do you change the FILE >"print code" resulting printed font size?
Jayperkins Apr 5, 2011 10:32 AM (in response to AllDayDev)Thanks again for your reply.
I would like the code print out font to be a smaller size. Currently, it ls printing at 12 pt Monaco ( I can emulate this exactly by printing the same document in an editor set as Monaco 12pt ). However, the settings (see below) are set at Monanco 9pt. This works on the screen, but not for printing.
http://goo.gl/eXhnz > screenshot of Setting show "smallest".
Yet the code:print gives me more characters per line, resulting in many more pages per printout. The "print preview" shown in my last message is exactly what the printed page looks like as well.
NOTE: with the same settings ("smallest Monaco 9pt), Dreamweaver CS3 on OSX *does* code:print the smaller size, though without color coding. Dreamweaver CS 5 on my system does not.
Thank you.
Jay
5. Re: How do you change the FILE >"print code" resulting printed font size?
brayer_fish Jul 7, 2011 5:50 PM (in response to Jayperkins)Hi Jay,
I just had the exact same problem on OSX with Dreamweaver CS 5.
Here's how I fixed it for my situation. You are correct, changing the font size for code view seems to leave the actual printed code untouched (in 12pt monaco --- huge). I went to File->Page Setup and actually scaled down the entire page (in my case I took it down to 50%, and when I printed the code, it worked --- reducing the code to 6pt).
I hope this helps you or someone else Googling for answers. Cheers!
6. Re: How do you change the FILE >"print code" resulting printed font size?
Lee12345 Dec 2, 2014 3:43 AM (in response to brayer_fish)Thanks, even after all this time this tip is still valid on Dreamweaver CC and has solved my issue of huge printed text!
