4 Replies Latest reply on Nov 11, 2013 12:10 AM by Yuliya Trifonoff
    Centering Text
    Xismo1
      Hi all,
      hope you can help me with my query, I'm sure it's pretty simple just suck at JS. I downloaded the AddFileNamePlus script and everything is working perfectly except I would like to have the text layer that gets created to be set as paragraph text taking up full width of the document and text inside centered. Below is the code that I'm currently using which just creates a regular text layer. If anyone knows how to do this it would be greatly appreciated!!
      Thanks.
      //Check if a document is open
      if ( documents.length > 0 )
      var originalRulerUnits = preferences.rulerUnits;
      preferences.rulerUnits = Units.PERCENT;
      try
      var docRef = activeDocument;
      // Create a text layer at the front
      var myLayerRef = docRef.artLayers.add();
      myLayerRef.kind = LayerKind.TEXT;
      myLayerRef.name = "Filename";
      var myTextRef = myLayerRef.textItem;
      //Set your parameters below this line
      //If you wish to show the file extension, change the n to y in the line below, if not use n.
      var ShowExtension = "n";
      // Insert any text to appear before the filename, such as your name and copyright info between the quotes.
      //If you do not want extra text, delete between the quotes (but leave the quotes in).
      var TextBefore = "";
      // Insert any text to appear after the filename between the quotes.
      var TextAfter = "";
      // Set font size in Points
      myTextRef.size = 12;
      //Set font - use GetFontName.js to get exact name
      myTextRef.font = "Arial-BoldMT";
      //Set text colour in RGB values
      var newColor = new SolidColor();
      newColor.rgb.red = 0;
      newColor.rgb.green = 0;
      newColor.rgb.blue = 0;
      myTextRef.color = newColor;
      // Set the position of the text - percentages from left first, then from top.
      myTextRef.position = new Array( 20, 98);
      // Set the Blend Mode of the Text Layer. The name must be in CAPITALS - ie change NORMAL to DIFFERENCE.
      myLayerRef.blendMode = BlendMode.NORMAL;
      // select opacity in percentage
      myLayerRef.opacity = 100;
      // The following code strips the extension and writes tha text layer. fname = file name only
      di=(docRef.name).indexOf(".");
      fname = (docRef.name).substr(0, di);
      //use extension if set
      if ( ShowExtension == "y" )
         fname = docRef.name
      myTextRef.contents = TextBefore + "  " + fname +  "  " + TextAfter;
      catch( e )
      // An error occurred. Restore ruler units, then propagate the error back
      // to the user
      preferences.rulerUnits = originalRulerUnits;
      throw e;
      // Everything went Ok. Restore ruler units
      else
      alert( "You must have a document open to add the filename!" );
        • 1. Re: Centering Text
          c.pfaffenbichler Level 9
          Could you give this a try?
          Instead of percent it sets the rulerUnits to pixels and temporarily resizes the image to 72ppi.
          #target photoshop
          preferences.rulerUnits = Units.PIXELS;
          var originalResolution = app.activeDocument.resolution;
          try
          docRef.resizeImage (undefined, undefined, 72, ResampleMethod.NONE);
          var TextAfter = "";
          myTextRef.size = 12 * originalResolution / 72;
          // Set the position of the text.
          myTextRef.justification = Justification.CENTER;
          myTextRef.kind = TextType.PARAGRAPHTEXT;
          myTextRef.width = docRef.width;
          myTextRef.height = docRef.height / 5;
          myTextRef.position = [0, docRef.height * 0.95  ];
             fname = docRef.name
          catch( e )
          // to the user
          docRef.resizeImage (undefined, undefined, originalResolution, ResampleMethod.NONE);
          throw e;
          else
          • 2. Re: Centering Text
            Xismo1 Level 1
            That is absolutely wonderful! Works like a charm, thanks!
            Just wondering if you know why when the text layer is created there are two empty spaces before and after the text. Also if I ever need to increase the height of the created paragraph text so I can fit say two or three lines instead of one what would I have to modify? I saw you are dividing the height by 5 which I don't quite understand. And finally where do you set the temporary ppi change? Wanna know because in the future I will try to create a script that does automated image resizing as well as inclusion of the filename and images will always have to be at 72 ppi. Sorry for all the questions just trying to understand a bit more. I really need to start learning JS after seeing just how much is possible with scripts in PS =)
            • 3. Re: Centering Text
              The fifth of the document’s height was arbitrary, to fit more text you should correct these settings:
              and back to the original resolution
              • 4. Re: Centering Text
                Yuliya Trifonoff
                How can I add to this script to show too the Creation Date and Time of my picture?
                I have not problem to show current date and time but I'd like Creation Date and Time.
