3 Replies Latest reply on Apr 5, 2011 5:53 AM by HenrySeng-CH
    selectable ranges in datechooser from database
    Gilgeam
      Hi guys!
      I got a problem, I'm trying to set ranges in a datechooser. The code I use is this:
      <mx:DateChooser horizontalCenter="0" bottom="0" top="0" width="75%" id="calendario_desde"  creationComplete="fecha_desde_inicio()"/>
      protected function fecha_desde_inicio():void
      fecha_desde.token =  database.fecha_desde();
      anio= fecha_desde.lastResult.valor1;
      mes = fecha_desde.lastResult.valor2;
      dia = fecha_desde.lastResult.valor3;
      dRanges.push({rangeStart:new Date(anio,mes,dia), rangeEnd: new Date (2011,2,1)});
      calendario_desde.selectableRange = dRanges;
      Could you tell me what's wrong?
        • 1. Re: selectable ranges in datechooser from database
          HenrySeng-CH Level 1
          DateChooser.selectableRange accepts an object having startRange and endRange properties. In your version, you give it an array! containing an object containing the 2 properties
          try this:
               var range:Object = new Object();
               range.rangeStart = new Date(anio,mes,dia);
               range.rangeEnd = new Date (2011,2,1);
               calendario_desde.selectableRange = range;
          or this :
               calendario_desde.selectableRange = {rangeStart : new Date(anio,mes,dia), rangeEnd : new Date(2011,2,1)};
          • 2. Re: selectable ranges in datechooser from database
            Gilgeam Level 1
            Thanks a lot!
            But I still got a small problem. I want to set ranges at start and when I use this code on creationcomplete event it doesn't work.
            how can i do it?
            • 3. Re: selectable ranges in datechooser from database
              what happens? isn't a problem with your data?
