• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Multiple Join Question
Participant ,
Jun 18, 2008 Jun 18, 2008
Hello,
I am trying to pull information out of a database using joins. It doesn't seem to be working. I get no results. Here is how my tables are set up and what I am trying to join. I get no results whatsoever displayed, but no errors. I want to show the "compname" and then the teams involved.
Table: team Fields: id, captain, teamname,
Table: teamchallenges Fields: id, compname, team1, team2, team3, team4, team5
The id in the table "team" is relational in the "team1, team2, team3, team4, team5" fields of "teamchallenges" to determine more information to be pulled. So here is my query:
<cfquery name="qcomp" datasource="mydb">
SELECT * FROM teamchallenges a
INNER JOIN
team b ON a.team1 = b.id
INNER JOIN
team c ON a.team2 = c.id
INNER JOIN
team d ON a.team3 = d.id
INNER JOIN
team e ON a.team4 = e.id
INNER JOIN
team f ON a.team5 = f.id
</cfquery>
And my output:
<cfoutput query="qcomp">
<tr>
<td valign="top">#compname#</td>
<td valign="top">
#teamname#,
<cfif team2 NEQ "">#teamname#,</cfif>
<cfif team3 NEQ "">#teamname#,</cfif>
<cfif team4 NEQ "">#teamname#,</cfif>
<cfif team5 NEQ "">#teamname#,</cfif>
<cfif team6 NEQ "">#teamname#,</cfif>
<cfif team7 NEQ "">#teamname#,</cfif>
<cfif team8 NEQ "">#teamname#,</cfif>
<cfif team9 NEQ "">#teamname#,</cfif>
<cfif team10 NEQ "">#teamname#,</cfif></td>
</tr>
</cfoutput>
TOPICS
Advanced techniques
Views
519
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
I can never remember (because I rarely use them) which it is, but I think you need to use LEFT INNER JOIN or RIGHT INNER JOIN because any columns that do not have the data will prevent all associated items in other tables from displaying.
Votes
Translate
Translate
Report
Report
LEGEND ,
How many records does your query return?
Votes
Translate
Translate
Report
Report
Participant ,
Jun 19, 2008 Jun 19, 2008
My query should return 5 rows of data. Right now my results show nothing.
Votes
Translate
Translate
Report
Report
LEGEND ,
quote:
The question was not, "What do your results show?". It was, "How many records did your query return?"
Votes
Translate
Translate
Report
Report
Mentor ,
First off, you have a really BAD data model. Team1, team2, team3..... yuck. What happens if you need to add a team6, etc.? Also, joining them like you did means that you will only return rows that contain values for ALL teams at the same time. If you have any control over your data model, you should migrate your teams out of challenges and into an associative entity, since I am assuming that challenges and teams is a many to many relationship. Then you can link all three tables easily in a query to display whatever attributes you need.
Phi
Votes
Translate
Translate
Report
Report
Participant ,
Jun 20, 2008 Jun 20, 2008
INNER JOIN will only extract rows where the values being joined are common to each table. I think you need to see more about the join statements: INNER JOIN, LEFT OUTER JOIN, RIGHT OUTER JOIN, FULL OUTER JOIN. And just like paross1 said, you really need to change your data model.
Votes
Translate
Translate
Report
Report
Participant ,
Jun 23, 2008 Jun 23, 2008
I'm not sure why the data model is bad. I have a table with "team" information then a table for "team challenge" information showing who will be competing against who. I am limiting the challenges to only 10 teams, that is why I used #team1#, #team2# etc. The problem is that inputs the #id# of the team from the "team" table for #team1#, #team2# etc. So I try to join the two tables to pull out the #teamname# instead of id numbers.
I have the query working pulling out the correct id numbers for team1, team2, etc. I just need to find a way to pull their teamname in from the "team" table according to their #id# that was put into the "teamchallenges" table under #team1#, #team2# etc.
Here is what I'm using:
SELECT * FROM team a
INNER JOIN
teamchallenges b ON a.id = b.sentby
</cfquery>
<tr>
<td valign="top"><strong>Competition Name</strong></td>
<td valign="top"><strong>Teams Involved</strong></td>
</tr>
<tr>
<td valign="top">
#team1#, #team2#, #team3#, #team4#, #team5#,
</td>
</tr>
This works in the following output:
Competition Name Teams Involved
Team Smooch and Co 9, 7, , , ,
The Thrilla in Manilla 7, 1, 5, , ,
Votes
Translate
Translate
Report
Report
Mentor ,
Well, you are seeing symptoms of why it is bad, that being the fact that it isn't easy to write a query with a simple join to get the team names. Lets say that instead of having seperate columns for each team in the teamchallenges table that you instead have an intermediate table named challenges2team where you had only 2 columns named teamID and challengeID. Then your teamchallenges table would only contain information directly related to challenges, such as id, compname, and your challenges2team would contain a row for every matching teamID and challengeID.
So, for example, lets say that you have challengeID = 1, and three teams associated with that challenge with teamID values of 1, 3, and 5. Your challenges2team table would contain 3 rows with challengeID = 1, one for each matching TeamID. In order to see what challenges were associated with which team, you could do this:
SELECT t.teamname,
c.id,
c.compname
FROM team t
INNER JOIN challenges2team ct ON t.id = ct.teamID
INNER JOIN teamchallenges c ON c.id = ct.challengeID
WHERE c.id = 1
Your output would be three rows for the three teams associated with that challenge.
.. and there you are.
Phil
Votes
Translate
Translate
Report
Report
Mentor ,
...or perhaps something like this:
SELECT id, compname, teamname
FROM (SELECT c.id, c.compname, t.teamname
FROM teamchallenges c
INNER JOIN team t ON t.id = c.team1
UNION
INNER JOIN team t ON t.id = c.team2
UNION
INNER JOIN team t ON t.id = c.team3
UNION
INNER JOIN team t ON t.id = c.team4
UNION
INNER JOIN team t ON t.id = c.team5
UNION
INNER JOIN team t ON t.id = c.team6
UNION
INNER JOIN team t ON t.id = c.team7
UNION
INNER JOIN team t ON t.id = c.team8
UNION
INNER JOIN team t ON t.id = c.team9
UNION
INNER JOIN team t ON t.id = c.team10)
GROUP BY challenge_id, compname, teamname
ORDER BY challenge_id
Phil
Votes
Translate
Translate
Report
Report
Participant ,
LATEST
Phil,
That did exactly what I was trying to do. Thank you so very very much! I understand what you meant in the previous post and I will take that into consideration as well.
Votes
Translate
Translate
Report
Report
Resources
Documentation
