1 Reply Latest reply: Apr 5, 2011 12:36 PM by Omke Oudeman RSS
    Bridge CS5 Collection is seeing deleted items
    Jd_Johnson8 Community Member
      I have some done some housekeeping of about 75 to 100 folders recently.  I now want to create some contact sheets from a collection using the images from these folders now that i have eliminated the duplicate images/multiple exposures that i don't need anymore.  however, i had previously created a collection using these folders, and the collection is still seeing all of those items that have been deleted.  i have deleted the collection and tried recreating it to no avail... i am not sure how this is possible, but any help anyone can give me will be greatly appreciated!
      JD
        • 1. Re: Bridge CS5 Collection is seeing deleted items
          Omke Oudeman Community Member
          For that you only need to select the new files in the content window, choose
          new collection and after this from other folders repeat it, just as the
          first time you created that files. If that is not possible then there is
          something wrong with your install.
          Assuming with eliminating duplicates etc you have done so in the content
          window for the original folders and not from the collection content window
          itself? You should be careful with that because removing from collection by
          using the button top right of the collection content window does remove the
          files from the collection but not from the disk, however the normal way to
          delete is using the backspace and when in the collection window that is
          deleting also the original file without warning from your disk!
          This indicates also you have a problem with your  Bridge install. Normally
          deleting files from the folders the also delete from the collection, be sure
          you have deleted them to the trash, if you have put them in an other folder
          the collection keeps track of the new location.
          As said above, that should not be a problem, if so first aid for Bridge is
          restart it while holding down option key and from the pop up menu choose
          reset preferences. Try again and if it works set the prefs again to your
          wishes.
