1 Reply Latest reply on Apr 5, 2011 10:12 PM by mytaxsite.co.uk
    Customize scrollbar?
    MayerReed Level 1
      I created a DIV tag in my html page that is set to show a scrollbar if the text overruns the box area. I was wondering if it is possible to customize the appearance of that scrollbar?  I notice there are several scrollbar-related properties in the list of CSS commands that comes up when I click on 'Add Property" in the CSS panel, but can't find any documentation that says what they do, and when I tried experimenting with them, I could see no changes to my scrollbars.
        • 1. Re: Customize scrollbar?
          mytaxsite.co.uk Level 6
          The main properties you need to know are as follows:
          visible     --- The overflow is not clipped. It renders outside the element's box. This is default
          hidden     --- The overflow is clipped, and the rest of the content will be invisible
          scroll     --- The overflow is clipped, but a scroll-bar is added to see the rest of the content
          auto     --- If overflow is clipped, a scroll-bar should be added to see the rest of the content
          inherit     --- Specifies that the value of the overflow property should be inherited from the parent element
          And your css code may look something like this:
          .my_box
          width:200px;
          height:200px;
          overflow:scroll;
          Hope this gives you a start.
