4 Replies Latest reply on Jun 8, 2007 6:24 AM by Newsgroup_User
    batch process
    DannyK040592
      I'm using Fireworks MX 2004. I want to do a 'batch process' to create thumbnails. When I get to the last screen, 'batch' is grayed out -- only 'back' and 'cancel' are avaiable. I'll go through the steps I'm taking and maybe something will jump out at you:
      click 'file' then 'batch process';
      navigate to the folder with the images, then select the images I want the batch process to be applied to and click 'next';
      add scale, export and rename to the panel on the right;
      set options for scale to 150 px x variable;
      set options for export (jpg, quality = 50);
      set options for rename (prefix = sm_);
      click next;
      select custom location, browse to the folder where I want them saved and select that folder;
      select backup, overwrite existing backups;
      save script as thumbnail.jsf;
      'batch' is grayed out, back and cancel are the only available options.
      Any input is greatly appreciated.
      Thank you!
        • 1. Re: batch process
          Level 7
          I'm using FWs 8 but apart from that I followed your steps to the letter
          (apart from selecting Export Settings of JPEG - Smaller File) and it worked
          fine.
          Peter
          ___________________
          "DannyK040592" <webforumsuser@macromedia.com> wrote in message
          news:f4afb0$b2i$1@forums.macromedia.com...
          and
          | click next;
          | select that folder;
          | Thank you!
          • 2. Re: batch process
            Level 7
            > click next;
            > select that folder;
            > Thank you!
            I think it has changed with the newer version but, FW used to be picky
            about actually using the 'Add Files' button when selecting the images.
            Only thing I can think of.
            SKB
            • 3. Re: batch process
              DannyK040592 Level 1
              > click next;
              > select that folder;
              > Thank you!
              SKB
              SKB -- good eye!! I was selecting the files and clicking 'next'. I just now did 'add all', (I did a 'remove' for a handfull because their orientation was 90 degrees different than the bulk of the images -- I'll go back and batch process them by changing the resize to variable x 150) and it went as slick as can be. What a time saver!!!
              Thank you for your response to my question, SKB!
              • 4. Re: batch process
                Level 7
                > > click next;
                > > select that folder;
                > > Thank you!
                > SKB
                The reason FW doesn't force you to add images is so you can create just
                the batch operation and save it as a command, allowing you to run the
                entire process on any images at any time without having to select all
                the settings again.
                Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
                Extending Knowledge, Daily
                http://www.communityMX.com/
                CommunityMX - Free Resources:
                http://www.communitymx.com/free.cfm
                .:Adobe Community Expert for Fireworks:.
                news://forums.macromedia.com/macromedia.fireworks
                news://forums.macromedia.com/macromedia.dreamweaver
