0 Replies Latest reply on Apr 5, 2011 11:46 PM by connectpp
    Getting height, width of component in different state
    connectpp
      I have a collapsible component that extends Panel. Also i have a skin file that implements skin for this component.
      skin file has 2 states, collapsed and expanded. I use transitions to set width to the hostComponent.
      When the component is initially in expanded state I use a custom property collapsedWidth to set widthTo property for resize effect in transition. This works fine.
      But when component is initially in collapsed state i want the value of widthTo property to be set depending on the contents in expanded state. currently i have variable expandedWidth and using this variable it works fine but i want to get rid of expandedWidth variable and feel that the width in expanded state should be calculated as per the contents in expanded state. how can i get the width in expanded state when i am in collapsed state.
      <s:states>
            <s:State name="normal"/>
            <s:State name="collapsed"/>
      </s:states>
      <s:transitions>
            <s:Transition fromState="*" toState="collapsed">
               <mx:Parallel duration="250" target="{hostComponent}">
                  <mx:Resize widthTo="{hostComponent.collapsedWidth }"/>
               </mx:Parallel>
            </s:Transition>
            <s:Transition fromState="*" toState="normal">
                  <mx:Resize widthTo="{hostComponent.expandedWidth}"/>
                  <s:Fade alphaFrom="0" alphaTo="1"/>
               </mx:Parallel>
            </s:Transition>
      </s:transitions>
      My basic requirement is to remove collapsedWidth and expandedWidth.
