15 Replies Latest reply on Jun 14, 2007 6:29 AM by kimsue02
    Can't see Photoshop slices in Fireworks
    kimsue02
      HI - I just purchased Fireworks b/c of the lack of ImageReady. Anyway - when I open a PSD file that already has slices in Fireworks none of the slices are there. Am I missing something? How can I get the slices to import also?
      Thanks!
      Kim
        • 1. Re: Can't see Photoshop slices in Fireworks
          Level 7
          Add the slices in Fireworks instead.
          Linda Rathgeber [PVII] *Adobe Community Expert-Fireworks*
          http://www.projectseven.com
          Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
          CSS Newsgroup: news://forums.projectseven.com/css/
          http://www.adobe.com/communities/experts/
          • 2. Re: Can't see Photoshop slices in Fireworks
            Level 7
            > Thanks!
            > Kim
            I believe ImageReady and Fireworks handled slices differently, and that
            type of integration didn't make it into the latest version of FW,
            unfortunately. Nor for that matter, was the ability for Photoshop to
            export PSD's as native Fireworks PNG files.
            If you are only exporting the image slices for your site, you can still
            do this through Photoshop by going to FILE > SAVE FOR WEB AND DEVICES.
            FW's compression engine is a bit better than PS/IR, but that is the only
            real difference. Keep in mind too, you can still edit the file within
            PS. Most of IR's functionality for slicing was built into PS.
            If you need to edit the file and wish to do so in FW, as Linda said, you
            will have to redraw them in FW. If you want to match the slices as
            closely as possible, you can either do a screen grab of the slice layer
            in PS and bring it into FW for a reference, or make notes of slice
            positions and sizes in PS and then redraw them in FW. Neither of these
            is a great solution, I realize, but at least it can be done.
            Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
            Extending Knowledge, Daily
            http://www.communityMX.com/
            CommunityMX - Free Resources:
            http://www.communitymx.com/free.cfm
            .:Adobe Community Expert for Fireworks:.
            news://forums.macromedia.com/macromedia.fireworks
            news://forums.macromedia.com/macromedia.dreamweaver
            • 3. Re: Can't see Photoshop slices in Fireworks
              Level 7
              It's better to learn to do the slicing in Fireworks. :-)
              • 4. Re: Can't see Photoshop slices in Fireworks
                Level 7
                >> you will have to redraw them in FW. If you want to match the slices
                >> as closely as possible, you can either do a screen grab of the slice
                >> layer in PS and bring it into FW for a reference, or make notes of
                >> slice positions and sizes in PS and then redraw them in FW. Neither of
                >> these is a great solution, I realize, but at least it can be done.
                I agree :-)
                • 5. Re: Can't see Photoshop slices in Fireworks
                  kimsue02 Level 1
                  I know how to create slices in FW but I have all these old PSD files with a lot of slices in them already. So you're telling me there's no way to open these PSD files including the slices in FW? The slices get lost?
                  • 6. Re: Can't see Photoshop slices in Fireworks
                    Level 7
                    kimsue02 wrote:
                    > Hi,
                    Yes. Each graphics program has their own way of creating slices in a
                    document. As far as I'm aware, none of them can use the slice data
                    generated by the others.
                    • 7. Re: Can't see Photoshop slices in Fireworks
                      kimsue02 Level 1
                      ImageReady used to be able to - such a shame that's gone. This was one of the reasons I purchased FW.
                      • 8. Re: Can't see Photoshop slices in Fireworks
                        Level 7
                        Used to be able to do what, Kim?
                        • 9. Re: Can't see Photoshop slices in Fireworks
                          kimsue02 Level 1
                          See the slices I created in a Photoshop file. Image Ready was great for creating and editing slices. Once they got rid of it I was told FW was the program to use but it seems pointless, for my needs, if FW doesn't see the PSD slices.
                          • 10. Re: Can't see Photoshop slices in Fireworks
                            Level 7
                            > slices.
                            Fireworks is the program to use to create the slices and export them.
                            The workflow between Photoshop and Fireworks is somewhat different than
                            the workflow between Photoshop and Image Ready.
                            • 11. Re: Can't see Photoshop slices in Fireworks
                              Level 7
                              > slices.
                              Photoshop could see, and edit slices from IR because PS was using IR's
                              Engine to do that work in the first place.
                              Now we have a dedicated app for screen and web graphics, without the
                              limitations of IR. FW does a lot more than IR ever did and as mentioned,
                              and while the workflow may be different than PS, but (IMO anyway) it is
                              a more practical workflow. you'll find that you can do more in FW
                              without having to move from application to application. If you want to
                              work in the PS workflow, you can do most of what IR did within PS. But
                              FW is the way to go with new designs.
                              It all comes down to how you want to work.
                              • 12. Re: Can't see Photoshop slices in Fireworks
                                kimsue02 Level 1
                                Is there any program that has a work flow with Photoshop the way ImageReady used to have?
                                • 13. Re: Can't see Photoshop slices in Fireworks
                                  Level 7
                                  Not that I know of, not one that is integrated as IR was. Seriously,
                                  spend some time working with FW. It will be worth it.
                                  • 14. Re: Can't see Photoshop slices in Fireworks
                                    kimsue02 Level 1
                                    I've been playing around with FW a bit. I do need to go back and forth to Photoshop. So I save the FW file as a PSD and then edit what I have to in PS. When I go back to FW I import the PSD file - is this the correct way to do this? But what happens is it brings in all the layers all over again and I have to delete the duplicate previous layers, doesn't seen like the most efficient way to work between the two programs.
                                    Thanks.
                                    • 15. Re: Can't see Photoshop slices in Fireworks
                                      kimsue02 Level 1
                                      Actually, I just realized, I created the slices in FW and saved the file as a PSD. I then opened this PSD file and edited it in Photoshop and I went back to FW, the slices are gone! Is there anyway of creating slices in FW, open this file in Photoshop and add more layers or whatever, re-open this file in FW and have the slices still be there?
