4 Replies Latest reply on Jul 18, 2011 9:06 PM by RaniKumar
    SWC Load Error - Design Mode Problem
    paatfv10
      I'm loading custom .swcs into my Flash Builder (4.5 Burrito) project and I get these errors. These will only appear in design mode (not in source mode) and will not be labelled under the Problems tab, rather the Design Mode Problems tab:
      SWC Load Error
      SWC file failed to load. Any component dependent on this SWC file will not be displayed in the Design Mode.
      The SWC may have failed to load because of:
      *  Incompatible definitions caused by usage of a different SDK version
      *  Missing referred class definitions
      I don't think this problem is caused by an SDK incompatibility, as all these swcs have been created under flex 4 and I'm pretty sure under the 4.5 SDK.
      Loading the components contained in these swcs onto my canvas (at design time) will work fine. I'm able to build and run the application without any errors caught by flash builder.
      Any idea how to fix this problem, or what it means?
        • 1. Re: SWC Load Error - Design Mode Problem
          See4th Level 1
          Just bought FlashBuilder 4.5.1 and having the same problem here. My custom mobile skins library depends on:
          C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.5\sdks\4.5.0\frameworks\themes\Mobile\mobile.swc
          I had to switch my project SDK from 4.5.1 to 4.5 to fix it. Sounds like a bug.
          Jeff
          • 2. Re: SWC Load Error - Design Mode Problem
            fruto da terra
            pagamentos de boletos para forncedor
            • 3. Re: SWC Load Error - Design Mode Problem
              fruto da terra Level 1
              numero de contas de  corentista do banco safra do banco do brasil banco itau enprezarial banco santander do brasil unibanco com senha para efetuar pagamentos de boletos e efetuar ted e trasferencias
              • 4. Re: SWC Load Error - Design Mode Problem
                RaniKumar
                SWC Load error indicates that the swc used does not match with the definitions present in design view or with what is present in already loaded other lirbaries.  The issue is reported by the flash loader.  It looks like that, your swc is compiled with a previous version of the sdk and the design view and the related definition correpsonds to another version.
                The incompatability logic is not in DV.  When DV tries to load all the swc details available in the project, the loading fails as the loader reports the issue. There is hardly anything, we can do here from DV.  If the player reports the incompatability issue, the loader is corrupted and all further loading is ignored. So to avoid such issue, DV ignores the failed swc's and tries to proceed.
                If you pass me the swc , I can give the details of the incompatability. Ideally between 4.5 and 4.5.1 there should not have been any incompatability.  However your case shows there is.  You can contact me at ranik@adobe.com
