3 Replies Latest reply on Oct 31, 2011 8:59 AM by RusstheEdit
    AAF Import From Avid MC 5.5.1 Causes PPro to Crash
    lbsimpson Level 1
      Hi all,
      We are in the process of dumping our Avid system and switching to primarily Adobe production.  This feature came to my attention:
      http://tv.adobe.com/watch/adobe-presentations-2009/open-workflows-between-avid-and-adobe-c s4-production-premium#transcription-request
      And I thought it would be a great solution to the daunting task of getting our media out of Avid MXF and stored in a user-defined manner.  I was able to succesfully export a DV 25 MXF based sequence in Avid to an AAF file.  I was able to get it imported into Premiere and view the clips and sequence in the browser window.  I was even able to open the sequence created by the AAF in PPro thought it did not include any video tracks.  When I drag, drop clips from the AAF import they do open in the sequence with video and audio.  I tried exporting a short DV clip to Quicktime and AVI and was able to get as far as AME, but after clicking 'Export' it was only a few moments before PPro crashed.  IF it can't handle DV clips, I'm not sure how to go about our HD files, might need some 3rd party software after all.
      We are currently running MC 5.5 and PPro CS5 on the same tower as we only currenly have access to capture or dump to tape through Avid based on our Avid specific Nitirs DX A/D breakout box.  (we are looking at options for a PPro compatible breakoutbox, but interim will need to capture/dump through MC).  Perhaps having the two software apps on tehs ame tower is bogging things down?  Only PPro is running and oepn when I've tried these exports,etc.
      Thanks for any input,
      Lindsay
        • 1. Re: AAF Import From Avid MC 5.5.1 Causes PPro to Crash
          lbsimpson Level 1
          Hmm...considering the lack of response here and a few Avid forum threads I've come across like this...
          http://community.avid.com/forums/p/92218/547545.aspx#547545
          ...it seems as though the AAF between Avid/PPro is a great idea in theory but not at all funcitonal!
          I am having the exact same issue with AAF Avid>PP.  Currently I am  running MC 5.5.1 and CS5 PPro.  THe AAF imports from Avid just fine  into PPro, but when I open the folder, audio and video are two different  files with the video always offline(with HD media).  I also tried to relink to the MXF  and PPro indicates that the MXF file is an invalid media type.
          I also tried an AAF with the "copy" option and tried a couple of  transcode formats incluidng DVCPro HD MXF for my P2 media specifically.
          I have tried the AAF with Ikegami Long GOP media, P2 and DV media.   DV media is the only thing that opens in PPro with audio and video, but  if drag a clip into a new sequence or open the Avid exported sequence,  PPro crashes immediately with no other applications running in the  background...
          I've got 4 TB worth of Avid MXF filest aht I need to access in PPro.   Has anyone solved or come up with a work around for this issue without purchasing a third party app?  Though if 3rd party is needed Automatic  Duck was mentioned as a good tool to get media into AE but does it work  for PPro too?
          Lindsay
          • 2. Re: AAF Import From Avid MC 5.5.1 Causes PPro to Crash
            Simon Coldricik
            I'm not having any issue with crashing but I have an issue with this broad claim
            Exchange projects easily
            Adobe Premiere Pro CS5 can import Avid sequences that have been saved as AAF files, and you can also
            export Adobe Premiere Pro sequences as Avid AAF sequences, for a round-trip workflow. This means
            you can share media files and sequence information without conversion or rendering, while preserving
            commonly used effects and transitions. In most cases, there is no relinking of media and a translation
            report added to the project’s main bin provides information about any approximations that have been
            made during the conversion. Similarly, you can also import and export Apple Final Cut pro sequences
            using XML.
            Having spent ages trying to move DNxHD files between applications it seems that AAF import only works with DV footage. I think Adobe needs to be a little more honest with their marketing spin, pinging dv files bewteen apps is not how I imagine most editors would use this round-trip process. This has halted my purchase of Production Premium in its tracks. Any idea when AAF Import will include other Avid MFX media file formats ?
            • 3. Re: AAF Import From Avid MC 5.5.1 Causes PPro to Crash
              RusstheEdit Level 1
              Thought I'd give this a bump.
              I'm currently trying to get a project from Avid Media composer 5.5 to PPro CS5.0.4 on MACpro tower.
              II've followed the video tutorial here http://tv.adobe.com/watch/moving-to-adobe-premiere-pro-/importing-an-avid-project/ but as soon as PPro starts to import, but after a few seconds just crashes out shutting PPro down.
              The original footage was all ingested with PPro from DVcam to movs and then the edit was done in AVID (freelance editor couldnt use PPRO!) using AMA to link to the files.
              anybody any wiser about this?
              for any Adobe bods reading this here's the crash log.
              Process:         Adobe Premiere Pro CS5 [514]
              Path:            /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/MacOS/Adobe Premiere Pro CS5
              Identifier:      com.adobe.AdobePremierePro
              Version:         5.0.4 (5.0.4)
              Code Type:       X86-64 (Native)
              Parent Process:  launchd [163]
              Date/Time:       2011-10-31 15:46:04.486 +0000
              OS Version:      Mac OS X 10.7.2 (11C74)
              Report Version:  9
              Interval Since Last Report:          412940 sec
              Crashes Since Last Report:           4
              Per-App Interval Since Last Report:  6372 sec
              Per-App Crashes Since Last Report:   4
              Anonymous UUID:                      FA503F44-280A-48E1-90C1-F1874174478F
              Crashed Thread:  69
              Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
              Exception Codes: KERN_INVALID_ADDRESS at 0x00000000000801f4
              VM Regions Near 0x801f4:
                  __TEXT                 0000000100000000-0000000100004000 [   16K] r-x/rwx SM=COW  /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/MacOS/Adobe Premiere Pro CS5
              Application Specific Information:
              objc[514]: garbage collection is OFF
              Thread 0:: Dispatch queue: com.apple.main-thread
              0   libsystem_kernel.dylib                  0x00007fff8f2d367a mach_msg_trap + 10
              1   libsystem_kernel.dylib                  0x00007fff8f2d2d71 mach_msg + 73
              2   com.apple.CoreFoundation                0x00007fff9288bb6c __CFRunLoopServiceMachPort + 188
              3   com.apple.CoreFoundation                0x00007fff928942d4 __CFRunLoopRun + 1204
              4   com.apple.CoreFoundation                0x00007fff92893ae6 CFRunLoopRunSpecific + 230
              5   com.apple.HIToolbox                     0x00007fff9039f3d3 RunCurrentEventLoopInMode + 277
              6   com.apple.HIToolbox                     0x00007fff903a663d ReceiveNextEventCommon + 355
              7   com.apple.HIToolbox                     0x00007fff903a64ca BlockUntilNextEventMatchingListInMode + 62
              8   com.apple.AppKit                        0x00007fff86d053f1 _DPSNextEvent + 659
              9   com.apple.AppKit                        0x00007fff86d04cf5 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 135
              10  com.adobe.dvaui.framework               0x0000000102e87123 dvaui::ui::OS_Dialog::WaitForNextEvent() + 163
              11  com.adobe.dvaui.framework               0x0000000102e8894b dvaui::ui::OS_Dialog::ModalLoop() + 75
              12  com.adobe.dvaui.framework               0x0000000102e886f3 dvaui::ui::OS_Dialog::RunModal() + 195
              13  com.adobe.dvaeve.framework              0x0000000106733c09 dvaeve::UI_EveManager::DisplayView(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::istream&, dvaui::drawbot::SupplierInterface const*, dvaui::ui::UI_Node*) + 1785
              14  com.adobe.dvaeve.framework              0x000000010672fdf1 dvaeve::UI_Eve::ParseEveScript(std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >&) + 1169
              15  com.adobe.premiere.dialogs              0x00000001072a6de0 DLG::ProgressDialog::DoProgressDialog(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, ASL::InterfaceRef<ASL::IBatchOperation, ASL::IBatchOperation>, char const*) + 1872
              16  com.adobe.premiere.dialogs              0x00000001070f330a DLG::HandleAAFProgressDialog(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, ASL::InterfaceRef<ASL::ASLUnknown, ASL::ASLUnknown>, dvaui::drawbot::SupplierInterface const*, dvaui::ui::UI_Node*) + 202
              17  com.adobe.premiere.dialogs              0x000000010718d888 DLG::DispatchDialog(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, ASL::InterfaceRef<ASL::ASLUnknown, ASL::ASLUnknown>, dvaui::drawbot::SupplierInterface const*, dvaui::ui::UI_Node*) + 1336
              18  com.adobe.premiere.hsl                  0x0000000106e6ec38 HSL::HostDialogDispatcher::OnCreateNamedDialog(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, ASL::InterfaceRef<ASL::ASLUnknown, ASL::ASLUnknown>) + 264
              19  com.adobe.premiere.hsl                  0x0000000106e6f088 HSL::HostDialogDispatcher::ListenToMessage(ASL::Message const&) + 136
              20  ASLMessaging                            0x000000010059327c ASL::Broadcaster::BroadcastMessage(ASL::Message const&) + 1484
              21  ASLMessaging                            0x000000010059e721 ASL::StationUtils::BroadcastMessage(ASL::ImmutableString const&, ASL::Message const&) + 65
              22  com.adobe.MediaCore.Frameworks.SweetPeaSupport          0x00000001028f193c ML::SDKCallback_CreateNamedDialog(char const*, void*) + 268
              23  com.adobe.premiere.AAFProjectConverter          0x000000011ae91d52 PremAAF::(anonymous namespace)::RunDialog(SPBasicSuite*, char const*, void*, ASL::ImmutableString const&) + 274
              24  com.adobe.premiere.AAFProjectConverter          0x000000011ae93c61 PremAAF::Dialogs::DoImportDialog(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 353
              25  com.adobe.premiere.AAFProjectConverter          0x000000011af714a0 ConvertProjectToPremiere(ProjectOpenSaveRec*) + 544
              26  com.adobe.MediaCore.Frameworks.ProjectConverterHost          0x00000001042f17e6 ML::ProjectConverterModule::CallProjectConverter(unsigned int, void*) + 198
              27  com.adobe.MediaCore.Frameworks.ProjectConverterHost          0x00000001042eb886 ML::ProjectConverter::CallOpenSave(bool, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >&) + 406
              28  com.adobe.Mezzanine                     0x0000000105769427 MZ::CallOpenProjectConverter(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >&) + 311
              29  com.adobe.Mezzanine                     0x0000000105777c2f MZ::ImportOneFile(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool, MZ::MediaParams const&, ASL::InterfaceRef<BE::IProjectLoadStatus, BE::IProjectLoadStatus>, ASL::InterfaceRef<BE::IProgress, BE::IProgress>, std::vector<ASL::InterfaceRef<BE::IProjectItem, BE::IProjectItem>, std::allocator<ASL::InterfaceRef<BE::IProjectItem, BE::IProjectItem> > >&, std::vector<std::pair<int, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, std::allocator<std::pair<int, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, bool, MZ::ImportFromEDLDialog*, bool, MZ::ImportNewSequenceMediaParamsDialog*) + 4623
              30  com.adobe.Mezzanine                     0x000000010578868e MZ::(anonymous namespace)::ImportFilesOperation::OnImportFile(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, ASL::ObjectPtr<std::vector<ASL::InterfaceRef<BE::IProjectItem, BE::IProjectItem>, std::allocator<ASL::InterfaceRef<BE::IProjectItem, BE::IProjectItem> > >, ASL::AtomicValue>) + 158
              31  com.adobe.Mezzanine                     0x00000001057895de MZ::(anonymous namespace)::ImportFilesOperation::ListenToMessage(ASL::Message const&) + 494
              32  ASLMessaging                            0x000000010059327c ASL::Broadcaster::BroadcastMessage(ASL::Message const&) + 1484
              33  ASLMessaging                            0x000000010059e721 ASL::StationUtils::BroadcastMessage(ASL::ImmutableString const&, ASL::Message const&) + 65
              34  com.adobe.dvacore.framework             0x0000000100127ebe boost::function0<void>::operator()() const + 46
              35  com.adobe.dvacore.framework             0x00000001001864fa dvacore::threads::(anonymous namespace)::FunctionQueue::ExecuteOneFunction(bool) + 858
              36  com.adobe.dvacore.framework             0x0000000100127ebe boost::function0<void>::operator()() const + 46
              37  com.adobe.dvacore.framework             0x00000001001869eb dvacore::threads::(anonymous namespace)::RunLoopAdaptor::Execute(__CFRunLoopTimer*, void*) + 27
              38  com.apple.CoreFoundation                0x00007fff928b3f84 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
              39  com.apple.CoreFoundation                0x00007fff928b3ad6 __CFRunLoopDoTimer + 534
              40  com.apple.CoreFoundation                0x00007fff92894471 __CFRunLoopRun + 1617
              41  com.apple.CoreFoundation                0x00007fff92893ae6 CFRunLoopRunSpecific + 230
              42  com.apple.HIToolbox                     0x00007fff9039f3d3 RunCurrentEventLoopInMode + 277
              43  com.apple.HIToolbox                     0x00007fff903a663d ReceiveNextEventCommon + 355
              44  com.apple.HIToolbox                     0x00007fff903a64ca BlockUntilNextEventMatchingListInMode + 62
              45  com.apple.AppKit                        0x00007fff86d053f1 _DPSNextEvent + 659
              46  com.apple.AppKit                        0x00007fff86d04cf5 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 135
              47  com.adobe.dvaui.framework               0x0000000102e87123 dvaui::ui::OS_Dialog::WaitForNextEvent() + 163
              48  com.adobe.dvaui.framework               0x0000000102e8894b dvaui::ui::OS_Dialog::ModalLoop() + 75
              49  com.adobe.dvaui.framework               0x0000000102e886f3 dvaui::ui::OS_Dialog::RunModal() + 195
              50  com.adobe.dvaeve.framework              0x0000000106733c09 dvaeve::UI_EveManager::DisplayView(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::istream&, dvaui::drawbot::SupplierInterface const*, dvaui::ui::UI_Node*) + 1785
              51  com.adobe.dvaeve.framework              0x000000010672fdf1 dvaeve::UI_Eve::ParseEveScript(std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >&) + 1169
              52  com.adobe.premiere.dialogs              0x00000001072a6de0 DLG::ProgressDialog::DoProgressDialog(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, ASL::InterfaceRef<ASL::IBatchOperation, ASL::IBatchOperation>, char const*) + 1872
              53  com.adobe.premiere.hsl                  0x0000000106eae924 HSL::ProgressDialog::DoProgressDialog(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, ASL::InterfaceRef<ASL::IBatchOperation, ASL::IBatchOperation>) + 84
              54  com.adobe.premiere.hsl                  0x0000000106e71812 HSL::ImportFiles(std::vector<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::allocator<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > const&, bool, bool, std::vector<ASL::InterfaceRef<BE::IProjectItem, BE::IProjectItem>, std::allocator<ASL::InterfaceRef<BE::IProjectItem, BE::IProjectItem> > >&, std::vector<std::pair<int, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, std::allocator<std::pair<int, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, ASL::InterfaceRef<BE::IProjectLoadStatus, BE::IProjectLoadStatus>&, DLG::ImportFromEDL::ImportFromEDLDialog*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const*, DLG::ImportFromEDL::ImportNewSequenceMediaParamsDialog*) + 802
              55  com.adobe.premiere.HandlerProject          0x00000001083bd20a HandlerProject::ProjectItemHelpers::ImportFilesToProject(ASL::InterfaceRef<BE::IProject, BE::IProject>, ASL::InterfaceRef<BE::IProjectItem, BE::IProjectItem>, dvacore::utility::Guid, std::vector<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::allocator<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > const&, bool) + 314
              56  com.adobe.premiere.HandlerProject          0x000000010838401b HandlerProject::ProjectHandler::OnImportFile(std::vector<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::allocator<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > const&, bool) + 251
              57  com.adobe.premiere.HandlerProject          0x000000010838b900 HandlerProject::ProjectHandler::ListenToMessage(ASL::Message const&) + 2144
              58  ASLMessaging                            0x000000010059327c ASL::Broadcaster::BroadcastMessage(ASL::Message const&) + 1484
              59  ASLMessaging                            0x000000010059e721 ASL::StationUtils::BroadcastMessage(ASL::ImmutableString const&, ASL::Message const&) + 65
              60  com.adobe.premiere.frontend             0x000000010b455f50 FE::Document::ImportFiles(std::vector<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::allocator<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > const&, bool) + 256
              61  com.adobe.premiere.frontend             0x000000010b48778f FE::ImportFile(FE::Document*) + 447
              62  com.adobe.premiere.frontend             0x000000010b45e010 FE::Document::ObeyCommand(UIF::Command const&) + 832
              63  com.adobe.premiere.uiframework          0x000000010337619c UIF::Commander::PostCommand(int) + 60
              64  com.adobe.premiere.frontend             0x000000010b495c1b HandleMenuCommand(NSMenuItem*) + 203
              65  com.adobe.dvacore.framework             0x0000000100126f16 int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 38
              66  com.adobe.premiere.frontend             0x000000010b44bb9e boost::function0<int>::operator()() const + 46
              67  com.adobe.premiere.frontend             0x000000010b44af63 FE::ApplicationErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0 <int>) + 35
              68  com.adobe.dvacore.framework             0x0000000100125f95 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 197
              69  com.adobe.dvacore.framework             0x0000000100127de3 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 99
              70  com.adobe.premiere.frontend             0x000000010b49530c -[PremiereCocoaMacApplication handleMenuCommand:] + 140
              71  com.apple.CoreFoundation                0x00007fff928eea1d -[NSObject performSelector:withObject:] + 61
              72  com.apple.AppKit                        0x00007fff86e0a710 -[NSApplication sendAction:to:from:] + 139
              73  com.apple.AppKit                        0x00007fff86ef7bd7 -[NSMenuItem _corePerformAction] + 399
              74  com.apple.AppKit                        0x00007fff86ef790e -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 125
              75  com.adobe.dvaui.framework               0x0000000102ec148e -[DVAMacMenu performActionForItemAtIndex:] + 62
              76  com.apple.AppKit                        0x00007fff87194194 -[NSMenu _internalPerformActionForItemAtIndex:] + 38
              77  com.apple.AppKit                        0x00007fff87025ce5 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 138
              78  com.apple.AppKit                        0x00007fff86e7151f NSSLMMenuEventHandler + 339
              79  com.apple.HIToolbox                     0x00007fff903a5308 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1263
              80  com.apple.HIToolbox                     0x00007fff903a4914 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCall Rec + 446
              81  com.apple.HIToolbox                     0x00007fff903bb6c7 SendEventToEventTarget + 76
              82  com.apple.HIToolbox                     0x00007fff904019f5 _ZL18SendHICommandEventjPK9HICommandjjhPKvP20OpaqueEventTargetRefS5_PP14OpaqueEventRef + 398
              83  com.apple.HIToolbox                     0x00007fff904e8645 SendMenuCommandWithContextAndModifiers + 56
              84  com.apple.HIToolbox                     0x00007fff9052eef9 SendMenuItemSelectedEvent + 253
              85  com.apple.HIToolbox                     0x00007fff903fab07 _ZL19FinishMenuSelectionP13SelectionDataP10MenuResultS2_ + 101
              86  com.apple.HIToolbox                     0x00007fff903f2245 _ZL14MenuSelectCoreP8MenuData5PointdjPP13OpaqueMenuRefPt + 600
              87  com.apple.HIToolbox                     0x00007fff903f180e _HandleMenuSelection2 + 580
              88  com.apple.AppKit                        0x00007fff86d704ce _NSHandleCarbonMenuEvent + 250
              89  com.apple.AppKit                        0x00007fff86d05941 _DPSNextEvent + 2019
              90  com.apple.AppKit                        0x00007fff86d04cf5 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 135
              91  com.apple.AppKit                        0x00007fff86d0162d -[NSApplication run] + 470
              92  com.adobe.premiere.frontend             0x000000010b494864 FE::MacApplication::RunSelf(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 164
              93  com.adobe.premiere.frontend             0x000000010b43f2de FE::Application::Run(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 2510
              94  com.adobe.premiere.frontend             0x000000010b49875d AppMain + 253
              95  com.adobe.premiere.startup              0x000000010b5e0c08 (anonymous namespace)::LaunchFrontendFramework(ASL::ObjectPtr<ASL::Module, ASL::AtomicValue> const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int, void*) + 168
              96  com.adobe.AdobePremierePro              0x0000000100003650 (anonymous namespace)::CallStartupFramework(int, char const* const*) + 288
              97  com.adobe.AdobePremierePro              0x0000000100003bd7 main + 167
              98  com.adobe.AdobePremierePro              0x0000000100003494 start + 52
              Thread 1:: Dispatch queue: com.apple.libdispatch-manager
              0   libsystem_kernel.dylib                  0x00007fff8f2d57e6 kevent + 10
              1   libdispatch.dylib                       0x00007fff91cfd5be _dispatch_mgr_invoke + 923
              2   libdispatch.dylib                       0x00007fff91cfc14e _dispatch_mgr_thread + 54
              Thread 2:
              0   libsystem_kernel.dylib                  0x00007fff8f2d4bca __psynch_cvwait + 10
              1   libsystem_c.dylib                       0x00007fff8cebd274 _pthread_cond_wait + 840
              2   com.adobe.amt.services                  0x0000000111a23c53 AMTConditionLock::LockWhenCondition(int) + 37
              3   com.adobe.amt.services                  0x0000000111a1ccce _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 92
              4   com.adobe.amt.services                  0x0000000111a23cbe AMTThread::Worker(void*) + 28
              5   libsystem_c.dylib                       0x00007fff8ceb98bf _pthread_start + 335
              6   libsystem_c.dylib                       0x00007fff8cebcb75 thread_start + 13
              Thread 3:
              2   com.apple.CoreServices.CarbonCore          0x00007fff8e19ac9a TSWaitOnCondition + 106
              3   com.apple.CoreServices.CarbonCore          0x00007fff8e12d3f6 TSWaitOnConditionTimedRelative + 127
              4   com.apple.CoreServices.CarbonCore          0x00007fff8e1720bd MPWaitOnQueue + 181
              5   com.adobe.MediaCore.Frameworks.ASL.Foundation          0x0000000100478810 ASL::(anonymous namespace)::TaskProc(void*) + 96
              6   com.apple.CoreServices.CarbonCore          0x00007fff8e172f22 PrivateMPEntryPoint + 58
              7   libsystem_c.dylib                       0x00007fff8ceb98bf _pthread_start + 335
              8   libsystem_c.dylib                       0x00007fff8cebcb75 thread_start + 13
              Thread 4:
              5   com.adobe.dvacore.framework             0x000000010019727f dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 143
              7   com.adobe.dvacore.framework             0x000000010018f613 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
              8   com.adobe.boost_threads.framework          0x00000001000dfac4 thread_proxy + 132
              9   libsystem_c.dylib                       0x00007fff8ceb98bf _pthread_start + 335
              10  libsystem_c.dylib                       0x00007fff8cebcb75 thread_start + 13
              Thread 5:
              1   com.adobe.dvatransport.framework          0x000000010063d34e boost::asio::detail::kqueue_reactor<false>::run(bool) + 478
              2   com.adobe.dvatransport.framework          0x000000010063e405 boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 517
              3   com.adobe.dvatransport.framework          0x000000010061bfcc SkyConnectionEnv::MainLoop() + 76
              4   com.adobe.dvatransport.framework          0x000000010061c039 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
              5   com.adobe.boost_threads.framework          0x00000001000dfac4 thread_proxy + 132
              6   libsystem_c.dylib                       0x00007fff8ceb98bf _pthread_start + 335
              7   libsystem_c.dylib                       0x00007fff8cebcb75 thread_start + 13
              Thread 6:
              2   com.adobe.dvatransport.framework          0x000000010063e53f boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 831
              3   com.adobe.dvatransport.framework          0x000000010063f135 boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service<boost::asio ::ip::tcp>::work_io_service_runner>::run() + 53
              4   com.adobe.dvatransport.framework          0x0000000100624379 asio_detail_posix_thread_function + 25
              Thread 7:
              Thread 8:
              Thread 9:
              Thread 10:
              Thread 11:
              Thread 12:
              Thread 13:
              1   libsystem_c.dylib                       0x00007fff8cebd2a6 _pthread_cond_wait + 890
              2   com.apple.CoreServices.CarbonCore          0x00007fff8e12d414 TSWaitOnConditionTimedRelative + 157
              3   com.apple.CoreServices.CarbonCore          0x00007fff8e1720bd MPWaitOnQueue + 181
              4   com.adobe.dvacore.framework             0x000000010019727f dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 143
              5   com.adobe.dvacore.framework             0x0000000100127ebe boost::function0<void>::operator()() const + 46
              6   com.adobe.dvacore.framework             0x000000010018f613 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
              7   com.adobe.boost_threads.framework          0x00000001000dfac4 thread_proxy + 132
              8   libsystem_c.dylib                       0x00007fff8ceb98bf _pthread_start + 335
              9   libsystem_c.dylib                       0x00007fff8cebcb75 thread_start + 13
              Thread 14:
              Thread 15:
              Thread 16:
              Thread 17:
              Thread 18:
              5   com.apple.CoreFoundation                0x00007fff928a37ff CFRunLoopRun + 95
              6   com.adobe.dvacore.framework             0x0000000100181799 dvacore::threads::RunPlatformEventLoop() + 89
              7   com.adobe.dvacore.framework             0x00000001001873d1 dvacore::threads::(anonymous namespace)::EventLoopExecutor::EventLoopMain(dvacore::threads::SyncPoint&) + 177
              8   com.adobe.dvacore.framework             0x0000000100127ebe boost::function0<void>::operator()() const + 46
              9   com.adobe.dvacore.framework             0x000000010018f613 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
              10  com.adobe.boost_threads.framework          0x00000001000dfac4 thread_proxy + 132
              11  libsystem_c.dylib                       0x00007fff8ceb98bf _pthread_start + 335
              12  libsystem_c.dylib                       0x00007fff8cebcb75 thread_start + 13
              Thread 19:
              0   libsystem_kernel.dylib                  0x00007fff8f2d4e42 __semwait_signal + 10
              1   libsystem_c.dylib                       0x00007fff8ce6fdea nanosleep + 164
              2   com.adobe.premiere.scriptlayer          0x00000001064d53bb ScObjects::Thread::sleep(unsigned int) + 59
              3   com.adobe.premiere.scriptlayer          0x00000001064bfec3 ScObjects::BridgeTalkThread::run() + 163
              4   com.adobe.premiere.scriptlayer          0x00000001064d54b6 ScObjects::Thread::go(void*) + 166
              Thread 20:
              0   libsystem_kernel.dylib                  0x00007fff8f2d4d7a __recvfrom + 10
              1   ServiceManager-Launcher.dylib           0x0000000120fc3982 Invoke + 54020
              2   ServiceManager-Launcher.dylib           0x0000000120fc2adf Invoke + 50273
              3   ServiceManager-Launcher.dylib           0x0000000120fc1b26 Invoke + 46248
              4   ServiceManager-Launcher.dylib           0x0000000120fc1b81 Invoke + 46339
              5   ServiceManager-Launcher.dylib           0x0000000120fc1c02 Invoke + 46468
              6   ServiceManager-Launcher.dylib           0x0000000120fbc30d Invoke + 23695
              7   ServiceManager-Launcher.dylib           0x0000000120fbc4a6 Invoke + 24104
              8   ServiceManager-Launcher.dylib           0x0000000120fbcf2f Invoke + 26801
              9   ServiceManager-Launcher.dylib           0x0000000120fbd01d Invoke + 27039
              10  ServiceManager-Launcher.dylib           0x0000000120fc031f Invoke + 40097
              11  ServiceManager-Launcher.dylib           0x0000000120fc05c5 Invoke + 40775
              12  ServiceManager-Launcher.dylib           0x0000000120fc0b84 Invoke + 42246
              13  ServiceManager-Launcher.dylib           0x0000000120fc0d71 Invoke + 42739
              14  ServiceManager-Launcher.dylib           0x0000000120fb2daf Login + 1773
              15  ServiceManager-Launcher.dylib           0x0000000120fb4295 Login + 7123
              16  ServiceManager-Launcher.dylib           0x0000000120fc12a8 Invoke + 44074
              17  ServiceManager-Launcher.dylib           0x0000000120fc36c1 Invoke + 53315
              18  libsystem_c.dylib                       0x00007fff8ceb98bf _pthread_start + 335
              19  libsystem_c.dylib                       0x00007fff8cebcb75 thread_start + 13
              Thread 21:
              Thread 22:
              Thread 23:
              Thread 24:
              2   com.apple.CoreServices.CarbonCore          0x00007fff8e198e3e TS_exception_listener_thread + 100
              3   libsystem_c.dylib                       0x00007fff8ceb98bf _pthread_start + 335
              4   libsystem_c.dylib                       0x00007fff8cebcb75 thread_start + 13
              Thread 25:
              2   com.adobe.adobeswfl                     0x000000012a6a189d APXGetHostAPI + 2465805
              3   com.adobe.adobeswfl                     0x000000012a45a5e9 APXGetHostAPI + 77145
              4   com.adobe.adobeswfl                     0x000000012a6a19b1 APXGetHostAPI + 2466081
              5   com.adobe.adobeswfl                     0x000000012a6a1d1a APXGetHostAPI + 2466954
              6   com.adobe.adobeswfl                     0x000000012a6a1e49 APXGetHostAPI + 2467257
              Thread 26:
              Thread 27:
              Thread 28:
              Thread 29:
              Thread 30:
              Thread 31:
              Thread 32:
              Thread 33:
              Thread 34:
              Thread 35:
              Thread 36:
              Thread 37:
              2   com.apple.framework.IOKit               0x00007fff8e94c3ab io_connect_method + 431
              3   com.apple.framework.IOKit               0x00007fff8e907627 IOConnectCallMethod + 172
              4   com.apple.framework.IOKit               0x00007fff8e90772b IOConnectCallScalarMethod + 46
              5   com.blackmagic-design.DeckLinkAPI          0x0000000124fe2ce3 BMD::IOKit::WriteScalar_ReadScalar(unsigned int, int, unsigned long long const*, unsigned int, unsigned long long*, unsigned int) + 42
              6   com.blackmagic-design.DeckLinkAPI          0x0000000124fde74a WaitForNotificationEvents + 60
              7   com.blackmagic-design.DeckLinkAPI          0x0000000124fd49a3 CDeckLinkOutput::DriverNotificationThread() + 101
              8   com.blackmagic-design.DeckLinkAPI          0x0000000124fd4a75 CDeckLinkOutput::DriverNotificationThreadFunction(void*) + 9
              Thread 38:
              5   com.blackmagic-design.DeckLinkAPI          0x0000000124fd558d CDeckLinkOutput::VideoPreviewThread(PreviewThreadArgs*) + 71
              6   com.blackmagic-design.DeckLinkAPI          0x0000000124fd56d1 CDeckLinkOutput::VideoPreviewThreadFunction(void*) + 15
              Thread 39:
              Thread 40:
              Thread 41:
              5   com.apple.CoreMediaIO                   0x00007fff90dcd541 CMIO::DAL::RunLoop::OwnThread(void*) + 159
              6   com.apple.CoreMediaIO                   0x00007fff90dc36b2 CAPThread::Entry(CAPThread*) + 98
              Thread 42:
              2   com.adobe.adobeswfl                     0x000000012a6a1869 APXGetHostAPI + 2465753
              3   com.adobe.adobeswfl                     0x000000012a6be0ec APXGetHostAPI + 2582620
              Thread 43:
              3   com.adobe.adobeswfl                     0x000000012a83be6f APXGetHostAPI + 4146655
              Thread 44:: com.apple.NSURLConnectionLoader
              5   com.apple.Foundation                    0x00007fff86a350ab +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 335
              6   com.apple.Foundation                    0x00007fff86a297fe -[NSThread main] + 68
              7   com.apple.Foundation                    0x00007fff86a29776 __NSThread__main__ + 1575
              Thread 45:: com.apple.CFSocket.private
              0   libsystem_kernel.dylib                  0x00007fff8f2d4df2 __select + 10
              1   com.apple.CoreFoundation                0x00007fff928dcf9b __CFSocketManager + 1355
              2   libsystem_c.dylib                       0x00007fff8ceb98bf _pthread_start + 335
              3   libsystem_c.dylib                       0x00007fff8cebcb75 thread_start + 13
              Thread 46:
              1   com.adobe.MediaFoundation               0x0000000100ac04fc MF::DirectoryChangeMonitor::(anonymous namespace)::EventQueueThreadProc(void*) + 428
              Thread 47:: com.apple.audio.IOThread.client
              2   com.apple.audio.CoreAudio               0x00007fff89759eb3 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, unsigned int) + 93
              3   com.apple.audio.CoreAudio               0x00007fff89759f05 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, unsigned int) + 37
              4   com.apple.audio.CoreAudio               0x00007fff89753568 HALC_ProxyIOContext::IOWorkLoop() + 888
              5   com.apple.audio.CoreAudio               0x00007fff89753151 HALC_ProxyIOContext::IOThreadEntry(void*) + 73
              6   com.apple.audio.CoreAudio               0x00007fff8975300c HALB_IOThread::Entry(void*) + 78
              Thread 48:
              Thread 49:
              2   com.blackmagic-design.premierepro.Playback          0x00000001209896e8 BMD::Core::Threaded::RunThread() + 188
              3   com.blackmagic-design.premierepro.Playback          0x0000000120989772 BMD::Core::Threaded::StaticRunThread(void*) + 14
              4   libsystem_c.dylib                       0x00007fff8ceb98bf _pthread_start + 335
              5   libsystem_c.dylib                       0x00007fff8cebcb75 thread_start + 13
              Thread 50:
              Thread 51:
              Thread 52:
              Thread 53:
              Thread 54:
              Thread 55:
              Thread 56:
              Thread 57:
              Thread 58:
              Thread 59:
              Thread 60:
              Thread 61:
              Thread 62:
              Thread 63:
              0   libsystem_kernel.dylib                  0x00007fff8f2d5192 __workq_kernreturn + 10
              1   libsystem_c.dylib                       0x00007fff8cebb594 _pthread_wqthread + 758
              2   libsystem_c.dylib                       0x00007fff8cebcb85 start_wqthread + 13
              Thread 64:: Dispatch queue: com.apple.root.default-priority
              2   libsystem_c.dylib                       0x00007fff8ce6fbb5 usleep + 53
              3   com.adobe.Mezzanine                     0x0000000105788ce2 MZ::(anonymous namespace)::ImportFilesOperation::ProcessFile(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, ASL::ObjectPtr<std::vector<ASL::InterfaceRef<BE::IProjectItem, BE::IProjectItem>, std::allocator<ASL::InterfaceRef<BE::IProjectItem, BE::IProjectItem> > >, ASL::AtomicValue>) + 322
              4   com.adobe.Mezzanine                     0x000000010578a937 MZ::(anonymous namespace)::ImportFilesOperation::Process() + 631
              5   com.adobe.Mezzanine                     0x000000010573b1da boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf0<void, ASL::IThreadedQueueRequest>, boost::_bi::list1<boost::_bi::value<ASL::InterfaceRef<ASL::IThreadedQueueRequest, ASL::IThreadedQueueRequest> > > >, void>::invoke(boost::detail::function::function_buffer&) + 74
              6   com.adobe.dvacore.framework             0x0000000100199b3e dvacore::threads::ExecuteTopLevelFunction(dvacore::threads::AllocatedFunctionT<boost::fun ction<void ()()> > const&) + 46
              7   com.adobe.dvacore.framework             0x0000000100199438 dvacore::threads::(anonymous namespace)::WrapGCDAsyncCall(void*) + 24
              8   libdispatch.dylib                       0x00007fff91cfc799 _dispatch_worker_thread2 + 255
              9   libsystem_c.dylib                       0x00007fff8cebb3da _pthread_wqthread + 316
              10  libsystem_c.dylib                       0x00007fff8cebcb85 start_wqthread + 13
              Thread 65:
              Thread 66:
              Thread 67:
              Thread 68:
              2   com.apple.FinderKit                     0x00007fff8b2176c3 TConditionVariable::WaitWithTimeout(TMutex&, unsigned long long, bool&) + 69
              3   com.apple.FinderKit                     0x00007fff8b2426c6 TThreadSafeQueue<TThumbnailExtractorThread::TThumbnailQueueData>::WaitForChange(unsigned long long) + 40
              4   com.apple.FinderKit                     0x00007fff8b241a56 TThumbnailExtractorThread::Main() + 302
              5   com.apple.FinderKit                     0x00007fff8b217975 TThread::MainGlue(void*) + 29
              Thread 69 Crashed:
              0   com.adobe.premiere.AAFProjectConverter          0x000000011aee90e3 AAF::ScopeStack::ResolveScopeReference(IAAFScopeReference&) + 211
              1   com.adobe.premiere.AAFProjectConverter          0x000000011aed8ca5 AAF::Importer::ProcessSegment(AAF::Composition&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, IAAFSegment&, unsigned long long, AAF::Track&, int&, int&, AAF::Clip*) + 1285
              2   com.adobe.premiere.AAFProjectConverter          0x000000011aed9050 AAF::Importer::ProcessComponent(AAF::Composition&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, IAAFComponent&, AAF::Track&, int&, int&, AAF::Clip*) + 272
              3   com.adobe.premiere.AAFProjectConverter          0x000000011aed9882 AAF::Importer::ProcessSequence(IAAFSequence&, AAF::Composition&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int&, AAF::Track*&, AAF::Clip*) + 354
              4   com.adobe.premiere.AAFProjectConverter          0x000000011aed9dc6 AAF::Importer::ProcessOperationGroupInput(IAAFSegment&, bool, IAAFOperationGroup&, AAF::Composition&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, AAF::Track*, int&) + 662
              5   com.adobe.premiere.AAFProjectConverter          0x000000011aed9f7a AAF::Importer::ProcessOperationGroup(IAAFOperationGroup&, AAF::Composition&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, AAF::Track*, int&) + 218
              6   com.adobe.premiere.AAFProjectConverter          0x000000011aed9c2f AAF::Importer::ProcessOperationGroupInput(IAAFSegment&, bool, IAAFOperationGroup&, AAF::Composition&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, AAF::Track*, int&) + 255
              7   com.adobe.premiere.AAFProjectConverter          0x000000011aed9f7a AAF::Importer::ProcessOperationGroup(IAAFOperationGroup&, AAF::Composition&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, AAF::Track*, int&) + 218
              8   com.adobe.premiere.AAFProjectConverter          0x000000011aede27e AAF::Importer::readCompositions() + 12734
              9   com.adobe.premiere.AAFProjectConverter          0x000000011af3b130 PremAAFImport::ImportAAF(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, PremAAF::ProgressReporter&) + 272
              10  com.adobe.premiere.AAFProjectConverter          0x000000011af2c360 PremAAFImport::(anonymous namespace)::ImportAAFOperation::Process() + 64
              11  com.adobe.MediaCore.Frameworks.ASL.Foundation          0x000000010046828a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf0<void, ASL::IThreadedQueueRequest>, boost::_bi::list1<boost::_bi::value<ASL::InterfaceRef<ASL::IThreadedQueueRequest, ASL::IThreadedQueueRequest> > > >, void>::invoke(boost::detail::function::function_buffer&) + 74
              12  com.adobe.dvacore.framework             0x0000000100127ebe boost::function0<void>::operator()() const + 46
              13  com.adobe.dvacore.framework             0x00000001001972fb dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 267
              14  com.adobe.dvacore.framework             0x0000000100127ebe boost::function0<void>::operator()() const + 46
              15  com.adobe.dvacore.framework             0x000000010018f613 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
              16  com.adobe.boost_threads.framework          0x00000001000dfac4 thread_proxy + 132
              17  libsystem_c.dylib                       0x00007fff8ceb98bf _pthread_start + 335
              18  libsystem_c.dylib                       0x00007fff8cebcb75 thread_start + 13
              Thread 70:
              Thread 71:
              Thread 72:
              Thread 73:
              Thread 74:
              Thread 75:
              Thread 76:
              Thread 77:
              Thread 78:
              Thread 79:
              Thread 80:
              Thread 81:
              Thread 82:
              Thread 83:
              Thread 84:
              Thread 85:
              Thread 86:
              Thread 87:
              Thread 88:
              Thread 89:
              Thread 90:
              Thread 91:
              Thread 92:
              Thread 69 crashed with X86 Thread State (64-bit):
                rax: 0x0000000000080204  rbx: 0x000000011180fce0  rcx: 0x0000000131c4bd80  rdx: 0x0000000000000000
                rdi: 0x000000011180fce0  rsi: 0x0000000000000001  rbp: 0x0000000134c2dcc0  rsp: 0x0000000134c2dc70
                 r8: 0x0000000131c4d5b8   r9: 0x0000000000000001  r10: 0x000000011180fcf0  r11: 0x0000000134c2dc1c
                r12: 0x0000000000000000  r13: 0x000000011180fce0  r14: 0x000000013aa00880  r15: 0x0000000131c4d5b8
                rip: 0x000000011aee90e3  rfl: 0x0000000000010202  cr2: 0x00000000000801f4
              Logical CPU: 12
              Binary Images:
                     0x100000000 -        0x100003fff +com.adobe.AdobePremierePro (5.0.4 - 5.0.4) <95920D41-C4A7-3166-A177-A98B1AE92CBD> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/MacOS/Adobe Premiere Pro CS5
                     0x100008000 -        0x10000dffd +com.adobe.AdobeCrashReporter (3.0 - 3.0.20100302) <DFFB9A08-8369-D65F-161F-7C61D562E307> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                     0x100012000 -        0x10007cff7 +com.adobe.amtlib (amtlib 3.0.0.64 - 3.0.0.64) <6B2F73C2-10AB-08B3-4AB0-A31C83D1E5E0> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                     0x1000af000 -        0x1000beff7  com.apple.opengl (1.7.5 - 1.7.5) <2945F1A6-910C-3596-9988-5701B04BD821> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                     0x1000c6000 -        0x1000cdff3 +com.adobe.boost_date_time.framework (boost_date_time version 5.0.0 - 5.0.0.0) <740E38F5-4F61-E53F-F66E-51BA444827FA> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                     0x1000dd000 -        0x1000e5ff3 +com.adobe.boost_threads.framework (boost_threads version 5.0.0 - 5.0.0.0) <76962F4C-CF91-F183-6A31-B125F2E0C9CE> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                     0x1000f4000 -        0x100274fe7 +com.adobe.dvacore.framework (dvacore version 5.0.0 - 5.0.0.0) <EE0F0B45-64C9-8876-3AD6-C3E977A43A2E> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                     0x1003fb000 -        0x10041afff +com.adobe.dvamediatypes.framework (dvamediatypes version 5.0.0 - 5.0.0.0) <3DF860FF-A2BC-C51F-555B-E3471679F636> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                     0x10043a000 -        0x10043bfff +PRM (??? - ???) <9129DE14-8AE0-E05C-E9C9-9E14D3A76A7D> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
                     0x10043f000 -        0x1004a5ff5 +com.adobe.MediaCore.Frameworks.ASL.Foundation (1.0 - 1.0) <4FF2D43F-B418-E775-89B6-B73C2156BA59> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
                     0x10058e000 -        0x1005a4fff +ASLMessaging (??? - ???) <8F28CDE4-1E18-9233-80C7-643533CE0E9B> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
                     0x1005c2000 -        0x1005c3fff +com.adobe.MediaCore.Frameworks.Memory (1.0 - 1.0) <356E74AD-101E-3E6F-E6F6-937F7EA7E0A9> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
                     0x1005c8000 -        0x1005d9ff1 +ASLUnitTesting (??? - ???) <AB4DEB5D-D4D1-95B7-7B01-6E0CC4923CDA> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
                     0x1005f2000 -        0x1005f3fff +com.adobe.boost_system.framework (boost_system version 5.0.0 - 5.0.0.0) <E8151E8B-3B98-A3B7-41EC-7FEE945D7305> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                     0x1005f9000 -        0x10066fff7 +com.adobe.dvatransport.framework (dvatransport version 5.0.0 - 5.0.0.0) <F301D928-436B-73AD-D192-73344BC87744> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
                     0x1006f2000 -        0x10072fff3 +com.adobe.dvamarshal.framework (dvamarshal version 5.0.0 - 5.0.0.0) <C99AC560-5B1C-8E5B-1A96-CD5C11633D19> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
                     0x1007a8000 -        0x100983fff +com.adobe.dynamiclink.framework (dynamiclink version 5.0.0 - 5.0.0.0) <F05AF920-FE0F-C9A2-26B5-EBC6AC07A9CF> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
                     0x100aaf000 -        0x100ae3fff +com.adobe.MediaFoundation (??? - 1.0) <7441AF6E-23E1-E1E8-28F0-12A2A47347D6> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
                     0x100b28000 -        0x100b9ffe3 +com.adobe.MediaCore.Frameworks.AudioRenderer (??? - 1.0) <53F03A38-0A49-90D7-622B-2A7C757CE4E6> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
                     0x100c39000 -        0x101713fef +com.adobe.MediaCore.Frameworks.Backend (??? - 1.0) <7A5AABE7-EB74-A4E9-63F5-C047648F03BB> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
                     0x10243f000 -        0x1025e3ff3 +com.adobe.MediaCore.Frameworks.ImageRenderer (??? - 1.0) <98CC75BC-2194-4396-846C-8F23A17E3456> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
                     0x102713000 -        0x10274fff7 +com.adobe.MediaCore.Frameworks.MLFoundation (1.0 - 1.0) <B6D56CFE-8F32-CDF1-7E44-37831E4B9B38> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
                     0x1027a1000 -        0x1027f9fff +com.adobe.MediaCore.VideoFrame (1.0 - 1.0) <5878F609-57ED-CEF4-F7FC-5B87B8EE877F> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
                     0x102869000 -        0x1028a0fff +com.adobe.MediaCore.Frameworks.PluginSupport (1.0 - 1.0) <E07FDF10-7D8A-87A9-16FD-B4F406612A9E> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
                     0x1028e1000 -        0x10291ffff +com.adobe.MediaCore.Frameworks.SweetPeaSupport (1.0 - 1.0) <B341E6F2-931C-7F39-3543-0E11934D3214> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
                     0x102975000 -        0x1029b7fe1 +com.adobe.MediaCore.Frameworks.AudioSupport (1.0 - 1.0) <42E3EDB9-E3F9-CCF5-F2C2-4D8859EE31D6> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
                     0x102a00000 -        0x102a04fff +com.adobe.MediaCore.Frameworks.MediaUtils (1.0 - 1.0) <7CD4954E-990E-53BD-77D8-C15E99283356> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
                     0x102a0a000 -        0x102a24ffb +com.adobe.MediaCore.Frameworks.AudioFilterHost (1.0 - 1.0) <EEB687E7-2749-27AC-0656-A579163D55BE> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
                     0x102a4c000 -        0x102aaaffd +AdobeXMP (??? - ???) <BD9DD0AC-9226-CCBE-D811-7416A1641FBE> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                     0x102ab8000 -        0x102b44fe3 +AdobeXMPFiles (??? - ???) <1CC3CD84-DAE7-0B17-F92A-EFAD4C8D4771> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
                     0x102b7c000 -        0x102bb4fff +com.adobe.MediaCore.Frameworks.AudioFilters (??? - 1.0) <D9F9C194-6681-58C9-1733-82F7B32D0A64> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
                     0x102c1f000 -        0x102c2bff5 +com.adobe.boost_signals.framework (boost_signals version 5.0.0 - 5.0.0.0) <654A49A0-2AFF-4230-E579-18B8B4A2804A> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                     0x102c3d000 -        0x102f88fef +com.adobe.dvaui.framework (dvaui version 5.0.0 - 5.0.0.0) <153F0B53-B114-38FF-FE03-E70DD91B53D1> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                     0x103336000 -        0x1035d2fe1 +com.adobe.premiere.uiframework (1.0 - 1.0) <001B9903-BEA5-7F15-026A-27A730E8DC29> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramework
                     0x103908000 -        0x103a27fff +com.adobe.MediaCore.Frameworks.VideoRenderer (1.0 - 1.0) <77EDFD04-38D5-BE01-D369-42380D4AD231> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
                     0x103b90000 -        0x103d35ff7 +com.adobe.MediaCore.Frameworks.ImporterHost (1.0 - 1.0) <DD4913EC-FFA7-BDD8-EBD9-522F98217029> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
                     0x103f03000 -        0x103fc8feb +com.adobe.MediaCore.Frameworks.ExporterHost (1.0 - 1.0) <0ECD85D7-C33C-B5CC-FFBF-6BF99E9B0335> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
                     0x1040e4000 -        0x10415dff7 +com.adobe.MediaCore.Frameworks.PlayerHost (1.0 - 1.0) <416D7984-1232-FBB4-6C2E-238CE48EE317> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
                     0x1041fa000 -        0x104269fff +com.adobe.MediaCore.Frameworks.RecorderHost (1.0 - 1.0) <38733132-C7BD-477E-5EDB-0FB3A487D2DA> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/RecorderHost.framework/Versions/A/RecorderHost
                     0x1042e9000 -        0x1042f6ff7 +com.adobe.MediaCore.Frameworks.ProjectConverterHost (1.0 - 1.0) <9D558E84-1053-937D-CE9D-37155A061C50> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConverterHos t
                     0x104309000 -        0x1043dbfff +com.adobe.MediaCore.Frameworks.VideoFilterHost (1.0 - 1.0) <76DCA2D8-73A5-307E-8FE5-5E007491FA4F> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
                     0x10449e000 -        0x1044adfff +com.adobe.MediaCore.Frameworks.ProjectSupport (1.0 - 1.0) <5FF31CD8-E89B-15FE-D99E-287E954FC546> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
                     0x1044c1000 -        0x1044d8ff6 +com.adobe.AMEAppFoundation.framework (??? - 1.0) <4DC4DA20-D5FF-7218-47FD-2ED4540A776D> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
                     0x1044f9000 -        0x10451cff1 +com.adobe.PostEncodeHost.framework (??? - 1.0) <313A563D-2A02-6A42-E532-4BC15244289E> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostEncodeHost
                     0x10454a000 -        0x104589fff +com.adobe.dvatemporalxmp.framework (dvatemporalxmp version 5.0.0 - 5.0.0.0) <EB4640AC-23A6-2F7A-4A31-4BD777C948FE> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
                     0x1045a1000 -        0x1045befff +AdobeBIB (??? - ???) <258F8418-4511-610F-526B-1B00695037B6> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                     0x1045c8000 -        0x104668fef +com.adobe.AdobeScCore (ScCore 4.1.23 - 4.1.23.7471) <B5706E32-47E4-52DC-0605-712F96BC74FC> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                     0x1046ae000 -        0x104752ffb +com.adobe.AdobeExtendScript (ExtendScript 4.1.23 - 4.1.23.7471) <4749CAD2-7EDF-6D17-A5A5-7B45189FEEA7> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
                     0x1047b4000 -        0x10480aff3 +com.adobe.MediaCore.Frameworks.BravoInitializer (1.0 - 1.0) <A227C530-AE53-EC88-3D12-970638D5E5CD> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/BravoInitializer
                     0x10488a000 -        0x10499efff +AdobeACE (??? - ???) <E359887D-1E7F-5E62-CB8D-37CE4DBFB4D8> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                     0x1049c3000 -        0x104d0cfe7 +AdobeAGM (??? - ???) <BEEAAC1B-CC8F-1A91-C0A2-03BE0343A313> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                     0x104dde000 -        0x10510ffe7 +AdobeCoolType (??? - ???) <D234D9AD-924B-9C1C-8F11-ECECAE7BBC05> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                     0x1051ab000 -        0x10526dff7 +AMEWrapper (??? - ???) <906E3C08-E157-32BF-6E1E-10D70EA31D78> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrapper
                     0x10532a000 -        0x10543efff +com.adobe.EncoderHost.framework (??? - 1.0) <0A2787CD-3F83-44AA-F028-9E927B14DBD2> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
                     0x105545000 -        0x1055cdff7 +com.adobe.premiere.MBCProvider (1.0 - 1.0) <811A025D-EED9-E52E-B8C6-0B9D9E2E4D36> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/MBCProvider.framework/Versions/A/MBCProvider
                     0x10564c000 -        0x105cdbfff +com.adobe.Mezzanine (??? - 1.0) <7F6314D6-EC48-C6FE-1D71-24EF3BA91C74> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
                     0x106217000 -        0x106227ff8 +com.adobe.ahclientframework (1.5.0.30 - 1.5.0.30) <5D6FFC4E-7B81-3E8C-F0D4-66A3FA94A837> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                     0x106232000 -        0x1062e3fff +com.adobe.dvaworkspace.framework (dvaworkspace version 5.0.0 - 5.0.0.0) <768D908A-1B81-6E35-E9F5-690848341006> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
                     0x1063bf000 -        0x10653bff7 +com.adobe.premiere.scriptlayer (1.0 - 1.0) <68EDFE08-FE7E-3CBC-74E8-BA266B247F1A> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ScriptLayerPPro.framework/Versions/A/ScriptLayerPPro
                     0x106719000 -        0x1067eafe1 +com.adobe.dvaeve.framework (dvaeve version 5.0.0 - 5.0.0.0) <245938EF-BC11-E122-5DF7-50D14309E553> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
                     0x1068ed000 -        0x106966fff +com.adobe.MediaCore.Frameworks.UI (1.0 - 1.0) <B7D07112-9445-3075-4239-039337BF0D7B> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
                     0x1069d7000 -        0x106bbdfff +com.adobe.SettingsUI.framework (??? - 1.0) <DE45A816-895D-A48E-BC7A-FAFE8329EF9F> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
                     0x106e07000 -        0x106f67fef +com.adobe.premiere.hsl (1.0 - 1.0) <316F9DDE-09DD-31EE-FDE2-8BA6D3482CF6> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HSL.framework/Versions/A/HSL
                     0x1070ea000 -        0x107434ff9 +com.adobe.premiere.dialogs (1.0 - 1.0) <AAE86A0F-FAAE-24EF-312A-86155FDF827A> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/Dialogs.framework/Versions/A/Dialogs
                     0x10770b000 -        0x10771bfff +com.adobe.premiere.HandlerAudioMiniMixer (1.0 - 1.0) <C660F73E-2435-7C9E-5858-3BF08D67D937> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerAudioMiniMixer.framework/Versions/A/HandlerAudioMiniMi xer
                     0x107738000 -        0x1077d0fff +com.adobe.premiere.HandlerAudioMixer (1.0 - 1.0) <FF3418CA-72B4-9D77-FD7C-A3C8AAF45FA9> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerAudioMixer.framework/Versions/A/HandlerAudioMixer
                     0x107889000 -        0x10791aff7 +com.adobe.premiere.HandlerCapture (1.0 - 1.0) <79365A1F-9C8B-E67A-4A9D-D6EC16BD762C> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerCapture.framework/Versions/A/HandlerCapture
                     0x1079ce000 -        0x1079e7ff7 +com.adobe.premiere.HandlerCSXS (1.0 - 1.0) <2F42882B-CCC5-13BA-EED7-E18C3C7C6717> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerCSXS.framework/Versions/A/HandlerCSXS
                     0x107a15000 -        0x107c47ff7 +com.adobe.premiere.HandlerEffectControls (1.0 - 1.0) <B8945C2D-580F-777B-FEE4-DE29AB42E360> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerEffectControls.framework/Versions/A/HandlerEffectContr ols
                     0x107e4e000 -        0x107ea8fff +com.adobe.premiere.HandlerEffects (1.0 - 1.0) <0D11E439-D6D9-5FD6-4CF8-A6AD5DCC005B> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerEffects.framework/Versions/A/HandlerEffects
                     0x107f09000 -        0x107f15fff +com.adobe.premiere.HandlerEvents (1.0 - 1.0) <4233456A-0C1C-467B-BA31-76A8CD51AEF4> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerEvents.framework/Versions/A/HandlerEvents
                     0x107f31000 -        0x107f41fff +com.adobe.premiere.HandlerGetProperties (1.0 - 1.0) <C551C5A1-D8A9-6477-D3DF-79AE43FA5046> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerGetProperties.framework/Versions/A/HandlerGetPropertie s
                     0x107f5c000 -        0x107f73fff +com.adobe.premiere.HandlerHistory (1.0 - 1.0) <17BED53E-C92E-92EB-D343-9DF4217571D9> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerHistory.framework/Versions/A/HandlerHistory
                     0x107f99000 -        0x107fe3ff3 +com.adobe.premiere.HandlerInfo (1.0 - 1.0) <8CA38343-363F-82EE-8F6F-3DD2D9341A33> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerInfo.framework/Versions/A/HandlerInfo
                     0x10803b000 -        0x108082ff7 +com.adobe.premiere.HandlerMetadataEditor (1.0 - 1.0) <3F36266A-33CF-E0D3-66D4-8D75681E26C1> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerMetadataEditor.framework/Versions/A/HandlerMetadataEdi tor
                     0x1080f5000 -        0x108156ff3 +com.adobe.premiere.HandlerMediaBrowser (1.0 - 1.0) <EF4E5313-0A3C-1F6B-3430-41A06C1185E3> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerMediaBrowser.framework/Versions/A/HandlerMediaBrowser
                     0x1081d5000 -        0x1081f8ff7 +com.adobe.premiere.HandlerMulticam (1.0 - 1.0) <47298EA9-481E-B7DD-DC51-6586E675F0D8> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerMulticam.framework/Versions/A/HandlerMulticam
                     0x10822f000 -        0x1082b3ff7 +com.adobe.premiere.HandlerProgramMonitor (1.0 - 1.0) <49719B96-2D6F-A13E-D0BF-35A76ECE4F48> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerProgramMonitor.framework/Versions/A/HandlerProgramMoni tor
                     0x108363000 -        0x108506ffb +com.adobe.premiere.HandlerProject (1.0 - 1.0) <DB7F223C-9D92-E9DE-2DCF-071AB23AF21D> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerProject.framework/Versions/A/HandlerProject
                     0x1086e3000 -        0x1087bdfff +com.adobe.premiere.HandlerSourceMonitor (1.0 - 1.0) <4A7896C1-C928-1004-AE2A-0A43420F6060> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerSourceMonitor.framework/Versions/A/HandlerSourceMonito r
                     0x108892000 -        0x108a6efff +com.adobe.premiere.HandlerTimeline (1.0 - 1.0) <94F5C8CF-00D3-B140-096A-CFD133F293F5> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerTimeline.framework/Versions/A/HandlerTimeline
                     0x108c44000 -        0x108ca9fff +com.adobe.premiere.FontEngine (1.0 - 1.0) <8746E8E8-16DB-F23C-0D3E-BD5D6C90A107> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEngine
                     0x108d41000 -        0x108d71ff3 +com.adobe.premiere.TitleLayer (1.0 - 1.0) <46342BA6-015B-4FB2-E1A8-D1C0A3B72CEE> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLayer
                     0x108f1a000 -        0x108f27ff7 +com.adobe.premiere.TitleImageManager (1.0 - 1.0) <7100D0DB-311D-B676-903C-12AA9099270A> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/TitleImageManager
                     0x108f3e000 -        0x108fddff4 +com.adobe.premiere.TitleCharacterFactory (1.0 - 1.0) <0A1D64DA-C2B6-5704-8FE9-99A9A7BE7E8C> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/TitleCharacterFactory.framework/Versions/A/TitleCharacterFact ory
                     0x10903e000 -        0x10916cfe3 +com.adobe.premiere.TitleCG (1.0 - 1.0) <88423A75-829F-F55E-26B3-8C9412266AB4> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
                     0x10923b000 -        0x1095a4fff +com.adobe.premiere.TitleLayout (1.0 - 1.0) <4660245B-2984-D3D3-1F2B-6FD5770F84D8> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleLayout
                     0x109cae000 -        0x109d29ffb +com.adobe.premiere.TitleRenderer (1.0 - 1.0) <90BD3409-02BE-D784-98A5-D6369A2BBD66> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/TitleRenderer.framework/Versions/A/TitleRenderer
                     0x109dd9000 -        0x10a5d7fef +com.adobe.HandlerTitler.framework (HandlerTitler version .. - ...) <D3ED29C1-16AB-26A1-3D7E-185B61E15021> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerTitler.framework/Versions/A/HandlerTitler
                     0x10ae68000 -        0x10afabfef +WRServices (??? - ???) <DD50D315-C0EC-C729-AC67-92588187E8C7> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                     0x10aff7000 -        0x10b026ff7 +com.adobe.premiere.HandlerTools (1.0 - 1.0) <12AA2404-9126-B778-8302-CCC62961D4EE> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerTools.framework/Versions/A/HandlerTools
                     0x10b0ab000 -        0x10b0e8fff +com.adobe.premiere.HandlerTrim (1.0 - 1.0) <6B7EBA4C-D8CF-3F8E-4780-72D90F47D7FB> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerTrim.framework/Versions/A/HandlerTrim
                     0x10b135000 -        0x10b144fff +com.adobe.premiere.HandlerVSTEditor (1.0 - 1.0) <7FCBAB65-D4A8-B3D1-FCDE-05E27A27638C> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerVSTEditor.framework/Versions/A/HandlerVSTEditor
                     0x10b15e000 -        0x10b177ff7 +com.adobe.premiere.CSXSHost (1.0 - 1.0) <F6BD2CE5-50F0-4E03-DA81-E027BBA83E4D> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/CSXSManager.framework/Versions/A/CSXSManager
                     0x10b197000 -        0x10b332fff +com.adobe.PlugPlug (2.0.0.746 - 2.0.0.746) <CB23C5AA-0E4B-182B-CB88-57DD32893F92> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
                     0x10b3da000 -        0x10b3fefff +com.adobe.premiere.registration (1.0 - 1.0) <703188FE-0F03-5BE2-7946-67F800D81E44> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/PrRegistration.framework/Versions/A/PrRegistration
                     0x10b418000 -        0x10b4eaff5 +com.adobe.premiere.frontend (1.0 - 1.0) <04994BF5-94AE-9F07-A4A4-82407CD4E00F> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
                     0x10b5db000 -        0x10b5fbfef +com.adobe.premiere.startup (1.0 - 1.0) <E749566C-465E-D0E4-C037-92398FE605FF> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/Startup.framework/Versions/A/Startup
                     0x10b613000 -        0x10b640fe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <095FDD3C-3961-3865-A59B-A5B0A4B8B923> /usr/lib/libSystem.B.dylib
                     0x10b64e000 -        0x10b6b0fff  com.apple.coreui (1.2.1 - 164.1) <F7972630-F696-3FC5-9FCF-A6E1C8771078> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                     0x10b6ec000 -        0x10b6f1ff7  libsystem_network.dylib (??? - ???) <5DE7024E-1D2D-34A2-80F4-08326331A75B> /usr/lib/system/libsystem_network.dylib
                     0x10b6f8000 -        0x10b701ff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <A4D651E3-D1C6-3934-AD49-7A104FD14596> /usr/lib/system/libsystem_notify.dylib
                     0x10b708000 -        0x10b73bff7  com.apple.GSS (2.1 - 2.0) <9A2C9736-DA10-367A-B376-2C7A584E6C7A> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                     0x10b753000 -        0x10b7a5ff7  libGLU.dylib (??? - ???) <3C9153A0-8499-3DC0-AAA4-9FA6E488BE13> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                     0x10b7b4000 -        0x10b7bafff  libGFXShared.dylib (??? - ???) <343AE6C0-EB02-333C-8D35-DF6093B92758> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                     0x10b7c0000 -        0x10b7d6fff  libGL.dylib (??? - ???) <6A473BF9-4D35-34C6-9F8B-86B68091A9AF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                     0x10b7e8000 -        0x10b827ff7  libGLImage.dylib (??? - ???) <2D1D8488-EC5F-3229-B983-CFDE0BB37586> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                     0x10b82f000 -        0x10b831fff  libCVMSPluginSupport.dylib (??? - ???) <61D89F3C-C64D-3733-819F-8AAAE4E2E993> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                     0x10b836000 -        0x10b839fff  libCoreVMClient.dylib (??? - ???) <E034C772-4263-3F48-B083-25A758DD6228> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                     0x10b83e000 -        0x10b921fff  libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <358B5B40-43B2-3F92-9FD3-DAA68806E1FF> /usr/lib/libcrypto.0.9.7.dylib
                     0x10b977000 -        0x10bc4ffe6 +libxerces-c-3.0.dylib (??? - ???) <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/libxerces-c-3.0.dylib
                     0x10bdc9000 -        0x10bdc9fff  libmx.A.dylib (2026.0.0 - compatibility 1.0.0) <C23BF0A1-7E6D-35EF-85FE-651EE2C13D53> /usr/lib/libmx.A.dylib
                     0x10bdcc000 -        0x10be18fff +com.adobe.MediaCore.Frameworks.GPUFoundation (??? - 1.0) <E3FFB220-3864-4225-10C0-8518CEFDAC53> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUFoundation
                     0x10bf4d000 -        0x10bffdfff +com.adobe.exo.framework (exo version 5.0.0 - 5.0.0.0) <75607AC0-6751-5090-CA98-0ECA3FF5DFBE> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/exo.framework/Versions/A/exo
                     0x10c103000 -        0x10c145fff +com.adobe.dynamiclinkui.framework (dynamiclinkui version 5.0.0 - 5.0.0.0) <089DB1C7-163A-CB74-F469-732D2A7F0D37> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynamiclinkui
                     0x10c19b000 -        0x10c1c6fff  com.apple.carbonframeworktemplate (1.0 - 1.0) <F2591842-ED49-83CD-A03C-5C3677D4177B> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefoundation
                     0x10c202000 -        0x10c22bfff +ameproperties (??? - ???) <BBD88CAF-7AB3-CE73-2C0F-06D7A3CF28C5> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ameproperties.framework/Versions/A/ameproperties
                     0x10c26f000 -        0x10c290fff +AdobeBIBUtils (??? - ???) <5DBF8E0C-F733-1148-9588-A01126793FD2> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                     0x10c29d000 -        0x10c2a2fff +com.adobe.AppServices.framework (??? - 1.0) <4EEC80D3-D366-D841-16C1-2901E1706FC7> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AppServices.framework/Versions/A/AppServices
                     0x10c2ad000 -        0x10c303feb +com.adobe.headlights.LogSessionFramework (??? - 2.0.1.011) <03B80698-2C3B-A232-F15F-8F08F8963A19> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                     0x10c348000 -        0x10c34efff  com.apple.agl (3.1.4 - AGL-3.1.4) <AB6F0403-0C4C-3FF2-B59E-2246E5F8F810> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                     0x10c355000 -        0x10c3aafff +com.adobe.dvametadata.framework (dvametadata version 5.0.0 - 5.0.0.0) <32AC0DCD-CB83-0756-0C2B-1913CC4C588C> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
                     0x10c422000 -        0x10c529fef +com.adobe.dvametadataDB.framework (dvametadataDB version 5.0.0 - 5.0.0.0) <E416C66A-919D-112C-C6BB-FB82BB7A934F> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvametadataDB
                     0x10c56f000 -        0x10c5f5fff +com.adobe.dvametadataUI.framework (dvametadataUI version 5.0.0 - 5.0.0.0) <8C4B478E-105C-2D6A-88A6-E23977D4CB42> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
                     0x10c680000 -        0x10c697ff3 +com.adobe.dvastoryparser.framework (dvastoryparser version 5.0.0 - 5.0.0.0) <8C196573-AC7D-CC48-4B42-8B093D1DB40B> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvastoryparser.framework/Versions/A/dvastoryparser
                     0x10c6ac000 -        0x10c6f1fff +DynamicLinkMedia (??? - ???) <D795520D-AE5C-BB63-9AA7-B97F5AEFE78C> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
                     0x10c760000 -        0x10c818ff0 +com.diaquest.pro4.omf (1.0.0.1022 - 1.0.0.1022) <AFF2D11A-C6BC-4D70-7490-E50AB3890360> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/Pro4OMF.framework/Versions/A/Pro4OMF
                     0x10c839000 -        0x10c83dff8 +com.adobe.ape.shim (adbeape version 3.1.65.7508 - 3.1.65.7508) <0C380604-C686-C2E4-0535-C1FAB230187E> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                     0x10c841000 -        0x10c8a3ff7 +com.adobe.MediaCore.Frameworks.Utilities.QT32Client (1.0 - 1.0) <217176A4-10FB-2C95-C8F8-25B8785F17EA> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
                     0x10c916000 -        0x10c987fff +PProDynamicLinkServer (??? - ???) <64DB1032-5E68-154D-FD6F-2A20505E5905> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/PProDynamicLinkServer.framework/Versions/A/PProDynamicLinkSer ver
                     0x10ca30000 -        0x10cb73fef +com.adobe.MediaCore.Frameworks.Display (??? - 1.0) <8901E3DC-95CF-BE5D-B3D4-AB4365D369BE> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/Display.framework/Versions/A/Display
                     0x10ce1b000 -        0x10ce7ffff +aif_core (??? - ???) <F3570BB9-0476-0B5D-5A47-2BA7EA411F70> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
                     0x10ce9a000 -        0x10d0c7fff +aif_ogl (??? - ???) <4084ACF3-7D8D-5A58-6F36-435EC858B909> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
                     0x10d1a4000 -        0x10d1c2fff +image_runtime (??? - ???) <A98E3E79-9773-E82B-6AE1-E8A3F30875FB> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
                     0x10d1de000 -        0x10d228fff  com.apple.glut (3.4.9 - GLUT-3.4.9) <B17217E4-837F-35F8-A3EF-243FF2C3557B> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
                     0x10d29a000 -        0x10d2b3feb +libtbb.dylib (??? - ???) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/libtbb.dylib
                     0x10d2c4000 -        0x10d2cafeb +libtbbmalloc.dylib (??? - ???) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/libtbbmalloc.dylib
                     0x10d3d8000 -        0x10d3e0fff +com.adobe.asneu.framework (asneu version 1.7.0.1 - 1.7.0.1) <3D59CB21-F5C7-4232-AB00-DFEB04206024> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
                     0x10d724000 -        0x10d733ffd +com.mainconcept.mc_enc_mpa (8.5 - 8.5.0.14572) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/mc_enc_mpa.framework/Versions/8.5/mc_enc_mpa
                     0x10d750000 -        0x10d769ff3 +com.adobe.MediaCore.Frameworks.QTParser (1.0 - 1.0) <7837A19C-B1B4-3E13-5305-D23DA8BA3334> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
                     0x10d7c3000 -        0x10d7f1ff7  GLRendererFloat (??? - ???) <16DF14A0-7264-31A4-83F6-E6F96CF4AB3D> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
                     0x10fe00000 -        0x10fe31ff7 +com.adobe.MediaCore.ExporterXDCAMHD (1.0 - 1.0) <F5832CBE-D2A3-74D5-3CF6-DAEA01A9930B> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/ExporterXDCAMHD.bundle/Contents/MacOS/ExporterXDCAMHD
                     0x10ffea000 -        0x10ffecfff  com.apple.textencoding.unicode (2.4 - 2.4) <FD4695F4-6110-36C6-AC06-86453E30FF6E> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                     0x110a00000 -        0x110b98ff7  GLEngine (??? - ???) <D770A837-9F8D-3C86-AB33-CBDEF5599CA2> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
                     0x110bcc000 -        0x110cc5fff  libGLProgrammability.dylib (??? - ???) <BCA0FD49-2103-33D8-8801-326C6A62465E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                     0x110ceb000 -        0x110fb2ff7  com.apple.ATIRadeonX3000GLDriver (7.12.9 - 7.1.2) <E0D46EC5-2A19-36AA-AECC-A73219F999F1> /System/Library/Extensions/ATIRadeonX3000GLDriver.bundle/Contents/MacOS/ATIRadeonX3000GLD river
                     0x111a00000 -        0x111a70ff6 +com.adobe.amt.services (AMTServices 3.0.0.64 [BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00] - 3.0.0.64) <52FF1F9B-9991-ECE2-C7E3-09DA1B368CBE> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
                     0x111af7000 -        0x111afbfff  com.apple.audio.AudioIPCPlugIn (1.2.1 - 1.2.1) <46DBC886-A984-36F8-BAC6-CFBAED880258> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
                     0x111c00000 -        0x111c78fef +com.adobe.adobe_caps (adobe_caps 3.0.116.0 - 3.0.116.0) <4A355686-1451-B19A-0C55-DFE49FD2539E> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                     0x1137f0000 -        0x1137f6fff  com.apple.audio.AppleHDAHALPlugIn (2.1.3 - 2.1.3f7) <25F21980-C114-3688-B6E7-FD83052D67B1> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                     0x1157c2000 -        0x1157e9ff1 +com.mainconcept.mc_enc_dv (8.5 - 8.5.0.14572) <46AB8404-6892-F7BF-150E-D8249ECFD0B8> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
                     0x117a83000 -        0x117ac6fff +com.adobe.MediaCore.ImporterQuickTime (1.0 - 1.0) <2388FA12-4964-DC63-2E71-67CA12B92B3C> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/ImporterQuickTime.bundle/Contents/MacOS/ImporterQuickTim e
                     0x117be2000 -        0x117c0cff1 +com.mainconcept.mc_dec_dv (8.5 - 8.5.0.14572) <CFF0820D-B6C1-0DB8-43DE-35169748FD94> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/mc_dec_dv.framework/mc_dec_dv
                     0x117eeb000 -        0x117ef0ff7 +com.adobe.MediaCore.ExporterCoreAudio (1.0 - 1.0) <754198FB-87E2-B57A-9B10-CCEAFA97167B> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/ExporterCoreAudio.bundle/Contents/MacOS/ExporterCoreAudi o
                     0x1183b0000 -        0x1183cbfff  com.apple.carbonframeworktemplate (1.0 - 1.0) <0B262E2C-F292-5BA8-3FE6-15742C3C875E> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/VXMLPresetReader.framework/vxmlpresetreader
                     0x11878f000 -        0x1187d1ff3 +libMXF_SDK_XML_r.4.2.319.dylib (4.2.0 - compatibility 4.2.0) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_XML_r.4.2.319.dylib
                     0x11a988000 -        0x11a9b1fff +libMOG_Framework_r.2.0.8.dylib (2.0.8 - compatibility 2.0.8) <F686FD64-AF59-C0EA-F3E4-FA05E4144F73> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/MOG/Frameworks/libMOG_Framework_r.2.0.8.dylib
                     0x11a9cc000 -        0x11a9dbfe7 +com.adobe.MediaCore.Frameworks.AudioConverter (1.0 - 1.0) <6E7E340B-CE94-39CC-507C-6BDCD8A50E66> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AudioConverter.framework/Versions/A/AudioConverter
                     0x11ae83000 -        0x11afb4fef +com.adobe.premiere.AAFProjectConverter (1.0 - 1.0) <E65421EA-B7FC-B82A-AA36-19308DA66269> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/AAF.bundle/Contents/MacOS/AAF
                     0x11b0b2000 -        0x11b2d3fef +libMXF_SDK_r.4.2.319.dylib (4.2.0 - compatibility 4.2.0) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_r.4.2.319.dylib
                     0x11d41f000 -        0x11d6ebff6 +libxerces-c-3.0.dylib (??? - ???) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/MOG/Frameworks/libxerces-c-3.0.dylib
                     0x11d881000 -        0x11dc56fef +libxqilla.5.0.0.dylib (6.0.0 - compatibility 6.0.0) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/MOG/Frameworks/libxqilla.5.0.0.dylib
                     0x11df1d000 -        0x11df87fe7 +libMXF_SDK_Modules_r.1.1.34.dylib (1.1.0 - compatibility 1.1.0) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_Modules_r.1.1.34.dylib
                     0x11e100000 -        0x11e2e0ff7  com.apple.audio.codecs.Components (2.1 - 2.1) <57D69399-8CD8-36C5-8040-13F38FBC18C3> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
                     0x11e348000 -        0x11e36fff3 +com.adobe.MediaCore.ExporterQuickTimeHost (1.0 - 1.0) <487C05DE-A627-0B08-334E-721B8741E16C> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/ExporterQuickTimeHost.bundle/Contents/MacOS/ExporterQuic kTimeHost
                     0x11e529000 -        0x11e5feff3 +com.mainconcept.mc_mux_mp2 (8.5 - 8.5.0.14572) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/mc_mux_mp2.framework/Versions/8.5/mc_mux_mp2
                     0x11e62d000 -        0x11e73ffef +com.mainconcept.mc_enc_mp2v (8.6 - 8.6.0.14572) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/mc_enc_mp2v.framework/Versions/8.6/mc_enc_mp2v
                     0x11e794000 -        0x11e7c9ffa  com.apple.AVCVideoServices (1.0 - 42) <AE5F5B65-5BBC-B2F3-5033-DF66725B0ED3> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
                     0x11eb00000 -        0x11ec08fff +com.adobe.FCPXProjectConverter (1.0.24 - 1.0.24) <B0328FF8-602F-7684-3C72-1AF0C5E9CCC2> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/FCPXProjectConverter.bundle/Contents/MacOS/FCPXProjectCo nverter
                     0x11ecb8000 -        0x11ecd6fe7 +com.adobe.MediaCore.AudioVideoIO (1.0 - 1.0) <6029FA1D-8906-96CD-ED88-7F97F8DCD290> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AudioVideoIO.framework/Versions/A/AudioVideoIO
                     0x11ef00000 -        0x11ef72fff +com.adobe.MediaCore.PlayerMediaCore (1.0 - 1.0) <1C14A85C-944F-42DC-3232-0E69F9C6C6A4> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/PlayerMediaCore.bundle/Contents/MacOS/PlayerMediaCore
                     0x120000000 -        0x1200d0ff7 +com.adobe.MediaCore.IPPMPEGDecoder (1.0 - 1.0) <93B79ABF-8E77-66ED-BEFC-4C9665084051> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/IPPMPEGDecoder.framework/IPPMPEGDecoder
                     0x120115000 -        0x1202e4fff +com.adobe.MediaCore.ImporterRED (1.01 - 1.0) <90CA825B-903F-0CC8-D29D-199DC2639F8D> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/ImporterRED.bundle/Contents/MacOS/ImporterRED
                     0x120602000 -        0x120611fe4 +com.adobe.MediaCore.PremiereFiltersMetaPlugin (1.0 - 1.0) <8D3D9C8F-57DF-91A0-949A-2847F49CFC1D> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/PremiereFiltersMetaPlugin.prmp/Contents/MacOS/PremiereFi ltersMetaPlugin
                     0x120627000 -        0x120642ff3 +com.adobe.MediaCore.RecorderHDVMac (1.0 - 1.0) <EC4A4386-1E9F-0CAB-85B2-00B7E4847945> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/RecorderHDVMac.bundle/Contents/MacOS/RecorderHDVMac
                     0x120661000 -        0x120817fef +com.mainconcept.mc_dec_mp2v (8.5 - 8.5.0.14572) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/mc_dec_mp2v.framework/Versions/8.5/mc_dec_mp2v
                     0x120820000 -        0x120847fff +com.adobe.MediaCore.RecorderQTKit (1.0 - 1.0) <EA4A8447-4314-83CE-4BB3-786A8AE499F8> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/RecorderQTKit.bundle/Contents/MacOS/RecorderQTKit
                     0x120872000 -        0x120884fe9 +com.adobe.MediaCore.TransitionsMetaPlugin (1.0 - 1.0) <6FDE8686-337E-B4A8-D1ED-021287113CF6> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/TransitionsMetaPlugin.prmp/Contents/MacOS/TransitionsMet aPlugin
                     0x120921000 -        0x12095afff +com.blackmagic-design.premierepro.FileImport (1.0 - 1.0) <5A5DD944-E6F3-E07A-95A4-2E5CC2AC7CE7> /Library/Application Support/Adobe/*/DeckLinkFileImport.bundle/Contents/MacOS/DeckLinkFileImport
                     0x120977000 -        0x1209b2ff7 +com.blackmagic-design.premierepro.Playback (1.0 - 1.0) <4418C448-55E0-499E-4E4B-E816092F604E> /Library/Application Support/Adobe/*/DeckLinkPlayback.bundle/Contents/MacOS/DeckLinkPlayback
                     0x1209d5000 -        0x1209ebff7 +com.blackmagic-design.premierepro.Record (1.0 - 1.0) <BC0B65CC-45DB-72D6-928E-5556CF5FC4B3> /Library/Application Support/Adobe/*/DeckLinkRecord.bundle/Contents/MacOS/DeckLinkRecord
                     0x120f00000 -        0x120f20ffb +com.adobe.ape (adbeapecore version 3.1.70.10055 - 3.1.70.10055) <66373ADB-0865-ECDB-D3D0-B3373FC43919> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
                     0x120fb0000 -        0x120fd8fef +ServiceManager-Launcher.dylib (??? - ???) <4608E5E7-7F22-A4FF-527C-E97EA339FCCC> /Library/Application Support/Adobe/*/ServiceManager-Launcher.dylib
                     0x124911000 -        0x124912fff +libgmodule-2.0.0.dylib (2105.0.0 - compatibility 2105.0.0) <FBA9AA26-3875-5E84-C222-59EAF6093049> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/AAF.bundle/Contents/Frameworks/libgmodule-2.0.0.dylib
                     0x124fa7000 -        0x124fc7ff7 +com.blackmagic-design.cmio.DeckLinkCMIO (1.0 - 1) <AE2C06C2-10E4-3FE7-868B-CFECFE80A938> /Library/CoreMediaIO/*/DeckLinkCMIO.plugin/Contents/MacOS/DeckLinkCMIO
                     0x124fce000 -        0x12508afef +com.blackmagic-design.DeckLinkAPI (8.6 - 8.6) <B3C9829D-E4FB-316D-C202-2BC16510E116> /Library/Application Support/Blackmagic Design/*/DeckLinkAPI.bundle/Contents/MacOS/DeckLinkAPI
                     0x125a0d000 -        0x125a37fff  com.apple.cmio.DAL.VDC_4 (210.0 - 3180) <3C963342-7F33-33D9-BB82-4BBEB8D18ADB> /System/Library/Frameworks/CoreMediaIO.framework/Resources/VDC.plugin/Contents/MacOS/VDC
                     0x125c58000 -        0x125c58ffd +cl_kernels (??? - ???) <21CCDA7F-5FE7-4708-8DA6-1A1AD1B2E08D> cl_kernels
                     0x125c69000 -        0x125c6ffef  libcldcpuengine.dylib (1.50.61 - compatibility 1.0.0) <EAC03E33-595E-3829-8199-479FA5CD9987> /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine.dylib
                     0x125c75000 -        0x125c78ff7  libCoreFSCache.dylib (??? - ???) <D4B5EFEA-7878-3674-A973-BA1D675E5A3C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                     0x125c89000 -        0x125c8affc +cl_kernels (??? - ???) <BDEF191E-330D-4818-8163-19AEE94873FB> cl_kernels
                     0x125ce9000 -        0x125cf8ff7  libSimplifiedChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <D5083346-BF48-325F-9399-06F4F9D7986C> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                     0x126b7e000 -        0x126b80ffa +com.adobe.MediaCore.Opacity (1.0 - 1.0) <91B01C3E-B8D2-BF04-FE6B-ABF55915869A> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/Opacity.bundle/Contents/MacOS/Opacity
                     0x126b85000 -        0x126b88ff3 +com.adobe.PProAEFilter.Fast_Blur (??? - 1.0) <F7296633-6685-F763-D46E-33BD1DC8CD2E> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/Fast_Blur.bundle/Contents/MacOS/Fast_Blur
                     0x126b8c000 -        0x126b8ffff +com.adobe.PProAEFilter.Drop_Shadow (??? - 1.0) <CF5D48E5-552B-5BF7-1BA5-DC9DB6E6BC4D> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/Drop_Shadow.bundle/Contents/MacOS/Drop_Shadow
                     0x126b93000 -        0x126b95fff +com.adobe.MediaCore.Motion (1.0 - 1.0) <B1A10995-3DDF-7170-164A-8EF0FAB66EA4> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/Motion.bundle/Contents/MacOS/Motion
                     0x126bc4000 -        0x126bdffff  libJapaneseConverter.dylib (54.0.0 - compatibility 1.0.0) <489CAB2F-2854-3435-81CD-A062384016F7> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                     0x126be4000 -        0x126c05fff  libKoreanConverter.dylib (54.0.0 - compatibility 1.0.0) <32EBCCBC-E862-3888-8202-B01053FDFECA> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                     0x126c09000 -        0x126c1bff7  libTraditionalChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <8F0BC42F-025B-3803-9C3E-FBD99199DFAA> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                     0x126f2a000 -        0x126f2ffff +com.adobe.MediaCore.AEFilterCrop (1.0 - 1.0) <E4D1B5BA-03BB-0569-07FA-1BD132DA261C> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/AEFilterCrop.bundle/Contents/MacOS/AEFilterCrop
                     0x126f34000 -        0x126f36ff7 +com.adobe.MediaCore.AEFilterGaussianBlur (1.0 - 1.0) <A5C43779-D0E7-6FB0-031B-BFD67D5A66FA> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/AEFilterGaussianBlur.bundle/Contents/MacOS/AEFilterGauss ianBlur
                     0x127e92000 -        0x127e93ff7 +com.adobe.PProAEFilter.Bevel_Edges (??? - 1.0) <83675930-3F36-FD44-4CCB-8E51F358B3E9> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/Bevel_Edges.bundle/Contents/MacOS/Bevel_Edges
                     0x127e96000 -        0x127e96ff7 +com.adobe.PProAEFilter.Mosaic (??? - 1.0) <27B0F777-C843-1150-67BA-276DFAB57090> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/Mosaic.bundle/Contents/MacOS/Mosaic
                     0x1292dd000 -        0x1292e2fff +com.adobe.PProAEFilter.Twirl (??? - 1.0) <AE28819F-C3A4-C69E-76DD-E1CBA897DA3B> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/Twirl.bundle/Contents/MacOS/Twirl
                     0x129324000 -        0x129325ff3 +cl_kernels (??? - ???) <8CEF2683-29ED-4B84-8C41-00F530D9EE72> cl_kernels
                     0x12a316000 -        0x12a317ff3 +cl_kernels (??? - ???) <56FA0317-5785-4920-ACED-268A97821505> cl_kernels
                     0x12a41a000 -        0x12b282ff3 +com.adobe.adobeswfl (??? - 2.0.0.10053) <ADE7E8AA-80B6-7BAC-8205-13D7A0E89DF8> /Library/Application Support/Adobe/*/adbeapecore.framework/Resources/AdobeSWFL.bundle/Contents/MacOS/AdobeSWFL
                     0x12b484000 -        0x12b4c1feb +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 1.0.0.64 - 1.0.0.64) <CD8BD7C7-0F66-29B6-C158-A6EF8DF69996> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotification s
                     0x12e3e9000 -        0x12e3ecfff  libLatinSuppConverter.dylib (54.0.0 - compatibility 1.0.0) <7E087B67-5698-34B6-9F16-1E0C1C3FF0DD> /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
                     0x131e07000 -        0x131e3dff3 +libgsf-1.114.dylib (115.15.0 - compatibility 115.0.0) <AF0F6CA7-FB5C-3099-D3C7-77EC8DCA7A8D> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/AAF.bundle/Contents/Frameworks/libgsf-1.114.dylib
                     0x131e52000 -        0x131e5eff3 +libintl.8.dylib (9.2.0 - compatibility 9.0.0) <A808F363-25EC-7D66-8217-E5FA85E88522> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/AAF.bundle/Contents/Frameworks/libintl.8.dylib
                     0x131f89000 -        0x13201cff7  unorm8_bgra.dylib (1.50.61 - compatibility 1.0.0) <3ED8B0D5-4A55-3E39-8490-B7BC1780F67B> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_bgra.dylib
                     0x13203b000 -        0x1320ccff7  unorm8_rgba.dylib (1.50.61 - compatibility 1.0.0) <278541F2-18CC-3BE4-AD6B-24A3E983ACB5> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_rgba.dylib
                     0x132699000 -        0x1326cbff7 +libgobject-2.0.0.dylib (2105.0.0 - compatibility 2105.0.0) <62BBBD25-6FED-A5A9-8405-CD30FD950D6E> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/AAF.bundle/Contents/Frameworks/libgobject-2.0.0.dylib
                     0x1382b3000 -        0x138603fff +libcom-api.dylib (??? - ???) <F2E64BCC-5950-102F-C3AE-5C3242923210> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/libcom-api.dylib
                     0x1388fd000 -        0x1389dbfef +libglib-2.0.0.dylib (2105.0.0 - compatibility 2105.0.0) <308CC206-1D7D-C204-AE71-2BE93520041E> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/AAF.bundle/Contents/Frameworks/libglib-2.0.0.dylib
                     0x1389f4000 -        0x138a79fec +libgio-2.0.0.dylib (2105.0.0 - compatibility 2105.0.0) <C6024225-E733-ACF2-3BE9-71F47B055754> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-ins/Common/AAF.bundle/Contents/Frameworks/libgio-2.0.0.dylib
                  0x7fff6ec63000 -     0x7fff6ec97ac7  dyld (195.5 - ???) <4A6E2B28-C7A2-3528-ADB7-4076B9836041> /usr/lib/dyld
                  0x7fff86138000 -     0x7fff8613bfff  libRadiance.dylib (??? - ???) <CD89D70D-F177-3BAE-8A26-644EA7D5E28E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
                  0x7fff8613c000 -     0x7fff862dbfff  com.apple.QuartzCore (1.7 - 270.0) <E8FC9AA4-A5CB-384B-AD29-7190A1387D3E> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                  0x7fff862dc000 -     0x7fff8636efff  com.apple.CorePDF (3.0 - 3.0) <6056B710-155A-3543-9373-B9F3E5FC99CE> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                  0x7fff8636f000 -     0x7fff863e2fff  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <6BDD43E4-A4B1-379E-9ED5-8C713653DFF2> /usr/lib/libstdc++.6.dylib
                  0x7fff863e3000 -     0x7fff8651cfef  com.apple.vImage (5.1 - 5.1) <EB634387-CD15-3246-AC28-5FB368ACCEA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                  0x7fff8651d000 -     0x7fff86570fff  libFontRegistry.dylib (??? - ???) <57FBD85F-41A6-3DB9-B5F4-FCC6B260F1AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                  0x7fff86571000 -     0x7fff8698dff7  com.apple.SceneKit (2.1 - 125.1) <296A889C-2E9D-366F-8962-E23931EECC70> /System/Library/PrivateFrameworks/SceneKit.framework/Versions/A/SceneKit
                  0x7fff8698e000 -     0x7fff869ceff7  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <B7173CA4-CE16-3BAB-8D83-185FCEFA15F5> /usr/lib/libcups.2.dylib
                  0x7fff869cf000 -     0x7fff86ce8ff7  com.apple.Foundation (6.7.1 - 833.20) <D922F590-FDA6-3D89-A271-FD35E2290624> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                  0x7fff86cfc000 -     0x7fff878fdff7  com.apple.AppKit (6.7.2 - 1138.23) <5CD2C850-4F52-3BA2-BA11-3107DFD2D23C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                  0x7fff878fe000 -     0x7fff8791bff7  com.apple.openscripting (1.3.3 - ???) <A64205E6-D3C5-3E12-B1A0-72243151AF7D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                  0x7fff8791c000 -     0x7fff87b97fff  com.apple.imageKit (2.1.1 - 1.0) <9C159577-0FFF-34D8-890E-66627A9E44FB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                  0x7fff87b98000 -     0x7fff87bcdfff  libTrueTypeScaler.dylib (??? - ???) <B326A78E-C65A-345E-8D64-62B45CC6FA3F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
                  0x7fff87bce000 -     0x7fff87bd2fff  libdyld.dylib (195.5.0 - compatibility 1.0.0) <F1903B7A-D3FF-3390-909A-B24E09BAD1A5> /usr/lib/system/libdyld.dylib
                  0x7fff87bd3000 -     0x7fff87bf0fff  com.apple.frameworks.preferencepanes (15.0 - 15.0) <ABF4E917-A452-3B86-B071-948F4B6A3CD3> /System/Library/Frameworks/PreferencePanes.framework/Versions/A/PreferencePanes
                  0x7fff87bf1000 -     0x7fff87bf1fff  com.apple.quartzframework (1.5 - 1.5) <21FCC91F-C7B9-304F-8C9C-04F3924F4AE3> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                  0x7fff87bf8000 -     0x7fff87dfafff  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <38CD6ED3-C8E4-3CCD-89AC-9C3198803101> /usr/lib/libicucore.A.dylib
                  0x7fff87dfb000 -     0x7fff87e4fff7  com.apple.ImageCaptureCore (3.0.1 - 3.0.1) <5D86BECB-9F7A-3FDB-9436-C3DE4B2A5F29> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                  0x7fff87e50000 -     0x7fff88434fff  libBLAS.dylib (??? - ???) <C34F6D88-187F-33DC-8A68-C0C9D1FA36DF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                  0x7fff88435000 -     0x7fff884d4fff  com.apple.LaunchServices (480.21 - 480.21) <6BFADEA9-5BC1-3B53-A013-488EB7F1AB57> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                  0x7fff884d5000 -     0x7fff886effef  com.apple.CoreData (104 - 358.12) <33B1FA75-7970-3751-9DCC-FF809D3E1FA2> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                  0x7fff889cc000 -     0x7fff889cdfff  libunc.dylib (24.0.0 - compatibility 1.0.0) <C67B3B14-866C-314F-87FF-8025BEC2CAAC> /usr/lib/system/libunc.dylib
                  0x7fff889ce000 -     0x7fff896d4fef  com.apple.WebCore (7534.51 - 7534.51.22) <352D30ED-1D1D-390E-B7CB-18E954485FD3> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
                  0x7fff896d7000 -     0x7fff89704ff7  com.apple.opencl (1.50.63 - 1.50.63) <DB335C5C-3ABD-38C8-B6A5-8436EE1484D3> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                  0x7fff89705000 -     0x7fff8972cfff  com.apple.framework.internetaccounts (1.1 - 2) <B01A08DC-2735-3783-B0C8-63492BD845CF> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/InternetAccounts
                  0x7fff8972d000 -     0x7fff89795ff7  com.apple.audio.CoreAudio (4.0.1 - 4.0.1) <7966E3BE-376B-371A-A21D-9BD763C0BAE7> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                  0x7fff89796000 -     0x7fff897d0fff  com.apple.DebugSymbols (2.1 - 85) <AEF473A5-25BF-3FB7-9A07-320D9CB85959> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                  0x7fff897dd000 -     0x7fff897e1fff  libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <5EEAD17D-006C-3855-8093-C7A4A97EE0D0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
                  0x7fff898c9000 -     0x7fff898f2fff  com.apple.datadetectors (3.0 - 172.3) <7C8B98DD-68C0-3AE0-BCD9-55CBD63925B7> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
                  0x7fff898f3000 -     0x7fff89936ff7  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <2B1571E1-8E87-364E-BC36-C9C9B5D3EAC4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
                  0x7fff89937000 -     0x7fff89972fff  com.apple.LDAPFramework (3.0 - 120.1) <0C23534F-A8E7-3144-B2B2-50F9875101E2> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                  0x7fff89973000 -     0x7fff899f7ff7  com.apple.ApplicationServices.ATS (317.5.0 - ???) <FE629F2D-6BC0-3A58-9844-D8B9A6808A00> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                  0x7fff89a09000 -     0x7fff89afefff  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <5C40E880-0706-378F-B864-3C2BD922D926> /usr/lib/libiconv.2.dylib
                  0x7fff89aff000 -     0x7fff89b11ff7  libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <6245B497-784B-355C-98EF-2DC6B45BF05C> /usr/lib/libsasl2.2.dylib
                  0x7fff89b12000 -     0x7fff89b13fff  libsystem_sandbox.dylib (??? - ???) <8D14139B-B671-35F4-9E5A-023B4C523C38> /usr/lib/system/libsystem_sandbox.dylib
                  0x7fff8a969000 -     0x7fff8aa03ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <4E70C394-773E-3A4B-A93C-59A88ABA9509> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                  0x7fff8aa04000 -     0x7fff8aa06ff7  com.apple.print.framework.Print (7.1 - 247.1) <8A4925A5-BAA3-373C-9B5D-03E0270C6B12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                  0x7fff8aa07000 -     0x7fff8ae34fff  libLAPACK.dylib (??? - ???) <4F2E1055-2207-340B-BB45-E4F16171EE0D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                  0x7fff8ae35000 -     0x7fff8ae3afff  libGIF.dylib (??? - ???) <393E2DB5-9479-39A6-A75A-B5F20B852532> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
                  0x7fff8b0ca000 -     0x7fff8b121fff  com.apple.Suggestions (1.0 - 85.0) <CC8986E7-65EF-3CE5-9058-B082EB19DFFA> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
                  0x7fff8b122000 -     0x7fff8b149fff  com.apple.PerformanceAnalysis (1.10 - 10) <2A058167-292E-3C3A-B1F8-49813336E068> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                  0x7fff8b14a000 -     0x7fff8b499fff  com.apple.FinderKit (1.0.1 - 1.0.1) <6549E97F-041F-3FDD-BC6F-FC3FBCF20F98> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
                  0x7fff8b49a000 -     0x7fff8b4fefff  com.apple.Symbolication (1.2 - 83.1) <0C6F8907-6829-3409-99AC-ACC62923DE98> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                  0x7fff8b501000 -     0x7fff8b55dfff  com.apple.QuickLookFramework (3.1 - 500.1) <0C9E98D2-D8F9-3161-9809-0D77B98AD938> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                  0x7fff8b582000 -     0x7fff8b582fff  com.apple.audio.units.AudioUnit (1.7.1 - 1.7.1) <04C10813-CCE5-3333-8C72-E8E35E417B3B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                  0x7fff8b583000 -     0x7fff8b615ff7  com.apple.PDFKit (2.6.1 - 2.6.1) <33A0A777-8CF4-3F36-BB1A-78F8A3D7E8C2> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                  0x7fff8b616000 -     0x7fff8b676fff  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <3A7521E6-5510-3FA7-AB65-79693A7A5839> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                  0x7fff8b72f000 -     0x7fff8b834ff7  libFontParser.dylib (??? - ???) <B9A53808-C97E-3293-9C33-1EA9D4E83EC8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                  0x7fff8b835000 -     0x7fff8b8b8fef  com.apple.Metadata (10.7.0 - 627.20) <E00156B0-663A-35EF-A307-A2CEB00F1845> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                  0x7fff8b8b9000 -     0x7fff8b93eff7  com.apple.Heimdal (2.1 - 2.0) <C92E327E-CB5F-3C9B-92B0-F1680095C8A3> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                  0x7fff8b9a2000 -     0x7fff8b9a2fff  com.apple.vecLib (3.7 - vecLib 3.7) <9A58105C-B36E-35B5-812C-4ED693F2618F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                  0x7fff8b9a3000 -     0x7fff8b9bafff  com.apple.CFOpenDirectory (10.7 - 144) <9709423E-8484-3B26-AAE8-EF58D1B8FB3F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                  0x7fff8b9bf000 -     0x7fff8ba12fff  com.apple.AppleVAFramework (5.0.14 - 5.0.14) <45159B9E-05BF-35B2-AF76-D933490FBFB1> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                  0x7fff8ba13000 -     0x7fff8ba1bfff  libsystem_dnssd.dylib (??? - ???) <7749128E-D0C5-3832-861C-BC9913F774FA> /usr/lib/system/libsystem_dnssd.dylib
                  0x7fff8ba1c000 -     0x7fff8ba5dfff  com.apple.QD (3.12 - ???) <4F3C5629-97C7-3E55-AF3C-ACC524929DA2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                  0x7fff8ba5e000 -     0x7fff8baccfff  com.apple.CoreSymbolication (2.1 - 66) <E1582596-4157-3535-BF1F-3BAE92A0B09F> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                  0x7fff8bacd000 -     0x7fff8badbfff  com.apple.NetAuth (1.0 - 3.0) <F384FFFD-70F6-3B1C-A886-F5B446E456E7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                  0x7fff8badc000 -     0x7fff8c270fef  com.apple.CoreAUC (6.11.04 - 6.11.04) <FFC336DF-C71F-3C93-8E93-5CBD9EEAE940> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                  0x7fff8c271000 -     0x7fff8c29cff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <8051A3FC-7385-3EA9-9634-78FC616C3E94> /usr/lib/libxslt.1.dylib
                  0x7fff8c29d000 -     0x7fff8c63bfef  com.apple.MediaToolbox (1.0 - 705.42) <BF05C02D-3202-3FF8-A334-C14AF7C89F9E> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                  0x7fff8c64a000 -     0x7fff8c756fff  libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <3A8E1F89-5E26-3C8B-B538-81F5D61DBF8A> /usr/lib/libcrypto.0.9.8.dylib
                  0x7fff8c757000 -     0x7fff8ce6a587  com.apple.CoreGraphics (1.600.0 - ???) <A9F2451E-6F60-350E-A6E5-539669B53074> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                  0x7fff8ce6b000 -     0x7fff8cf48fef  libsystem_c.dylib (763.12.0 - compatibility 1.0.0) <FF69F06E-0904-3C08-A5EF-536FAFFFDC22> /usr/lib/system/libsystem_c.dylib
                  0x7fff8cf49000 -     0x7fff8cf4efff  libcache.dylib (47.0.0 - compatibility 1.0.0) <B7757E2E-5A7D-362E-AB71-785FE79E1527> /usr/lib/system/libcache.dylib
                  0x7fff8cf4f000 -     0x7fff8cf6cff7  libxpc.dylib (77.17.0 - compatibility 1.0.0) <72A16104-2F23-3C22-B474-1953F06F9376> /usr/lib/system/libxpc.dylib
                  0x7fff8cf6d000 -     0x7fff8d04bfff  com.apple.ImageIO.framework (3.1.1 - 3.1.1) <13E549F8-5BD6-3BAE-8C33-1D0BD269C081> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
                  0x7fff8d056000 -     0x7fff8d058fff  com.apple.TrustEvaluationAgent (2.0 - 1) <1F31CAFF-C1C6-33D3-94E9-11B721761DDF> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                  0x7fff8d059000 -     0x7fff8d0cffff  com.apple.ISSupport (1.9.8 - 56) <2CEE7E6B-D841-36D8-BC9F-081B33F6E501> /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
                  0x7fff8dabd000 -     0x7fff8dad0ff7  libCRFSuite.dylib (??? - ???) <034D4DAA-63F0-35E4-BCEF-338DD7A453DD> /usr/lib/libCRFSuite.dylib
                  0x7fff8db21000 -     0x7fff8dc2efff  libJP2.dylib (??? - ???) <6052C973-9354-35CB-AAB9-31D00D8786F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJP2.dylib
                  0x7fff8dc2f000 -     0x7fff8dc3aff7  com.apple.speech.recognition.framework (4.0.19 - 4.0.19) <7ADAAF5B-1D78-32F2-9FFF-D2E3FBB41C2B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                  0x7fff8dc3b000 -     0x7fff8dc61ff7  com.apple.framework.familycontrols (3.0 - 300) <41A6DFC2-EAF5-390A-83A1-C8832528705C> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                  0x7fff8dcc8000 -     0x7fff8dd03ff7  libsystem_info.dylib (??? - ???) <9C8C2DCB-96DB-3471-9DCE-ADCC26BE2DD4> /usr/lib/system/libsystem_info.dylib
                  0x7fff8dd04000 -     0x7fff8dd12fff  com.apple.HelpData (2.1.0 - 70) <917CF02F-276E-3571-9042-AAAAC0D3D4E1> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
                  0x7fff8dd13000 -     0x7fff8de16fff  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <7F60B0FF-4946-3639-89AB-B540D318B249> /usr/lib/libsqlite3.dylib
                  0x7fff8de17000 -     0x7fff8de92ff7  com.apple.print.framework.PrintCore (7.1 - 366.1) <3F140DEB-9F87-3672-97CC-F983752581AC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                  0x7fff8dedc000 -     0x7fff8def6fff  com.apple.CoreMediaAuthoring (2.0 - 889) <99D8E4C6-DDD3-3B0C-BBFB-A513877F10F6> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                  0x7fff8df1f000 -     0x7fff8df3cfff  libPng.dylib (??? - ???) <3C70A94C-9442-3E11-AF51-C1B0EF81680E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
                  0x7fff8df3d000 -     0x7fff8e024fff  com.apple.backup.framework (1.3.1 - 1.3.1) <3F01784C-3C09-3F08-B949-779F0A5248C1> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                  0x7fff8e025000 -     0x7fff8e02fff7  liblaunch.dylib (392.18.0 - compatibility 1.0.0) <39EF04F2-7F0C-3435-B785-BF283727FFBD> /usr/lib/system/liblaunch.dylib
                  0x7fff8e030000 -     0x7fff8e030fff  com.apple.Accelerate (1.7 - Accelerate 1.7) <82DDF6F5-FBC3-323D-B71D-CF7ABC5CF568> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                  0x7fff8e031000 -     0x7fff8e0d3ff7  com.apple.securityfoundation (5.0 - 55005) <0D59908C-A61B-389E-AF37-741ACBBA6A94> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                  0x7fff8e0e9000 -     0x7fff8e405ff7  com.apple.CoreServices.CarbonCore (960.18 - 960.18) <6020C3FB-6125-3EAE-A55D-1E77E38BEDEA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                  0x7fff8e406000 -     0x7fff8e425fff  libresolv.9.dylib (46.0.0 - compatibility 1.0.0) <33263568-E6F3-359C-A4FA-66AD1300F7D4> /usr/lib/libresolv.9.dylib
                  0x7fff8e426000 -     0x7fff8e53eff7  com.apple.DesktopServices (1.6.1 - 1.6.1) <4418EAA6-7163-3A77-ABD3-F8289796C81A> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                  0x7fff8e53f000 -     0x7fff8e860fff  com.apple.AddressBook.framework (6.1 - 1062) <94321204-A094-3BBE-8EA6-6048D39F4E54> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
                  0x7fff8e861000 -     0x7fff8e8d6ff7  libc++.1.dylib (19.0.0 - compatibility 1.0.0) <C0EFFF1B-0FEB-3F99-BE54-506B35B555A9> /usr/lib/libc++.1.dylib
                  0x7fff8e8d7000 -     0x7fff8e8ddff7  com.apple.phonenumbers (1.0 - 47) <8CE13253-C65B-392F-B87F-D85A15D500D3> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
                  0x7fff8e8de000 -     0x7fff8e902fff  com.apple.Kerberos (1.0 - 1) <1F826BCE-DA8F-381D-9C4C-A36AA0EA1CB9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                  0x7fff8e903000 -     0x7fff8e96dfff  com.apple.framework.IOKit (2.0 - ???) <87D55F1D-CDB5-3D13-A5F9-98EA4E22F8EE> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                  0x7fff8e96e000 -     0x7fff8ee35fff  FaceCoreLight (1.4.7 - compatibility 1.0.0) <E9D2A69C-6E81-358C-A162-510969F91490> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
                  0x7fff8ee40000 -     0x7fff8ee41fff  libdnsinfo.dylib (395.6.0 - compatibility 1.0.0) <718A135F-6349-354A-85D5-430B128EFD57> /usr/lib/system/libdnsinfo.dylib
                  0x7fff8ee87000 -     0x7fff8eed5fff  libauto.dylib (??? - ???) <D8AC8458-DDD0-3939-8B96-B6CED81613EF> /usr/lib/libauto.dylib
                  0x7fff8ef29000 -     0x7fff8ef2afff  liblangid.dylib (??? - ???) <CACBE3C3-2F7B-3EED-B50E-EDB73F473B77> /usr/lib/liblangid.dylib
                  0x7fff8ef2b000 -     0x7fff8ef30fff  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <D952F17B-200A-3A23-B9B2-7C1F7AC19189> /usr/lib/libpam.2.dylib
                  0x7fff8ef31000 -     0x7fff8ef31fff  com.apple.ApplicationServices (41 - 41) <03F3FA8F-8D2A-3AB6-A8E3-40B001116339> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                  0x7fff8ef32000 -     0x7fff8ef35fff  com.apple.help (1.3.2 - 42) <AB67588E-7227-3993-927F-C9E6DAC507FD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                  0x7fff8efaa000 -     0x7fff8f08edef  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <C5F2392D-B481-3A9D-91BE-3D039FFF4DEC> /usr/lib/libobjc.A.dylib
                  0x7fff8f08f000 -     0x7fff8f090fff  com.apple.MonitorPanelFramework (1.4.0 - 1.4.0) <0F55CD76-DB24-309B-BD12-62B00C1AAB9F> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
                  0x7fff8f091000 -     0x7fff8f0bafff  com.apple.CoreServicesInternal (113.8 - 113.8) <C1A3CF1B-BC45-3FC6-82B3-1511EBBA9D51> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                  0x7fff8f0e3000 -     0x7fff8f1e1fff  com.apple.QuickLookUIFramework (3.1 - 500.1) <D3A71FF1-7ED1-39DB-AD4E-451612DA536C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                  0x7fff8f1e2000 -     0x7fff8f1f9fff  com.apple.MultitouchSupport.framework (220.62.1 - 220.62.1) <F21C79C0-4B5A-3645-81A6-74F8EFA900CE> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                  0x7fff8f1fa000 -     0x7fff8f200fff  IOSurface (??? - ???) <06FA3FDD-E6D5-391F-B60D-E98B169DAB1B> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                  0x7fff8f201000 -     0x7fff8f282ff7  libType1Scaler.dylib (??? - ???) <272DE5FE-9A91-3283-9212-84F7DD53B71C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
                  0x7fff8f283000 -     0x7fff8f284ff7  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <8BCA214A-8992-34B2-A8B9-B74DEACA1869> /usr/lib/system/libsystem_blocks.dylib
                  0x7fff8f285000 -     0x7fff8f28bff7  libunwind.dylib (30.0.0 - compatibility 1.0.0) <1E9C6C8C-CBE8-3F4B-A5B5-E03E3AB53231> /usr/lib/system/libunwind.dylib
                  0x7fff8f28c000 -     0x7fff8f2b5fff  libJPEG.dylib (??? - ???) <64D079F9-256A-323B-A837-84628B172F21> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
                  0x7fff8f2b6000 -     0x7fff8f2b6fff  com.apple.Carbon (153 - 153) <895C2BF2-1666-3A59-A669-311B1F4F368B> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                  0x7fff8f2b7000 -     0x7fff8f2bdfff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <CEA34337-63DE-302E-81AA-10D717E1F699> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                  0x7fff8f2be000 -     0x7fff8f2defff  libsystem_kernel.dylib (1699.22.73 - compatibility 1.0.0) <69F2F501-72D8-3B3B-8357-F4418B3E1348> /usr/lib/system/libsystem_kernel.dylib
                  0x7fff8f2df000 -     0x7fff8f2e4fff  com.apple.OpenDirectory (10.7 - 146) <91A87249-6A2F-3F89-A8DE-0E95C0B54A3A> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                  0x7fff8f32b000 -     0x7fff8f75dfff  com.apple.VideoToolbox (1.0 - 705.42) <FA0AD643-845C-3378-AFD1-8C5BD0215B72> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                  0x7fff8f75e000 -     0x7fff8f773fff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <C061ECBB-7061-3A43-8A18-90633F943295> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                  0x7fff8f774000 -     0x7fff8f786ff7  libbsm.0.dylib (??? - ???) <349BB16F-75FA-363F-8D98-7A9C3FA90A0D> /usr/lib/libbsm.0.dylib
                  0x7fff8f787000 -     0x7fff8f8e0fff  com.apple.audio.toolbox.AudioToolbox (1.7.1 - 1.7.1) <4877267E-F736-3019-85D3-40A32A042A80> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                  0x7fff8f8e9000 -     0x7fff8f99cfff  com.apple.CoreText (220.11.0 - ???) <4EA8E2DF-542D-38D5-ADB9-C0DAA73F898B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
                  0x7fff8f9ec000 -     0x7fff8f9edfff  libDiagnosticMessagesClient.dylib (??? - ???) <3DCF577B-F126-302B-BCE2-4DB9A95B8598> /usr/lib/libDiagnosticMessagesClient.dylib
                  0x7fff8f9ee000 -     0x7fff8fa0aff7  com.apple.GenerationalStorage (1.0 - 125) <31F60175-E38D-3C63-8D95-32CFE7062BCB> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                  0x7fff8fb02000 -     0x7fff8fb32ff7  com.apple.DictionaryServices (1.2.1 - 158.2) <3FC86118-7553-38F7-8916-B329D2E94476> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                  0x7fff8fbb6000 -     0x7fff8fc5afef  com.apple.ink.framework (1.3.2 - 110) <F69DBD44-FEC8-3C14-8131-CC0245DBBD42> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                  0x7fff8fc5b000 -     0x7fff8fc5eff7  com.apple.securityhi (4.0 - 1) <B37B8946-BBD4-36C1-ABC6-18EDBC573F03> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                  0x7fff8fc5f000 -     0x7fff900cdfff  com.apple.RawCamera.bundle (3.8.2 - 579) <3D4EBC1A-4139-3E22-B407-0D4887D8D208> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                  0x7fff900ce000 -     0x7fff90341fff  com.apple.CoreImage (7.82 - 1.0.1) <282801B6-5D80-3E2C-88A4-00FE29906D5A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
                  0x7fff90342000 -     0x7fff9034dff7  com.apple.DisplayServicesFW (2.5.2 - 317) <48964503-D7F0-3567-9594-E6AA9C9300EF> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                  0x7fff90353000 -     0x7fff9035aff7  com.apple.CommerceCore (1.0 - 17) <AA783B87-48D4-3CA6-8FF6-0316396022F4> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                  0x7fff9039d000 -     0x7fff906c1fff  com.apple.HIToolbox (1.8 - ???) <A3BE7C59-52E6-3A7F-9B30-24B7DD3E95F2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                  0x7fff906c2000 -     0x7fff906c6ff7  com.apple.CommonPanels (1.2.5 - 94) <0BB2C436-C9D5-380B-86B5-E355A7711259> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                  0x7fff906c7000 -     0x7fff906f4fff  com.apple.quartzfilters (1.7.0 - 1.7.0) <ED846829-EBF1-3E2F-9EA6-D8743E5A4784> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                  0x7fff906f5000 -     0x7fff9087fff7  com.apple.QTKit (7.7.1 - 2306) <A97042BD-4FD8-3556-9279-6B7742C98904> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                  0x7fff908c0000 -     0x7fff908ceff7  com.apple.AppleFSCompression (37 - 1.0) <88C436E8-38AE-3D96-A8C8-2D1805CC47B7> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                  0x7fff908cf000 -     0x7fff9092aff7  com.apple.HIServices (1.10 - ???) <BAB8B422-7047-3D2D-8E0A-13FCF153E4E7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                  0x7fff90b32000 -     0x7fff90bf9ff7  ColorSyncDeprecated.dylib (4.6.0 - compatibility 1.0.0) <B3E00682-FD14-30C3-AE7D-2B16655AD469> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
                  0x7fff90bfa000 -     0x7fff90c51fff  libTIFF.dylib (??? - ???) <FF0D9A24-6956-3F03-81EA-3EEAD22C9DB8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
                  0x7fff90c52000 -     0x7fff90c57fff  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <98ECD5F6-E85C-32A5-98CD-8911230CB66A> /usr/lib/system/libcompiler_rt.dylib
                  0x7fff90c61000 -     0x7fff90ca7ff7  libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <EAF61ADC-DC00-34CE-B23E-7238ED54E31D> /usr/lib/libcurl.4.dylib
                  0x7fff90cc6000 -     0x7fff90cd3ff7  libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <8EDE3492-D916-37B2-A066-3E0F054411FD> /usr/lib/libbz2.1.0.dylib
                  0x7fff90cd4000 -     0x7fff90cd4fff  com.apple.Cocoa (6.6 - ???) <021D4214-9C23-3CD8-AFB2-F331697A4508> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                  0x7fff90cd5000 -     0x7fff90d1efff  com.apple.framework.CoreWLAN (2.1.1 - 211.3) <0FBC6087-6872-3403-A317-CE888969CF4C> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                  0x7fff90d1f000 -     0x7fff90d4ffff  com.apple.shortcut (2.0 - 2.0) <6E6C9F01-5DAC-35F4-876D-082D915EE782> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
                  0x7fff90d50000 -     0x7fff90d8efff  com.apple.bom (11.0 - 183) <841FA160-A37A-368D-B14E-27AA9DD1AEDA> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
                  0x7fff90d8f000 -     0x7fff90db3ff7  com.apple.RemoteViewServices (1.2 - 39) <862849C8-84C1-32A1-B87E-B29E74778C9F> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                  0x7fff90db4000 -     0x7fff90dc0fff  com.apple.DirectoryService.Framework (10.7 - 146) <BB0240B0-69F7-38FA-A8D8-9C0079F8613F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                  0x7fff90dc1000 -     0x7fff90e11fff  com.apple.CoreMediaIO (210.0 - 3180) <13374EA4-83BE-3407-B9DD-D199426D0E7A> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                  0x7fff90e12000 -     0x7fff90e3bff7  com.apple.framework.Apple80211 (7.1.1 - 711.1) <FD0675E6-6602-3C28-85AA-6A4AF6B36D78> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                  0x7fff9103f000 -     0x7fff911a5fff  com.apple.CFNetwork (520.2.5 - 520.2.5) <406712D9-3F0C-3763-B4EB-868D01F1F042> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
                  0x7fff911a6000 -     0x7fff911dffe7  libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <79AAEC98-1258-3DA4-B1C0-4120049D390B> /usr/lib/libssl.0.9.8.dylib
                  0x7fff91351000 -     0x7fff9135cff7  libc++abi.dylib (14.0.0 - compatibility 1.0.0) <8FF3D766-D678-36F6-84AC-423C878E6D14> /usr/lib/libc++abi.dylib
                  0x7fff9135d000 -     0x7fff91392fff  com.apple.securityinterface (5.0 - 55004) <790DDF7E-6BA9-36DD-B818-2322A712E1F5> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
                  0x7fff91393000 -     0x7fff91490fff  com.apple.avfoundation (2.0 - 180.30) <061DDF4C-E7BB-33D0-BEB9-0443ADF6EC8C> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                  0x7fff91491000 -     0x7fff91491fff  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <61EFED6A-A407-301E-B454-CD18314F0075> /usr/lib/system/libkeymgr.dylib
                  0x7fff91492000 -     0x7fff9161cff7  com.apple.WebKit (7534.51 - 7534.51.22) <A52AF4EF-A2AA-3718-AB96-576A5E0A1CB8> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
                  0x7fff91620000 -     0x7fff918f8ff7  com.apple.security (7.0 - 55010) <93713FF4-FE86-3B4C-8150-5FCC7F3320C8> /System/Library/Frameworks/Security.framework/Versions/A/Security
                  0x7fff91a0b000 -     0x7fff91a1dff7  libz.1.dylib (1.2.5 - compatibility 1.0.0) <30CBEF15-4978-3DED-8629-7109880A19D4> /usr/lib/libz.1.dylib
                  0x7fff91a5c000 -     0x7fff91a84ff7  com.apple.CoreVideo (1.7 - 70.1) <98F917B2-FB53-3EA3-B548-7E97B38309A7> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                  0x7fff91ae5000 -     0x7fff91aecfff  com.apple.NetFS (4.0 - 4.0) <B9F41443-679A-31AD-B0EB-36557DAF782B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                  0x7fff91aed000 -     0x7fff91bcefff  com.apple.CoreServices.OSServices (478.29 - 478.29) <B487110E-C942-33A8-A494-3BDEDB88B1CD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                  0x7fff91bcf000 -     0x7fff91c0ffff  libtidy.A.dylib (??? - ???) <E500CDB9-C010-3B1A-B995-774EE64F39BE> /usr/lib/libtidy.A.dylib
                  0x7fff91c10000 -     0x7fff91c10fff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <C06A140F-6114-3B8B-B080-E509303145B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                  0x7fff91c1f000 -     0x7fff91c22fff  com.apple.AppleSystemInfo (1.0 - 1) <598ADC13-C994-3579-A885-0D6658DDD564> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
                  0x7fff91c4f000 -     0x7fff91c63ff7  com.apple.LangAnalysis (1.7.0 - 1.7.0) <04C31EF0-912A-3004-A08F-CEC27030E0B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                  0x7fff91cfa000 -     0x7fff91d08fff  libdispatch.dylib (187.7.0 - compatibility 1.0.0) <712AAEAC-AD90-37F7-B71F-293FF8AE8723> /usr/lib/system/libdispatch.dylib
                  0x7fff91d09000 -     0x7fff91d10fff  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <172B1985-F24A-34E9-8D8B-A2403C9A0399> /usr/lib/system/libcopyfile.dylib
                  0x7fff91d11000 -     0x7fff91d11fff  com.apple.CoreServices (53 - 53) <043C8026-8EDD-3241-B090-F589E24062EF> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                  0x7fff91d12000 -     0x7fff91d51fff  com.apple.AE (527.7 - 527.7) <B82F7ABC-AC8B-3507-B029-969DD5CA813D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                  0x7fff91d52000 -     0x7fff91d5dfff  com.apple.CommonAuth (2.1 - 2.0) <BFDD0A8D-4BEA-39EC-98B3-2E083D7B1ABD> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                  0x7fff91d5e000 -     0x7fff91d6bfff  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <931F40EB-CA75-3A90-AC97-4DB8E210BC76> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
                  0x7fff91e01000 -     0x7fff9206fff7  com.apple.QuartzComposer (5.0 - 236) <CBF3070A-BD09-328D-857F-F35A0E1D22B5> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                  0x7fff92070000 -     0x7fff920b2ff7  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <A5B9778E-11C3-3F61-B740-1F2114E967FB> /usr/lib/system/libcommonCrypto.dylib
                  0x7fff920b3000 -     0x7fff920b5fff  libquarantine.dylib (36.0.0 - compatibility 1.0.0) <4C3BFBC7-E592-3939-B376-1C2E2D7C5389> /usr/lib/system/libquarantine.dylib
                  0x7fff920b6000 -     0x7fff9217dff7  com.apple.ColorSync (4.7.0 - 4.7.0) <F325A9D7-7203-36B7-8C1C-B6A4D5CC73A8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                  0x7fff9217e000 -     0x7fff92280ff7  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <D46F371D-6422-31B7-BCE0-D80713069E0E> /usr/lib/libxml2.2.dylib
                  0x7fff922bc000 -     0x7fff92546fff  com.apple.JavaScriptCore (7534.51 - 7534.51.21) <B311DA3D-F763-32A0-BE17-5DC97820BFAB> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                  0x7fff92557000 -     0x7fff9256dff7  com.apple.ImageCapture (7.0 - 7.0) <69E6E2E1-777E-332E-8BCF-4F0611517DD0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                  0x7fff925b9000 -     0x7fff925e4fff  libpcre.0.dylib (1.1.0 - compatibility 1.0.0) <7D3CDB0A-840F-3856-8F84-B4A50E66431B> /usr/lib/libpcre.0.dylib
                  0x7fff925e5000 -     0x7fff925ebfff  libmacho.dylib (800.0.0 - compatibility 1.0.0) <D86F63EC-D2BD-32E0-8955-08B5EAFAD2CC> /usr/lib/system/libmacho.dylib
                  0x7fff925ec000 -     0x7fff92640ff7  com.apple.ScalableUserInterface (1.0 - 1) <1873D7BE-2272-31A1-8F85-F70C4D706B3B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
                  0x7fff92641000 -     0x7fff926d7ff7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) <642D8D54-F9F5-3FBB-A96C-EEFE94C6278B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                  0x7fff9273a000 -     0x7fff927aafff  com.apple.datadetectorscore (3.0 - 179.4) <2A822A13-94B3-3A43-8724-98FDF698BB12> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                  0x7fff927ab000 -     0x7fff927f6ff7  com.apple.SystemConfiguration (1.11.1 - 1.11) <F832FE21-5509-37C6-B1F1-48928F31BE45> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                  0x7fff92804000 -     0x7fff9284bff7  com.apple.CoreMedia (1.0 - 705.42) <AA2E9D78-A08C-39E2-B423-D69A75C2397D> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                  0x7fff9284c000 -     0x7fff9285aff7  libkxld.dylib (??? - ???) <65BE345D-6618-3D1A-9E2B-255E629646AA> /usr/lib/system/libkxld.dylib
                  0x7fff9285b000 -     0x7fff92a2ffff  com.apple.CoreFoundation (6.7.1 - 635.15) <FE4A86C2-3599-3CF8-AD1A-822F1FEA820F> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                  0x7fff92b2f000 -     0x7fff92b30ff7  libremovefile.dylib (21.0.0 - compatibility 1.0.0) <C6C49FB7-1892-32E4-86B5-25AD165131AA> /usr/lib/system/libremovefile.dylib
                  0x7fff92b31000 -     0x7fff92b46fff  com.apple.FileSync.framework (6.0 - 432) <D296CA43-BAED-3AA9-953A-C879FEBD6104> /System/Library/PrivateFrameworks/FileSync.framework/Versions/A/FileSync
                  0x7fff92b47000 -     0x7fff92b4bfff  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <FF83AFF7-42B2-306E-90AF-D539C51A4542> /usr/lib/system/libmathCommon.A.dylib
              External Modification Summary:
                Calls made by other processes targeting this process:
                  task_for_pid: 13
                  thread_create: 0
                  thread_set_state: 0
                Calls made by this process:
                  task_for_pid: 0
                  thread_create: 0
                  thread_set_state: 0
                Calls made by all processes on this machine:
                  task_for_pid: 1592
                  thread_create: 0
                  thread_set_state: 0
              VM Region Summary:
              ReadOnly portion of Libraries: Total=456.1M resident=347.9M(76%) swapped_out_or_unallocated=108.2M(24%)
              Writable regions: Total=540.9M written=123.0M(23%) resident=201.2M(37%) swapped_out=0K(0%) unallocated=339.8M(63%)
              REGION TYPE                      VIRTUAL
              ATS (font support)                 33.1M
              ATS (font support) (reserved)         4K        reserved VM address space (unallocated)
              CG backing stores                  19.8M
              CG image                            128K
              CG raster data                      672K
              CG shared images                   3440K
              CoreGraphics                         16K
              CoreImage                            72K
              CoreServices                       1816K
              IOKit                              1420K
              IOKit (reserved)                    512K        reserved VM address space (unallocated)
              MALLOC                            335.3M
              MALLOC guard page                    32K
              MALLOC_LARGE (reserved)            23.8M        reserved VM address space (unallocated)
              Memory tag=240                     54.9M
              Memory tag=242                       12K
              Memory tag=249                      264K
              Memory tag=251                       72K
              OpenCL                               44K
              OpenGL GLSL                        1372K
              OpenGL GLSL (reserved)              128K        reserved VM address space (unallocated)
              SQLite page cache                   192K
              STACK GUARD                        56.4M
              Stack                              54.3M
              VM_ALLOCATE                        23.4M
              VM_ALLOCATE (reserved)             1128K        reserved VM address space (unallocated)
              __CI_BITMAP                          80K
              __DATA                             49.0M
              __IMAGE                            1256K
              __LINKEDIT                        143.4M
              __TEXT                            312.7M
              __UNICODE                           544K
              mapped file                       169.0M
              shared memory                      12.7M
              TOTAL                               1.3G
              TOTAL, minus reserved VM space      1.2G
              Model: MacPro5,1, BootROM MP51.007F.B03, 12 processors, 6-Core Intel Xeon, 2.66 GHz, 26 GB, SMC 1.39f11
              Graphics: ATI Radeon HD 5770, ATI Radeon HD 5770, PCIe, 1024 MB
              Memory Module: DIMM 1, 4 GB, DDR3 ECC, 1333 MHz, 0x0198, 0x393936353431332D3030322E4130304C4620
              Memory Module: DIMM 2, 4 GB, DDR3 ECC, 1333 MHz, 0x0198, 0x393936353431332D3030322E4130304C4620
              Memory Module: DIMM 3, 4 GB, DDR3 ECC, 1333 MHz, 0x0198, 0x393936353431332D3030322E4130304C4620
              Memory Module: DIMM 4, 1 GB, DDR3 ECC, 1333 MHz, 0x802C, 0x394A53463132383732415A2D314734463120
              Memory Module: DIMM 5, 4 GB, DDR3 ECC, 1333 MHz, 0x0198, 0x393936353431332D3030322E4130304C4620
              Memory Module: DIMM 6, 4 GB, DDR3 ECC, 1333 MHz, 0x0198, 0x393936353431332D3030322E4130304C4620
              Memory Module: DIMM 7, 4 GB, DDR3 ECC, 1333 MHz, 0x0198, 0x393936353431332D3030322E4130304C4620
              Memory Module: DIMM 8, 1 GB, DDR3 ECC, 1333 MHz, 0x80AD, 0x484D54313132553754465238432D48392020
              AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.100.98.75.18)
              Bluetooth: Version 4.0.1f4, 2 service, 18 devices, 1 incoming serial ports
              Network Service: Ethernet 2, Ethernet, en1
              PCI Card: pci1095,3132, sppci_othermassstorage, Slot-3
              PCI Card: pcibdbd,a117, sppci_video, Slot-4
              PCI Card: ATI Radeon HD 5770, sppci_displaycontroller, Slot-1
              PCI Card: pcibdbd,a117, sppci_video, Slot-2
              Serial ATA Device: HL-DT-ST DVD-RW GH41N
              Serial ATA Device: WDC WD1001FALS-41Y6A0, 1 TB
              Serial ATA Device: WDC WD1001FALS-00E8B0, 1 TB
              SCSI Device: SCSI Target Device @ 15
              USB Device: hub_device, 0x03f0  (Hewlett Packard), 0x2f24, 0xfa200000 / 2
              USB Device: Logitech Camera, 0x046d  (Logitech Inc.), 0x09a6, 0xfa260000 / 4
              USB Device: ShuttlePRO v2, 0x0b33  (Contour Design, Inc.), 0x0030, 0xfa210000 / 3
              USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfd100000 / 2
              USB Device: Apple Keyboard, apple_vendor_id, 0x0221, 0xfd120000 / 3
              USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x5a100000 / 2
              USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0x5a110000 / 3
              USB Device: XD-1212-U, 0x056a  (WACOM Co., Ltd.), 0x0044, 0x3d100000 / 2
              FireWire Device: built-in_hub, 800mbit_speed
