9 Replies Latest reply on Nov 9, 2011 7:49 AM by DyonisosDD2
    Not saving the the line/link position in process designer
    hkho Level 1
      I've got a process which works fine, but when I open it in process designer, the line/links are not arranged correctly. It's strange that if I drag on the service icon, then the line/link will be rearranged nicely, then I save it and close the process, when I open the process again the line/links become mess again not display in the correct position.
      Is there anything I can do, so that the lines can be saved correctly. Actually, the process is working corectly even those line seems broken in process designer. I've tried to copy it to a new process, but still can't solve the problem. Please advise if it can be solved. Thanks.
