7 Replies Latest reply on Jun 11, 2007 7:05 AM by Newsgroup_User
    Digital Video Buttons
    Proddy2k Level 1
      I have a Digital Video element with buttons controlling it manually made. I want to create buttons to make the user go to the beginning of the video if they click on the << button and end of video if they click on the >> button. Any ideas how to do this the simplist way, I have tried to use pre-defined behaviors in Director but they dont work.
      Any help will be appreciated!
      Cheers!
        • 1. Re: Digital Video Buttons
          Level 7
          If you are using Quicktime for your video, then setting the currentTime
          property will do what you are asking
          If your video is in channel 1 and you want to send it to the beginning:
          sprite(1).currentTime=1
          You can get the time at end of the video by using duration, so this will
          send it to the end (I'm not real sure why you would ever want to send
          the video to the end, though...)
          sprite(1).currentTime=sprite(1).duration
          For more specifics on how to control digital video, check out the help
          file. On the Contents tab, go to the Director Scripting Reference, then
          Media Types, then Quicktime. It explains all of the different commands
          and properties.
          • 2. Re: Digital Video Buttons
            Proddy2k Level 1
            and properties.
            I am using AVI Video Member, any ideas how to implement it for this video type?
            • 3. Re: Digital Video Buttons
              Level 7
              currentTime and duration will work for AVI too.
              regards
              Dean
              Director Lecturer / Consultant / Director Enthusiast
              http://www.fbe.unsw.edu.au/learning/director
              http://www.multimediacreative.com.au
              email: d.utian@unsw.edu.au
              • 4. Re: Digital Video Buttons
                Proddy2k Level 1
                and properties.
                I added this to the button but nothing happens:
                on mouseup
                sprite(8).currentTime=1
                end
                Any ideas?
                • 5. Re: Digital Video Buttons
                  Level 7
                  > on mouseup
                  > end
                  > Any ideas?
                  I think 'currentTime' should work for AVIs. But, give 'movieTime' a try
                  instead and see how that goes. So:
                  sprite(8).movieTime=1
                  regards
                  Dean
                  • 6. Re: Digital Video Buttons
                    Proddy2k Level 1
                    > on mouseup
                    > end
                    > Any ideas?
                    regards
                    Dean
                    OK it works by taking it to the beginning of the movie but how can I take it to the end of the movie? I want it to be paused at the end of the movie as the one above takes it back to the start but plays it.
                    • 7. Re: Digital Video Buttons
                      Level 7
                      movieTime - position in vidoe
                      movieRate - playback speed where 1 is forward, -1 backward, 2 fast forward (2x)
                      and 0 is paused
                      duration - length of video
                      to go to end of video sprite 8 and pause
                      sprite(8).movieTime=sprite(8).duration
                      sprite(8).movieRate=0
                      QT generally goes to a movieRate of 0 when it gets to the end of the video. This
                      does not happen with AVI.
                      to play again from paused state
                      sprite(8).movieRate=1
                      regards
                      Dean
