0 Replies Latest reply on Apr 7, 2011 1:09 AM by Abhiram88
    Problems while binding with XML file
    Abhiram88 Level 1
      I have a form which is embeded with an XSD in designer. Now I have few feilds to populate in the run time, so i have used an xml file and binded it with the workbench process while form rendering. In the designer I have made all those fields as "Use global data" and it is working fine. but those fields are not reflecting in the "submit by email" XML file becuase those are not binded in the XSD.
      Is there a way so that it can take the values from the XML through the work bench process and also bind them in the XSD ?
      Hope I am clear in explaining my situation.
      Pls .help
