9 Replies Latest reply on Apr 8, 2011 8:05 AM by ACS LLC
    creating drop down menus that change dependant upon previous menu
    ACS LLC Level 1
      I need to create a drop down menu and then have the next drop down change its content based on the selection in the previous menu
      Would anybody have any code that I could play around with that would help me achieve this?
      Thanks!!
      Mark
        • 1. Re: creating drop down menus that change dependant upon previous menu
          cfwild Level 1
          Hi Mark,
          Here is some code that may get you started:
          I'm loading the 1st cfselect with a query coming from a .cfc.  Also notice the bindonLoad="True".  The second cfselect "Channel" is using the select from Category; notice the bind which is pulling query from a differenct function of the same .cfc.  Notice the bind, it uses {Category} which is the value selected in the first cfselect.
                                  <cfselect
                                      name="Category"
                                      bind="cfc:quad.GetCategory()"
                                      style="width:387px;"
                                      size="1"
                                      multiple="No"
                                      required="No"
                                      display="Category"
                                      value="Category"
                                      bindonLoad="True">
                                  </cfselect>
                                  <cfselect
                                      name="Channel"
                                      bind="cfc:quad.GetChannel({Category})"
                                      size="1"
                                      multiple="No"
                                      required="No"
                                      display="Channel"
                                      value="Channel">
                                  </cfselect>
          This should get you going.
          <cfwild />
          • 2. Re: creating drop down menus that change dependant upon previous menu
            ACS LLC Level 1
            umm I never use the CF form functions, or CFC's, just basic CFM with HTML so I'm slightly confused
            I will play with it and read the doc's..
            Do you have any simple HTML examples? I'm wondering what the easiest way is to bind them together?
            After posting I thought I better post a little more info on what I'm trying to achieve.
            Let's say I have a list of products in a table
            Table one:
            product_uid,product_title
            1,product one
            2,product two
            3,product three
            Table two has entries related to table 1, where the product_uid from table 1 above is related back using sub_product_uid in table 2
            sub_uid,sub_product_uid,sub_title
            1,1,sub product 1 of product 1
            2,1,sub product 2 of product 1
            3,1,sub product 3 of product 1
            4,2,sub product 1 of product 2
            5,2,sub product 2 of product 2
            6,2,sub product 3 of product 2
            7,3,sub product 1 of product 3
            8,3,sub product 2 of product 3
            So, I have to write a Query to some how get all the products from table 1, and then group them with table 2 for their sub products
            Then I have to create a select that lists all the the products from table 1, and upon selecting a product in select box 1, it then changes the values of select box 2 to the appropriate sub products
            Mark
            • 3. Re: creating drop down menus that change dependant upon previous menu
              cfwild Level 1
              Hi Mark,
              This should get you close:
              Create a .cfc call it product, as in save as product.cfc
              You'll need to change the datasource name and the FROM clause below on both queries.
              <cfcomponent output="false">
                  <cffunction name="getProduct" access="remote" returnType="query">
                      <cfset var data="" />
                        <cfquery datasource="yourdb" name="data">
                          SELECT product_uid,product_title
                          FROM yourtable
                      </cfquery>
                      <cfreturn data>
                  </cffunction>
                  <cffunction name="getSubProduct" access="remote" returnType="query">
                      <cfargument name="product_uid" type="numeric" required="true">
                          SELECT sub_uid,sub_title
                          FROM yourtable
                          WHERE sub_product_uid = #ARGUMENTS.product_uid#
                      </cfquery>
                      <cfreturn data>
                  </cffunction>
              </cfcomponent>
              Imbed this in your your cfm page:
              <cfselect
                  name="Product"
                  bind="cfc:product.getProduct()"
                  size="1"
                  multiple="No"
                  required="No"
                  display="product_title"
                  value="product_uid"
                  bindonLoad="True">
              </cfselect>
              <cfselect
                  name="Sub Product"
                  bind="cfc:product.getSubProduct({product_uid})"
                  size="1"
                  multiple="No"
                  required="No"
                  display="sub_title"
                  value="sub_product_uid">
              </cfselect>
              • 4. Re: creating drop down menus that change dependant upon previous menu
                ACS LLC Level 1
                Thanks again! I have a lot to learn
                Never actually built a CFC... I'm going to have to try to figure it all out
                Is there any way to do it without a CFC???
                Thanks!!!
                Mark
                • 5. Re: creating drop down menus that change dependant upon previous menu
                  Dave Watts Adobe Community Professional
                  Sure. Anything that you do with a CFC, you can do with a CFM page. But it will be a lot easier if you use a CFC, as it'll do a lot of the work for you.
                  Dave Watts, CTO, Fig Leaf Software
                  http://www.figleaf.com/
                  http://training.figleaf.com/
                  • 6. Re: creating drop down menus that change dependant upon previous menu
                    Amiya Padhi
                    You can do the same using cfm pages also . You just need to make sure that it returns a two-dimensional array, where the first element in each array row is the option value and the second element in the row is the text to display in the option list.
                    • 7. Re: creating drop down menus that change dependant upon previous menu
                      Dan Bracuk Level 5
                      You appear to be talking about "related selects".  There are many ways to accomplish this and a google search will get you good results.  The way I do it is like this
                      http://www.pathcom.com/~bracuk/code/RelatedSelects.htm
                      • 8. Re: creating drop down menus that change dependant upon previous menu
                        ACS LLC Level 1
                        That would be the way I would want to go
                        Do you have any examples that you could post?
                        I know how to create an array, just need to figure out how to configure the CFM
                        Mark
                        • 9. Re: creating drop down menus that change dependant upon previous menu
                          ACS LLC Level 1
                          Thanks Dan,
                          I took a look, ummm ... looked a shade complicated for me, especially once it got into the javascript.
                          I thought it would have been fairly straightforward to create on of these, perhaps it's just because I've never done one, but they seem more complex that I had hoped!
                          Mark
