2 Replies Latest reply on Apr 26, 2012 8:59 AM by Mark Marcott
    Surppress 'Potential Printing Problems Detected' warning
    CB_8
      How can we surppress this warning? via the registry if possible?
      It comes up in our Terminal Services environment when printing PDF's using a new Xerox print driver.
        • 1. Re: Surppress 'Potential Printing Problems Detected' warning
          Michael.nl
          I got the same problem, any solution yet ?
          • 2. Re: Surppress 'Potential Printing Problems Detected' warning
            Mark Marcott
            This is related to the Xerox Print Driver.  The only way to stop it on a Xerox printer is to check the box "Do not show this again".  When this is checked, a setting is saved in the registry.
            This may be used to deploy a fix for all users to get rid of this message:
            1) Check for Xerox Driver Version 5.0 - do this be searching for the V5.0 in the registry (regedit.exe).
            2) Copy the data below to a text file and rename it to Fix.reg.
            3) Open Fix.reg and merge the settings into the local registry.
            4) Reboot your workstation.
            *** Copy the text between the *** comment into a file ***
            Windows Registry Editor Version 5.0
            [HKEY_CURRENT_USER\Software\Xerox\PrinterDriver\V5.0\AdobeReaderWarning]
            "SettingsPreference"=dword:00000001
            *** End of Copy ***
