8 Replies Latest reply on Apr 10, 2011 7:34 PM by Frustrated in AZ
    Downloading to ereader
    BagginsBob
      I have been downloading ebooks to my computer (Windows 7), from library and Gutenberg; no problem.  But when I transfer from computer to my Hanvon Wisereader, the books appear in the (connected) device window on computer but not in the device itself. I have installed Adobe Digital Editions, and authorised it, and have followed the 'Help' guide. I have tried sending icons, dragging them, bypassing the computer; nothing helps. Surely it can't be this hard. What am I missing? Any ideas?
        • 1. Re: Downloading to ereader
          rizwan.54 Level 1
          In order to fix this please follow the steps as given below.
          1) Delete restore folder from following location.
             C:\Documents and Settings\UserName\My Documents\My Digital Editions.
          2) Now connect your Reader.
          3) Once you plug in the Reader click start>>My Computer.
          4) There you will find a new drive created similar to C or D drive on your computer.
          5) Open the Readers Drive and you will find a folder of with name Adobe digital Editions.
          6) Delete that folder and plug off and re plug in the Reader.
          7) Now drag and dorp any book from Digital Edition to Reader.
          I hope this will help you!!!
          Regards
          Rizwan
          • 2. Re: Downloading to ereader
            Level 4
            Let me try to clarify these instructions a bit, because there is a step left
            out.
            Step 6 should be to delete the folder.
            Step '6a' would be to disconnect the reader logically from your Windows
            machine by 'ejecting' it.  You do that by using My Computer to display the
            drive letter the reader is using, then right clicking on it.  In the
            drop-down box, click on 'Eject'.  Then check the reader to see that it
            closes its software properly (some say 'synchronizing', some say 'updating',
            etc.)  When that operation is complete, unplug the reader.
            Step '6b' would be to plug the reader back in.  When Windows assigns it a
            drive letter, you can start ADE.  Your reader should show up in the left
            hand pane in Library view.  You should be able to drag and drop your ebooks
            onto you reader (Step 7).
            • 3. Re: Downloading to ereader
              celebryson1
              I tried this to solve a like problem with Kobo, but it didn't work. I still can't find the book in my library.
              • 4. Re: Downloading to ereader
                Level 4
                If you're comfortable with using Windows, there's another possibility.  I'll
                assume that the book you're looking for is in ePub format
                Open Windows Explorer (not the internet one - the computer exploration
                one) and look at the My Digital Editions or the Adobe Digital Editions
                folders.  You should be able to see ePub files.  Look for the title of the
                book you downloaded.  If you find it, make a note of the folder location.
                Then, open ADE in Library View, and click on the drop-down arrow on the word
                'Library'.  You should see a choice to Add Item To Library.  If you click on
                that choice, you will get a screen that will allow you to locate the book
                you found and then click on it.  You have choices as to file folder location
                (at the top), file format (at the bottom) and title, and you may have to
                adjust those settings to 'see' the book.  When it's set up, select the
                file name and click on it.  It will appear in the 'File Name' box.
                Then click 'Open'.  ADE will transfer the title to the library.
                There's an alternative to this process, but this one works a lot of the
                time.
                • 5. Re: Downloading to ereader
                  reader222200
                  My downloaded book show up in ADE on the boo
                  kshelf, but how do I get it to my Ipad. I've tried everything everyone has suggested. I need something simple. Even d/l  Bluefire reader but can't make that work either.
                  • 6. Re: Downloading to ereader
                    Level 4
                    AHA!  The real problem!
                    Unfortunately, Apple's iPad is not a supported device - yet.  Some others
                    have had similar questions, and I think the answer was to use a different
                    ebook management software.  I have a really superb memory - but it's also
                    short, and I can't remember the name of the software.  You can search the
                    Forum for iPad and it should be there....
                    • 7. Re: Downloading to ereader
                      celebryson1 Level 1
                      Kobo, on the other hand, is a supported e-reader. I have tried everything I could think of. The book shows up in ADE, and my Kobo is recognized, meaning it shows up as a bookshelf. I have dragged and droppped the book to Kobo, ejected the Kobo reader, but it doesn't come up in Kobo's book list. I even tried copying the EPUB from Documents/My Digital Editions directly to my Kobo, and if I open the ereader in 'My Computer', I can see the EPUB listed, but again, when I eject Kobo and try to find the book to read off Kobo, it's not in the book list.
                      • 8. Re: Downloading to ereader
                        Level 4
                        You've gone through all the steps that I know of and the same sequences I
                        use for my ereader.  There's only one other thing I can think of.
                        If you look at the ebook in ADE, you'll see a drop down box in the corner,
                        which displays the 'Item Options'.  The third one is 'Itelm Info'  That
                        displays the location of the ebook on your computer and also the permissions
                        assigned by the publisher.  Check to see that the publisher has allowed
                        copying to any device.  If they haven't, then that's why you can't get the
                        book on your Kobo ereader.
