• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Passing the timestamp
Explorer ,
Apr 08, 2011 Apr 08, 2011
I've discovered an interesting problem where suggested solutions don't seem to work.
I need to pass a DB2 timestamp to a module.  Here's what I've been trying:
The timestamp from the table is "2011-04-08 08:21:09.995639"
I use URLEncodeFormat to change the spaces, and prepare to pass "2011%2D04%2D08%2008%3A21%3A09%2E995639"
<cfset templeaveid =  #URLEncodedFormat(timestamp)# />
The passing code is:
<a href="dsp_pleave_edit.cfm?leaveid=#templeaveid#">Update</a>
When I get to the dsp_pleave_edit.cfm module, I dump the value (because I keep getting nothing) an lo! and behold, it's an empty string!  Yes, I've tried it in ts raw form and decoded form.  Both give the empty string.
<cfdump var=#URL.leaveid#><br />
<cfdump var=#URLDecode(URL.leaveid)#><br />
[empty string]
[empty string]
What am I doing wrong?  No, I cannot use another field, the timestamp is the only unique row identifier on this table.  This is definitely a stumper!
TOPICS
Advanced techniques
Views
675
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Apr 08, 2011 Apr 08, 2011
Is that anchor tag inside a cfoutput block?
Votes
Translate
Translate
LEGEND ,
Pass it as a numeric string.  When you receive it, use ParseDateTime to change it back to a timestamp.
Votes
Translate
Translate
Report
Report
Explorer ,
OK, I converted the date to a straight numeric string:
<cfset tstampDate =
     Left(#get_personal_leave.ROW_ADD_TSTAMP#, 4)
  & MID(#get_personal_leave.ROW_ADD_TSTAMP#, 6, 2)
  & MID(#get_personal_leave.ROW_ADD_TSTAMP#, 9, 2)
  & MID(#get_personal_leave.ROW_ADD_TSTAMP#, 12, 2)
  & MID(#get_personal_leave.ROW_ADD_TSTAMP#, 15, 2)
  & MID(#get_personal_leave.ROW_ADD_TSTAMP#, 18, 2)
  & MID(#get_personal_leave.ROW_ADD_TSTAMP#, 21, 6)/>
<cfdump var=#tstampDate#>
Which gives me:  20110408082109995639
and I still passed nothing.  So I tried a U in front of the string (for Update), and all I got was the U!  It's not passing the field's value. Why?  The production example I copied worked great:
PROD:
  <a href="dsp_employee_edit.cfm?userid=U#get_isb_employees.USER_ID#">Update</a>
Mine
  <a href="dsp_pleave_edit.cfm?leaveid=U#tstampDate#">Update</a>
And I use identical code on the receiving end (<cfdump var=#URL.userid#><br />) to see what I passed.
I noticed that the IE address bar shows the field for the production as:
dsp_employee_edit.cfm?userid=UMV370
but mine is showing as:
This suggests that the value within the pound signs isn't being translated to any sort of a value.  What would cause that?
Votes
Translate
Translate
Report
Report
LEGEND ,
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
No, it's in a table that is inside a cfform...and that's the answer.   As soon as I put it in a cfoutput block, I got the date.
Thanks once again for saving the day!
Votes
Translate
Translate
Report
Report
Resources
Documentation
