3 Replies Latest reply on Apr 8, 2011 12:20 PM by mrbahr
    Displaying UTF-8 Characters in Flex from XML
    mrbahr
      I am having a problem displaying UTF-8 encoded strings that are XML in flex components.  I have verified that the data is being stored correctly in MySQL and that the XML has the correct encoding.  I can display the XML in a browser and it displays correctly.
      I am using BlazeDS to transfer the string from the Java server to the Flex client.  When I try and display the characters, it displays strange characters.
      When I bring the XML into Flex as a String, I do the following:
      var xml:XML = new XML(xmlString);
      For example the string might be:
      <?xml version='1.0' encoding='UTF-8'?>
           <Root>
                <MASTERWINEINDEX>
                     <Col name="DESIGNATION"><![CDATA[Et Côteras]]></Col>
                     <Col name="VINTAGE"><![CDATA[2006]]></Col>
                </MASTERWINEINDEX>
           </Root>
      I use the following to display in an AdvancedDataGrid:
      private function wineSearchLabelFunction(item:XML, column:AdvancedDataGridColumn):String {
           return item.Col.(@name==column.dataField).toString();
      <mx:AdvancedDataGrid id="dataWineGrid" designViewDataType="flat" top="42" bottom="75" left="10" right="36"
                 sortableColumns="true" scroll="this.lblTop.text = String(dataWineGrid.verticalScrollPosition)"
                 doubleClickEnabled="true">
           <mx:columns>
                <mx:AdvancedDataGridColumn dataField="DESIGNATION" headerText="Designation" labelFunction="wineSearchLabelFunction"
                                       sortCompareFunction="{function(obj1:XML, obj2:XML):int{return wineSortFunction(obj1, obj2, 'DESIGNATION');}}"/>
            </mx:columns>
      </mx:AdvancedDataGrid>
      What I get in the "Designation" column is a field with strange characters.  I'm guessing that it is encoded correctly, but not displaying correctly.  I've tried displaying the data in a TextArea, TextInput and to no avail.
      Any ideas?
      Is it possible that blazeDS is doing some translation?  When I parse the xml string using "new XML(string)", do I need to do something special?
      Tom
