1 Reply Latest reply on Apr 29, 2011 9:25 PM by bolt_tecnologia
    Dreamweaver CS5 HTML5 Update   Update is not aplicable
    crime26
      (TR)(original) Dreamweaver CS5 HTML5 Güncelleştirmesi
        Güncelleştirme uygulanabilir değil
      (EN) Dreamweaver CS5 HTML5 Update
      System: Win 7 Pro 32bit TR, Dreamweaver 11.0 build 4847 (CS5 MASTER COLLECTION)
      Can I Help Me?
      http://i56.tinypic.com/2re5pb7.png
      http://i51.tinypic.com/5oe5np.png
      http://i56.tinypic.com/qy76mv.png
      START - Installer Session
      RIBS version: 3.0.106.0
      Win OS version: 6.1.0.0  Type: 1
      ::START TIMER:: [Total Timer]
      CHECK: Single instance running
      CHECK : Credentials
      Load Deployment File
      deploymentFile option not given
      Create Required Folders
      Assuming install mode
      Lookup install source path
      Sync Media DB ...
      ::START TIMER:: [Sync Media DB]
      Pre check media db syc
      End of Pre check media db syc. exit code: 0
      :: END TIMER :: [Sync Media DB] took 690.929 miliseconds (0.690929 seconds)
      Ready to initialize session to start with ...
      ::START TIMER:: [CreatePayloadSession]
      -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
      Updated source path: C:\Users\GC\AppData\Local\Temp\Adobe\AAMUpdater\AdobeDreamweaverCS5-11.0\11.0.3\Setup
      Updating media info for: {2C5BF2AE-8CE8-405A-B45F-2C2FD62D649B}
      Ignoring original data since install source is local
        Type: 0, Volume Order: 1, Media Name: AdobeDreamweaver-11.0-All-Update
        Path: C:\Users\GC\AppData\Local\Temp\Adobe\AAMUpdater\AdobeDreamweaverCS5-11.0\11.0.3\Setup\pay loads\AdobeDreamweaver11sv_SELanguagePack-250810042309\Install.db
      Updating media info for: {363682AB-FF33-411D-9F28-83F4D475858B}
        Path: C:\Users\GC\AppData\Local\Temp\Adobe\AAMUpdater\AdobeDreamweaverCS5-11.0\11.0.3\Setup\pay loads\AdobeDreamweaver11pl_PLLanguagePack-250810044302\Install.db
      Updating media info for: {3E093F04-E9E0-43E9-90C1-4423014CB4D3}
        Path: C:\Users\GC\AppData\Local\Temp\Adobe\AAMUpdater\AdobeDreamweaverCS5-11.0\11.0.3\Setup\pay loads\AdobeDreamweaver11ru_RULanguagePack-250810043224\Install.db
      Updating media info for: {42DC7599-BBA8-4569-8B06-CB79685C3988}
        Path: C:\Users\GC\AppData\Local\Temp\Adobe\AAMUpdater\AdobeDreamweaverCS5-11.0\11.0.3\Setup\pay loads\AdobeDreamweaver11ja_JPLanguagePack-250810024602\Install.db
      Updating media info for: {4FC4B869-AD0D-4A56-B626-2926EB2C48D0}
        Path: C:\Users\GC\AppData\Local\Temp\Adobe\AAMUpdater\AdobeDreamweaverCS5-11.0\11.0.3\Setup\pay loads\AdobeDreamweaver11-mul-250810021829\Install.db
      Updating media info for: {5476F479-0877-4775-8D0A-F6A113D9906B}
        Path: C:\Users\GC\AppData\Local\Temp\Adobe\AAMUpdater\AdobeDreamweaverCS5-11.0\11.0.3\Setup\pay loads\AdobeDreamweaver11it_ITLanguagePack-250810035512\Install.db
      Updating media info for: {6645611D-3292-442F-A105-FBFB0BAAEB72}
        Path: C:\Users\GC\AppData\Local\Temp\Adobe\AAMUpdater\AdobeDreamweaverCS5-11.0\11.0.3\Setup\pay loads\AdobeDreamweaver11fr_FRLanguagePack-250810033610\Install.db
      Updating media info for: {685893EC-E567-4A83-944A-C384DBC78195}
        Path: C:\Users\GC\AppData\Local\Temp\Adobe\AAMUpdater\AdobeDreamweaverCS5-11.0\11.0.3\Setup\pay loads\AdobeDreamweaver11cs_CZLanguagePack-250810050222\Install.db
      Updating media info for: {756FA186-6AA1-4866-BD30-328CA3821E00}
        Path: C:\Users\GC\AppData\Local\Temp\Adobe\AAMUpdater\AdobeDreamweaverCS5-11.0\11.0.3\Setup\pay loads\AdobeDreamweaver11zh_CNLanguagePack-250810031338\Install.db
      Updating media info for: {787EC3DF-20D9-4059-A234-5C5E4EFB03F7}
        Path: C:\Users\GC\AppData\Local\Temp\Adobe\AAMUpdater\AdobeDreamweaverCS5-11.0\11.0.3\Setup\pay loads\AdobeDreamweaver11ko_KRLanguagePack-250810025450\Install.db
      Updating media info for: {A75E99BC-811E-42D3-93C0-C03B62BEFFC3}
        Path: C:\Users\GC\AppData\Local\Temp\Adobe\AAMUpdater\AdobeDreamweaverCS5-11.0\11.0.3\Setup\pay loads\AdobeDreamweaver11pt_BRLanguagePack-250810040443\Install.db
      Updating media info for: {BC2D423A-85A6-4295-A6B0-FD80D499534D}
        Path: C:\Users\GC\AppData\Local\Temp\Adobe\AAMUpdater\AdobeDreamweaverCS5-11.0\11.0.3\Setup\pay loads\AdobeDreamweaver11tr_TRLanguagePack-250810045310\Install.db
      Updating media info for: {C53E61E7-FB4E-414E-A73C-CEED80FC7B67}
        Path: C:\Users\GC\AppData\Local\Temp\Adobe\AAMUpdater\AdobeDreamweaverCS5-11.0\11.0.3\Setup\pay loads\AdobeDreamweaver11zh_TWLanguagePack-250810030325\Install.db
      Updating media info for: {D60F3637-77A6-4FAB-A3FB-F89632B8DABA}
        Path: C:\Users\GC\AppData\Local\Temp\Adobe\AAMUpdater\AdobeDreamweaverCS5-11.0\11.0.3\Setup\pay loads\AdobeDreamweaver11de_DELanguagePack-250810032430\Install.db
      Updating media info for: {F19DAA62-588A-46D3-A092-C808F565D633}
        Path: C:\Users\GC\AppData\Local\Temp\Adobe\AAMUpdater\AdobeDreamweaverCS5-11.0\11.0.3\Setup\pay loads\AdobeDreamweaver11en_USLanguagePack-250810023521\Install.db
      Updating media info for: {FDE18649-FD4C-4E06-9648-F8437A7AB8AC}
        Path: C:\Users\GC\AppData\Local\Temp\Adobe\AAMUpdater\AdobeDreamweaverCS5-11.0\11.0.3\Setup\pay loads\AdobeDreamweaver11nl_NLLanguagePack-250810041406\Install.db
      Updating media info for: {FEB38268-97C6-4C14-9786-2A81A2AC7B6E}
        Path: C:\Users\GC\AppData\Local\Temp\Adobe\AAMUpdater\AdobeDreamweaverCS5-11.0\11.0.3\Setup\pay loads\AdobeDreamweaver11es_ESLanguagePack-250810034609\Install.db
      --------------------  END  - Updating Media Sources -  END  --------------------
      Supported RIBS version range: [0.0.66.0,3.0.106.0]
      ----------------- CreatePayloadSession: machine is x86 ---------------
      ______ Verify Dependency Subscribers ______
      [     916] Sat Apr 09 20:35:52 2011 ERROR
      The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11sv_SELanguagePack  {2C5BF2AE-8CE8-405A-B45F-2C2FD62D649B} requires a parent with following specification:
          Family: Dreamweaver
          ProductName: Adobe Dreamweaver CS5_AdobeDreamweaver11sv_SELanguagePack
          MinVersion: 0.0.0.0
          This parent relationship is not satisfied, because this payload is not present in this session.
          This payload will be ignored in this session.
      The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11pl_PLLanguagePack  {363682AB-FF33-411D-9F28-83F4D475858B} requires a parent with following specification:
          Family: Dreamweaver
          ProductName: Adobe Dreamweaver CS5_AdobeDreamweaver11pl_PLLanguagePack
          MinVersion: 0.0.0.0
      The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11ru_RULanguagePack  {3E093F04-E9E0-43E9-90C1-4423014CB4D3} requires a parent with following specification:
          Family: Dreamweaver
          ProductName: Adobe Dreamweaver CS5_AdobeDreamweaver11ru_RULanguagePack
          MinVersion: 0.0.0.0
      The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11ja_JPLanguagePack  {42DC7599-BBA8-4569-8B06-CB79685C3988} requires a parent with following specification:
          Family: Dreamweaver
          ProductName: Adobe Dreamweaver CS5_AdobeDreamweaver11ja_JPLanguagePack
          MinVersion: 0.0.0.0
      The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11-mul  {4FC4B869-AD0D-4A56-B626-2926EB2C48D0} requires a parent with following specification:
          Family: Dreamweaver
          MinVersion: 0.0.0.0
      The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11it_ITLanguagePack  {5476F479-0877-4775-8D0A-F6A113D9906B} requires a parent with following specification:
          Family: Dreamweaver
          ProductName: Adobe Dreamweaver CS5_AdobeDreamweaver11it_ITLanguagePack
          MinVersion: 0.0.0.0
      The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11fr_FRLanguagePack  {6645611D-3292-442F-A105-FBFB0BAAEB72} requires a parent with following specification:
          Family: Dreamweaver
          ProductName: Adobe Dreamweaver CS5_AdobeDreamweaver11fr_FRLanguagePack
          MinVersion: 0.0.0.0
      The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11cs_CZLanguagePack  {685893EC-E567-4A83-944A-C384DBC78195} requires a parent with following specification:
          Family: Dreamweaver
          ProductName: Adobe Dreamweaver CS5_AdobeDreamweaver11cs_CZLanguagePack
          MinVersion: 0.0.0.0
      The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11zh_CNLanguagePack  {756FA186-6AA1-4866-BD30-328CA3821E00} requires a parent with following specification:
          Family: Dreamweaver
          ProductName: Adobe Dreamweaver CS5_AdobeDreamweaver11zh_CNLanguagePack
          MinVersion: 0.0.0.0
      The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11ko_KRLanguagePack  {787EC3DF-20D9-4059-A234-5C5E4EFB03F7} requires a parent with following specification:
          Family: Dreamweaver
          ProductName: Adobe Dreamweaver CS5_AdobeDreamweaver11ko_KRLanguagePack
          MinVersion: 0.0.0.0
      The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11pt_BRLanguagePack  {A75E99BC-811E-42D3-93C0-C03B62BEFFC3} requires a parent with following specification:
          Family: Dreamweaver
          ProductName: Adobe Dreamweaver CS5_AdobeDreamweaver11pt_BRLanguagePack
          MinVersion: 0.0.0.0
      The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11tr_TRLanguagePack  {BC2D423A-85A6-4295-A6B0-FD80D499534D} requires a parent with following specification:
          Family: Dreamweaver
          ProductName: Adobe Dreamweaver CS5_AdobeDreamweaver11tr_TRLanguagePack
          MinVersion: 0.0.0.0
      The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11zh_TWLanguagePack  {C53E61E7-FB4E-414E-A73C-CEED80FC7B67} requires a parent with following specification:
          Family: Dreamweaver
          ProductName: Adobe Dreamweaver CS5_AdobeDreamweaver11zh_TWLanguagePack
          MinVersion: 0.0.0.0
      The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11de_DELanguagePack  {D60F3637-77A6-4FAB-A3FB-F89632B8DABA} requires a parent with following specification:
          Family: Dreamweaver
          ProductName: Adobe Dreamweaver CS5_AdobeDreamweaver11de_DELanguagePack
          MinVersion: 0.0.0.0
      The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11en_USLanguagePack  {F19DAA62-588A-46D3-A092-C808F565D633} requires a parent with following specification:
          Family: Dreamweaver
          ProductName: Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack
          MinVersion: 0.0.0.0
      The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11nl_NLLanguagePack  {FDE18649-FD4C-4E06-9648-F8437A7AB8AC} requires a parent with following specification:
          Family: Dreamweaver
          ProductName: Adobe Dreamweaver CS5_AdobeDreamweaver11nl_NLLanguagePack
          MinVersion: 0.0.0.0
      The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11es_ESLanguagePack  {FEB38268-97C6-4C14-9786-2A81A2AC7B6E} requires a parent with following specification:
          Family: Dreamweaver
          ProductName: Adobe Dreamweaver CS5_AdobeDreamweaver11es_ESLanguagePack
          MinVersion: 0.0.0.0
      The base product is not installed, Unable to proceed with the patch operation
      [     916] Sat Apr 09 20:35:52 2011  INFO
      :: END TIMER :: [Total Timer] took 1145.75 miliseconds (1.14575 seconds) DTR = 13.9646 KBPS (0.0136373 MBPS)
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 18 error(s), 0 warning(s)
      ERROR: The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11sv_SELanguagePack  {2C5BF2AE-8CE8-405A-B45F-2C2FD62D649B} requires a parent with following specification:
          Family: Dreamweaver
          MinVersion: 0.0.0.0
      ERROR: The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11pl_PLLanguagePack  {363682AB-FF33-411D-9F28-83F4D475858B} requires a parent with following specification:
          Family: Dreamweaver
          MinVersion: 0.0.0.0
      ERROR: The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11ru_RULanguagePack  {3E093F04-E9E0-43E9-90C1-4423014CB4D3} requires a parent with following specification:
          Family: Dreamweaver
          MinVersion: 0.0.0.0
      ERROR: The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11ja_JPLanguagePack  {42DC7599-BBA8-4569-8B06-CB79685C3988} requires a parent with following specification:
          Family: Dreamweaver
          MinVersion: 0.0.0.0
      ERROR: The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11-mul  {4FC4B869-AD0D-4A56-B626-2926EB2C48D0} requires a parent with following specification:
          Family: Dreamweaver
          MinVersion: 0.0.0.0
      ERROR: The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11it_ITLanguagePack  {5476F479-0877-4775-8D0A-F6A113D9906B} requires a parent with following specification:
          Family: Dreamweaver
          MinVersion: 0.0.0.0
      ERROR: The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11fr_FRLanguagePack  {6645611D-3292-442F-A105-FBFB0BAAEB72} requires a parent with following specification:
          Family: Dreamweaver
          MinVersion: 0.0.0.0
      ERROR: The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11cs_CZLanguagePack  {685893EC-E567-4A83-944A-C384DBC78195} requires a parent with following specification:
          Family: Dreamweaver
          MinVersion: 0.0.0.0
      ERROR: The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11zh_CNLanguagePack  {756FA186-6AA1-4866-BD30-328CA3821E00} requires a parent with following specification:
          Family: Dreamweaver
          MinVersion: 0.0.0.0
      ERROR: The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11ko_KRLanguagePack  {787EC3DF-20D9-4059-A234-5C5E4EFB03F7} requires a parent with following specification:
          Family: Dreamweaver
          MinVersion: 0.0.0.0
      ERROR: The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11pt_BRLanguagePack  {A75E99BC-811E-42D3-93C0-C03B62BEFFC3} requires a parent with following specification:
          Family: Dreamweaver
          MinVersion: 0.0.0.0
      ERROR: The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11tr_TRLanguagePack  {BC2D423A-85A6-4295-A6B0-FD80D499534D} requires a parent with following specification:
          Family: Dreamweaver
          MinVersion: 0.0.0.0
      ERROR: The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11zh_TWLanguagePack  {C53E61E7-FB4E-414E-A73C-CEED80FC7B67} requires a parent with following specification:
          Family: Dreamweaver
          MinVersion: 0.0.0.0
      ERROR: The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11de_DELanguagePack  {D60F3637-77A6-4FAB-A3FB-F89632B8DABA} requires a parent with following specification:
          Family: Dreamweaver
          MinVersion: 0.0.0.0
      ERROR: The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11en_USLanguagePack  {F19DAA62-588A-46D3-A092-C808F565D633} requires a parent with following specification:
          Family: Dreamweaver
          MinVersion: 0.0.0.0
      ERROR: The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11nl_NLLanguagePack  {FDE18649-FD4C-4E06-9648-F8437A7AB8AC} requires a parent with following specification:
          Family: Dreamweaver
          MinVersion: 0.0.0.0
      ERROR: The extension payload: Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11es_ESLanguagePack  {FEB38268-97C6-4C14-9786-2A81A2AC7B6E} requires a parent with following specification:
          Family: Dreamweaver
          MinVersion: 0.0.0.0
      ERROR: The base product is not installed, Unable to proceed with the patch operation
      Search the same string above to find when the error occured.
      Exit Code: 28 - The base product is not installed
      END - Installer Session
