3 Replies Latest reply on Apr 11, 2011 4:47 AM by jexer
    Cant open a simple XML file.
    jexer Level 1
      Hello
      This has probably been answered, but the search bar in the forum seems to be broken so I couldn't look for it.
      I tried to open an xml file with a simple app:
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
          <fx:Script>
              <![CDATA[
                  import mx.rpc.events.FaultEvent;
                  import mx.rpc.events.InvokeEvent;
                  import mx.rpc.events.ResultEvent;
                  protected function srv_resultHandler(event:ResultEvent):void
                  { trace("result"); }
                  protected function srv_invokeHandler(event:InvokeEvent):void
                  { trace("invoke"); }
                  protected function srv_faultHandler(event:FaultEvent):void
                  { trace("fault"); }
                  protected function button1_clickHandler(event:MouseEvent):void
                  { trace("breakpoint");    }
          </fx:Script>
          <fx:Declarations>
              <s:HTTPService id="srv" url="data.xml"
                             result="srv_resultHandler(event)"
                             invoke="srv_invokeHandler(event)"
                             fault="srv_faultHandler(event)"/>
          </fx:Declarations>
          <s:Button click="button1_clickHandler(event)"/>
      </s:Application>
      The HTTPService gives me nothing; no error event, no success event, no invoke. When I freeze the program and look at the "srv", it doesn't seem to contain anything useful, like anything to take data from.
      The data.xml is both at the src-folder and its parent folder, and it looks like this:
      <root>
          <chart>
              <set>
                  <x>1</x>
                  <y>1</y>
              </set>
              <set>
                  <x>2</x>
                  <y>4</y>
              </set>
          </chart>
      </root>
      Why doesn't this work?
        • 1. Re: Cant open a simple XML file.
          EdAlive Level 1
          I've never used HTTPService to load xml.
          Here's how I've been doing it, if it helps.
          protected function init():void
               var loader:URLLoader = new URLLoader();
               loader.addEventListener(Event.COMPLETE, loader_completehandler);
               loader.load(new URLRequest('http://www.test.com/test.xml'));   // or relative url path
          protected function loader_completehandler(e:Event):void
               var xml:XML = new XML((e.target as URLLoader).data);
          • 2. Re: Cant open a simple XML file.
            Nuwan,Chamara Level 1
            I can't see in your code that you are using srv.send().
            Try calling srv.send() at the creation complete event handler to load the xml.
            • 3. Re: Cant open a simple XML file.
              jexer Level 1
              Thanks Nuwan
              It was missing the .send() command.
              I made the code after an example in TourDeFlex, and just couldn't spot the .send() that was in there. I've encountered so many bugs and inconsistent things in Flex that I just thought this is another bug or something.
              Thanks Edwan, too. I used to use the URLLoader but the HTTPService shrinks the 5 lines to one so I thought I'd figure that one out.
