1 Reply Latest reply on Apr 12, 2011 4:14 PM by rizwan.54
    Book transfered to Kobo not showing up in library
    celebryson1
      I use Kobo reader and recently purchased a EPUB book from another source and installed ADE following installation instructions. When I open up ADE on my computer, it recognizes my Kobo reader as a bookshelf. I used drag and drop to add the book to Kobo, but it doesn't appear on my reader. I've downloaded EPUB from other (non-protected) sources before and it worked fine. If I open my Kobo application on the computer, I do see the book there.
      Anyone have a clue how to fix this? I've lost patience with help files on all applications.
      Thanks in advance.
        • 1. Re: Book transfered to Kobo not showing up in library
          rizwan.54 Level 1
          In order to fix this you may follow the steps as given below.
          Solution ) Delete following folder from your computer.
          C:\Documents and Settings\sali\My Documents\My Digital Editions\Restore
          HD:\Users\UserName\Digital Editions\Restore (If your are using MAC)
          Now download the same book once again and while downloading the book it will give you three options "Open" , "Save" , "Cancel"
          Click on save and it should save on following location.: C:\Documents and Settings\UserName\My Documents\Downloads
          Now go to the location where you have downloaded book
          Right click on the book and select Open with.
          Now select Adobe Digital Editions
          Now the book should open in Digital Editions.
          I hope this will help you!!!
          Regards
          Rizwan
