10 Replies Latest reply on May 21, 2011 2:08 AM by 300L
    Import .MOV
    300L
      Hi, after a windows 7 reinstall I can't import my .MOV (Apple Photo JPEG) files anymore. I have tried QuickTime 7.68.75.0, QuickTime 7.69.80.9 and QuickTime_Alternative_322. But no picture in PPCS5, just the audio...
      Is there any 64 bit version of QuickTime or what's the problem?
        • 1. Re: Import .MOV
          the_wine_snob Level 9
          There is no 64-bit version of QT for the PC yet. The newer versions should install all Apple CODEC's, but it seems that something is happening to keep them from being installed on your systm.
          I do not recall if there are any Apple CODEC's that are unlocked, when one upgrades to QT Pro. As I have had the Pro version on all my machines for the full run of the 7.x series, I cannot even check that for you.
          Do you know the exact Apple CODEC used in these MOV files? It might be as simple as getting that CODEC and installing it. Could be one that is NOT included in QT?
          • 2. Re: Import .MOV
            300L Level 1
            From GSpot;
            Codec = jpeg
            Name: Apple Photo JPEG
            Maybe it works with a codec pack like ffdshow or do u know where to find just the "jpeg" codec I need?
            • 3. Re: Import .MOV
              Harm Millaard Level 7
              If you like reinstalling, go ahead and install FFDShow. A rather sure way to cripple your system.
              With MJPEGS, consider Mainconcept or Morgan.
              • 4. Re: Import .MOV
                300L Level 1
                I have installed:
                QuickTime 7.69.80.9
                ffdshow_rev3785_20110323_clsid_x64
                ffdshow_rev3800_20110328
                mjpegcodec-3.2.4
                But it still don't work
                • 5. Re: Import .MOV
                  For Apple's Photo-JPEG CODEC, you might want to look HERE.
                  I've got it installed on my system, and do not recall doing a download/install of it specifically. That could point to it being installed with Apple's QT Pro, which I have on all machines. As all of my QT's are Pro, I cannot even check to see if QT Player (regular) installed it - sorry.
                  • 6. Re: Import .MOV
                    300L Level 1
                    QT Pro doesn't install anything more. It's the same installer.
                    I tried Morgan M-JPEG codec V3 which support QuickTime Photo-jpeg streams. But still the same problem.
                    Good info HERE but no solution or codec to install.
                    I don't know what to do? Maybe next step is to reinstall Premiere Pro....
                    I think there is another problem. Ffdshow don't work...
                    • 7. Re: Import .MOV
                      Colin Brougham Level 6
                      GSpot is pretty much worthless for QuickTime; get MediaInfo instead and analyze a file with it. Go to Text mode and copy and paste the results here.
                      If these are truly PhotoJPEG, there is no reason they won't import into CS5:
                      You have installed a bunch of unnecessary stuff that you should get rid of: ffdshow, QT Alternative, Morgan, and anything else. Just install the latest version of QT Player. Do the files play back in QuickTime Player?
                      • 8. Re: Import .MOV
                        300L-eXqUPO
                        Here are the results from 3 different .MOV files from 3 different cameras. Movie 01 and Movie 02 import fine into CS5 but they just show me the audio (just like without QT installed). Movie 03 works great cause "Format : AVC" instead of "Format : JPEG".
                        Yes the files play back in QuickTime.
                        After uninstalled Morgan it's red marked in GSpot "List codecs and other filters" reason "File Missing".
                        General
                        Complete name                    : E:\Movie 01.MOV
                        Format                           : QuickTime
                        Format/Info                      : Original Apple specifications
                        File size                        : 96.6 MiB
                        Duration                         : 1mn 28s
                        Overall bit rate                 : 9 159 Kbps
                        Encoded date                     : UTC 2010-07-09 22:45:59
                        Tagged date                      : UTC 2010-07-09 22:45:59
                        Writing library                  : pana
                        Video
                        Format                           : JPEG
                        Codec ID                         : jpeg
                        Duration                         : 1mn 28s
                        Bit rate mode                    : Variable
                        Bit rate                         : 9 094 Kbps
                        Width                            : 1 280 pixels
                        Height                           : 720 pixels
                        Display aspect ratio             : 16:9
                        Frame rate mode                  : Constant
                        Frame rate                       : 30.000 fps
                        Compression mode                 : Lossy
                        Bits/(Pixel*Frame)               : 0.329
                        Stream size                      : 95.9 MiB (99%)
                        Language                         : English
                        Audio
                        Format                           : PCM
                        Format settings, Endianness      : Little
                        Format settings, Sign            : Unsigned
                        Codec ID                         : raw
                        Duration                         : 1mn 28s
                        Bit rate mode                    : Constant
                        Bit rate                         : 64.0 Kbps
                        Channel(s)                       : 1 channel
                        Sampling rate                    : 8 000 Hz
                        Bit depth                        : 8 bits
                        Stream size                      : 691 KiB (1%)
                        Language                         : English
                        ______________________________________________________________________
                        General
                        Complete name                    : G:\Movie 02.MOV
                        Format                           : MPEG-4
                        Format profile                   : QuickTime
                        Codec ID                         : qt
                        File size                        : 183 MiB
                        Duration                         : 3mn 23s
                        Overall bit rate                 : 7 550 Kbps
                        Encoded date                     : UTC 2010-11-29 17:26:26
                        Tagged date                      : UTC 2010-11-29 17:26:26
                        Xtra                             : WM/MediaClassPrimaryID
                        Video
                        Format                           : JPEG
                        Codec ID                         : jpeg
                        Duration                         : 3mn 23s
                        Bit rate                         : 7 036 Kbps
                        Height                           : 720 pixels
                        Bits/(Pixel*Frame)               : 0.255
                        Stream size                      : 170 MiB (93%)
                        Language                         : English
                        Audio
                        Format                           : PCM
                        Format settings, Endianness      : Big
                        Format settings, Sign            : Signed
                        Codec ID                         : twos
                        Duration                         : 3mn 23s
                        Bit rate                         : 512 Kbps
                        Channel(s)                       : 2 channels
                        Sampling rate                    : 16.0 KHz
                        Bit depth                        : 16 bits
                        Stream size                      : 12.4 MiB (7%)
                        Language                         : English
                        General
                        Complete name                    : G:\Movie 03.MOV
                        Format                           : MPEG-4
                        Codec ID                         : qt
                        File size                        : 83.7 MiB
                        Duration                         : 21s 80ms
                        Overall bit rate                 : 33.3 Mbps
                        Encoded date                     : UTC 2010-10-30 18:43:23
                        Tagged date                      : UTC 2010-10-30 18:43:23
                        Video
                        Format                           : AVC
                        Format/Info                      : Advanced Video Codec
                        Format profile                   : Baseline@L5.0
                        Format settings, CABAC           : No
                        Format settings, ReFrames        : 1 frame
                        Codec ID                         : avc1
                        Codec ID/Info                    : Advanced Video Coding
                        Duration                         : 21s 80ms
                        Bit rate                         : 31.8 Mbps
                        Width                            : 1 920 pixels
                        Height                           : 1 080 pixels
                        Original height                  : 1 088 pixels
                        Original display aspect ratio    : 16:9
                        Frame rate                       : 25.000 fps
                        Color space                      : YUV
                        Chroma subsampling               : 4:2:0
                        Bit depth                        : 8 bits
                        Scan type                        : Progressive
                        Bits/(Pixel*Frame)               : 0.613
                        Stream size                      : 79.8 MiB (95%)
                        Language                         : English
                        Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
                        Transfer characteristics         : BT.709-5, BT.1361
                        Matrix coefficients              : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
                        Audio
                        Format                           : PCM
                        Codec ID                         : sowt
                        Duration                         : 21s 80ms
                        Bit rate                         : 1 536 Kbps
                        Sampling rate                    : 48.0 KHz
                        Bit depth                        : 16 bits
                        Stream size                      : 3.86 MiB (5%)
                        Language                         : English
                        From properties CS5:
                        File Path: G:\Movie 02.MOV
                        Type: QuickTime Movie
                        File Size: 182,7 MB
                        Source Audio Format: 16000 Hz - 16 bit - Stereo
                        Project Audio Format: 32000 Hz - 32 bit floating point - Stereo
                        Total Duration: 00:03:23:00000
                        Average Data Rate: 921 KB / second
                        QuickTime Details:
                        Movie contains 1 video track(s), 1 audio track(s) and 0 timecode track(s).
                        Video:
                        There are 6090 frames with a duration of 1/30th.
                        Video track 1:
                        Duration is 6090
                        Average frame rate is 30,00 fps
                        Video track 1 contains 1 type(s) of video data:
                        Video data block #1:
                        Frame Size = 1280 x 720
                        Compressor = Photo - JPEG
                        Quality = Normal (3,00)
                        Audio:
                        Audio track 1 contains 1 type(s) of audio data:
                        Audio data block #1:
                        Format = 16 bit - Stereo
                        Rate = 16000 Hz
                        Compressor = twos
                        • 9. Re: Import .MOV
                          cabext
                          Hi
                          I'm curious to know if you have made any progress with this issue since your last post?
                          Even though I'm using Premiere Elements and not Pr. Pro, I have exactly the same problems importing .mov files in photo jpeg. I can play the files in Quick Time and Windows Media Player. But not import into Elements Organiser or Premiere ...
                          Should I try reinstalling Elements?
                          • 10. Re: Import .MOV
                            300L Level 1
                            I reinstalled Premiere Pro CS5 and selected to keep my settings. Still got the problem
                            It's weird that everything was fine before I bought an SSD, changed to ACHI in BIOS, reinstalled Windows 7 x64 and changed some Windows settings for my SSD.
