3 Replies Latest reply on Apr 12, 2011 12:04 PM by Flex harUI
    Get StackTrace of an error in non-debugging mode
    NikitaL
      I have an air application, in which there is a possibility to send logs to support when unhandled exception occured.
      I'm adding stackTrace of an error to the log before sending them.
      When the app is launched from Flex Builder everything works fine, but when the app was installed on the machine I get null instead of the stackTrace
      There is some code
      private function app_complete(e : Event) : void
           loaderInfo.uncaughtErrorEvents.addEventListener(UncaughtErrorEvent.UNCAUGHT_ERROR, app_UncaughtError);
      private function app_UncaughtError(event : UncaughtErrorEvent) : void
           var message : String;
           if (event.error is Error)
                message = (event.error as Error).getStackTrace();
           sendLog(message);
      I know that the getStackTrace method is for debug versions only, and it returns null in non-debugging mode. But I realy need to get StackTrace in non-debugging mode. Maybe there a way to make this method return not null value. Or maybe someone knows another way?
