ok, JESUS this is pissing me off sooo much!
so i made this thing (i wont post it all here) and it works
perfectly.
it uses an init() function, which sets the Interval for the
test() function. now the test() function requires an outside
variable, which is defined earlier, and it can easily get it. then
when its done, it uses the clearInterval() function and it stops
it.
No Problems!
quote:
var hold;
function init()
hold = setInterval(process, 200);
function process()
trace("ok");
clearInterval(hold);
init();
Now i try to make it into a class!
quote:
class demo
var hold;
var testvaribale = "asd123";
function init()
this.hold = setInterval(process, 200, this.testvaribale);
function process(testvar)
trace(testvar);
clearInterval(this.hold);
import demo;
var Demo = new demo();
Demo.init();
there are two MAJOR problems:
1) the process() function run by itself
CAN grab any variable, example: trace(this.testvariable);
would output "asd123". but the process() function run by the init()
using the interval, can NOT grab any variables. the previous code
would output "undefined". i can pass variables through the
setInterval code, and that has worked up until problem #2
2) clearInterval() does NOT work at all. using hold,
this.hold, or hold2 (a variable passed throught the setInterval
code), it will not clear the interval.
can someone
please
help me with this?
