1. Re: Photoshop crashes in OSX 10.6.7
c.pfaffenbichler Apr 11, 2011 9:13 AM (in response to Trophy92)Has OnOne Photoframes be upgraded for CS5 (assuming you work with CS5 which you don’t mention)?
Boilerplate-text:
As with all unexplainable Photoshop-problems you might try trashing the prefs (after making sure all customized presets like Actions, Patterns, Brushes etc. have been saved and making a note of the Preferences you’ve changed) by pressing command-alt-shift on starting the program or starting from a new user-account.
System Maintenance (repairing permissions, purging PRAM, running cron-scripts, cleaning caches, etc.) might also be beneficial, Onyx has been recommended for such tasks.
http://www.apple.com/downloads/macosx/system_disk_utilities/onyx.html
Weeding out bad fonts never seems to be a bad idea, either. (Validate your fonts in Font Book and remove the bad ones.)
If 3rd party plug-ins are installed try disabling them to verify if one of those may be responsible for the problem.
2. Re: Photoshop crashes in OSX 10.6.7
Jeffrey Tranberry Apr 11, 2011 9:34 AM (in response to Trophy92)Contact OnOne...see if they have an update.
3. Re: Photoshop crashes in OSX 10.6.7
Trophy92 Apr 11, 2011 10:33 AM (in response to Jeffrey Tranberry)I am using the latest edition of the OnOne Plugin suite which is 5.5.1 and has been working in CS5 (latest version) with no problems all year. I contacted OnOne and they sent me an uninstall script which I ran to remove all the Suite, re-installed the suite, activated it and again it crashed as soon as I said apply frame.
I have been having other problems the last two days with Finder re-booting when using Photoshop which closes down Aperture and Photoshop and any work not saved in Photoshop is lost. This is random but seems to happen after working on an image for a long time. Regularly saving does not prevent the crash or reboot of Photoshop.
I am not the only one, someone on the Apple community is also having issues when working in Photoshop and suddenly you get a blue screen and Finder reboots.
4. Re: Photoshop crashes in OSX 10.6.7
c.pfaffenbichler Apr 11, 2011 10:37 PM (in response to Trophy92)If I understand correctly no program should be able to crash the Mac OS, so I suspect the issue may lie with that.
What trouble-shooting and System maintenance procedures have you performed so far?
5. Re: Photoshop crashes in OSX 10.6.7
Trophy92 Apr 12, 2011 12:57 AM (in response to c.pfaffenbichler)I contacted OnOne about Photoframes crashing Photoshop and they are looking into it and cannot repeat. I have CS3 on my desktop as well and Photoframes installed in there. I applied a frame to the same image in CS3 twice with no problem.
I will try in CS5 again using the File> automate command rather than the palette as suggested by OnOne.
As for the blue screen that is different to the OnOne issue. I will just be working in Photoshop having opened up my image from Aperture as a 16 bit psd and just doing simple adjustments such as cloning or layer adjustments when suddenly the screen will go blue, Finder reboots and everything goes back to normal except Photoshop and Aperture have closed down. This must be an OSX 10.6.7 and Photoshop issue as I never have this problem when not working in Photoshop.
6. Re: Photoshop crashes in OSX 10.6.7
Trophy92 Apr 12, 2011 12:58 AM (in response to Trophy92)Forgot to say have tried rebooting computer, running disk utility to repair permissions and currently running Tech Tool 5.
7. Re: Photoshop crashes in OSX 10.6.7
Chris Cox Apr 12, 2011 8:54 AM (in response to Trophy92)Do you have the crash log? If we can look at that, we could confirm the cause.
The other issue almost sounds like you accidentally did a fast user change somehow.
8. Re: Photoshop crashes in OSX 10.6.7
Trophy92 Apr 12, 2011 10:09 AM (in response to Chris Cox)Where do I find the crash report?
I logged in as another user and again Photoshop crashes with OnOne Photoframes. I tried using CS3, which I also have installed, yesterday and had no problems applying a frame and while I was using it no problems with the blue screen.
I tried again with CS5 this afternoon and again after applying my changes to the image and having done some cloning the screen suddenly went blue and finder reboots, all within a few minutes after opening. How can I do a fast user change? This time I did not have time to try and use Photoframes. No report after after blue screen of course. What I have noticed is that my Mobile me idisk does not reconnect.
I get a message requesting to send a report to Adobe which I do, where does that go? I did copy some crash reports after the OnOne crashes, example below:
Process: Adobe Photoshop CS5 [951]
Path: /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/MacOS/Adobe Photoshop CS5
Identifier: com.adobe.Photoshop
Version: 12.0.2 (12.0.2x20101122.r.1204) (12.0.2)
Code Type: X86-64 (Native)
Parent Process: launchd [156]
Date/Time: 2011-04-11 17:33:52.944 +0100
OS Version: Mac OS X 10.6.7 (10J869)
Report Version: 6
Interval Since Last Report: 352753 sec
Crashes Since Last Report: 9
Per-App Interval Since Last Report: 121874 sec
Per-App Crashes Since Last Report: 5
Anonymous UUID: 40024EDD-0698-4BA7-B352-F0098911E525
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libstdc++.6.dylib 0x00007fff806ea7cd __dynamic_cast + 89
1 com.adobe.owl 0x00000001036b1e47 OWLRegisterSnapTargetWindow + 54681
2 com.adobe.owl 0x00000001036abb06 OWLRegisterSnapTargetWindow + 29272
3 com.adobe.owl 0x000000010364367b 0x10363e000 + 22139
4 com.adobe.owl 0x000000010364292f 0x10363e000 + 18735
5 com.adobe.owl 0x000000010365baee 0x10363e000 + 121582
6 com.apple.AppKit 0x00007fff80f6ccf9 -[NSView _drawRect:clip:] + 3566
7 com.apple.AppKit 0x00007fff80f6a4cf -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 2112
8 com.apple.AppKit 0x00007fff80f6ae5a -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
9 com.apple.AppKit 0x00007fff80f6ae5a -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 4555
10 com.apple.AppKit 0x00007fff810888e4 -[NSNextStepFrame _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 276
11 com.apple.AppKit 0x00007fff80f66362 -[NSView _displayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] + 2683
12 com.apple.AppKit 0x00007fff80edfb9a -[NSView displayIfNeeded] + 969
13 com.apple.AppKit 0x00007fff80e9539c -[NSNextStepFrame displayIfNeeded] + 76
14 com.apple.AppKit 0x00007fff80edaa46 _handleWindowNeedsDisplay + 678
15 com.apple.CoreFoundation 0x00007fff85a48b37 __CFRunLoopDoObservers + 519
16 com.apple.CoreFoundation 0x00007fff85a24464 __CFRunLoopRun + 468
17 com.apple.CoreFoundation 0x00007fff85a23dbf CFRunLoopRunSpecific + 575
18 com.apple.HIToolbox 0x00007fff8520e7ee RunCurrentEventLoopInMode + 333
19 com.apple.HIToolbox 0x00007fff8520e551 ReceiveNextEventCommon + 148
20 com.apple.HIToolbox 0x00007fff8520e4ac BlockUntilNextEventMatchingListInMode + 59
21 com.apple.AppKit 0x00007fff80eafe64 _DPSNextEvent + 718
22 com.apple.AppKit 0x00007fff80eaf7a9 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155
23 com.apple.AppKit 0x00007fff810eac47 -[NSApplication _realDoModalLoop:peek:] + 442
24 com.apple.AppKit 0x00007fff810e87d5 -[NSApplication runModalForWindow:] + 129
25 com.yourcompany.ONProxySupport 0x0000000106f9e424 -[ONWaitDlgCtrlr run] + 502
26 ...frame45.professional.filter 0x000000017d11ccc0 CPSCtrlr::Run() + 94
27 ...frame45.professional.filter 0x000000017d139e11 CPluginProxyFilter::DoStart() + 257
28 ...frame45.professional.filter 0x000000017d13749c PluginMainPhotoFrame + 380
29 com.adobe.Photoshop 0x0000000100700719 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4339001
30 com.adobe.Photoshop 0x00000001004378af AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1418959
31 com.adobe.Photoshop 0x000000010043bf38 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1437016
32 com.adobe.Photoshop 0x000000010043507c AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1408668
33 com.adobe.Photoshop 0x00000001004396c0 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1426656
34 com.adobe.Photoshop 0x000000010075db81 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4721057
35 com.adobe.Photoshop 0x000000010075e5e7 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4723719
36 com.adobe.Photoshop 0x0000000100435f71 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1412497
37 com.adobe.Photoshop 0x000000010075a136 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4706134
38 com.adobe.Photoshop 0x000000010075a56f AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4707215
39 com.adobe.Photoshop 0x0000000100436288 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1413288
40 com.adobe.Photoshop 0x0000000100439685 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1426597
41 com.adobe.Photoshop 0x00000001004b3232 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1925202
42 com.adobe.Photoshop 0x00000001004b452f AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1930063
43 com.adobe.Photoshop 0x0000000100071ca6 0x100000000 + 466086
44 com.adobe.Photoshop 0x00000001000670bf 0x100000000 + 422079
45 com.adobe.Photoshop 0x0000000100067182 0x100000000 + 422274
46 com.adobe.Photoshop 0x000000010024f957 0x100000000 + 2423127
47 com.adobe.Photoshop 0x0000000100278f47 0x100000000 + 2592583
48 ...toframe45.professional.auto 0x0000000122d85403 AutomationFilterPlugin::ExecuteHiddenFilter() + 3507
49 ...toframe45.professional.auto 0x0000000122d88056 Execute(void*) + 22
50 com.adobe.Photoshop 0x00000001004d3773 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 2057619
51 com.adobe.Photoshop 0x00000001002798d3 0x100000000 + 2595027
52 ...toframe45.professional.auto 0x0000000122d802d6 AutomationFilterPlugin::DoIt(PSActionsPlugInMessage*) + 278
53 ...toframe45.professional.auto 0x0000000122d7fcb8 AutomationFilterPlugin::Message(char const*, char const*, void*) + 40
54 ...toframe45.professional.auto 0x0000000122da389b AutoPluginMain + 91
55 com.adobe.Photoshop 0x00000001006fe977 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4331415
56 com.adobe.Photoshop 0x0000000100277e3c 0x100000000 + 2588220
57 com.adobe.Photoshop 0x0000000100277fb9 0x100000000 + 2588601
58 com.adobe.Photoshop 0x0000000100071ca6 0x100000000 + 466086
59 com.adobe.Photoshop 0x00000001000670bf 0x100000000 + 422079
60 com.adobe.Photoshop 0x0000000100067182 0x100000000 + 422274
61 com.adobe.Photoshop 0x000000010024f957 0x100000000 + 2423127
62 com.adobe.Photoshop 0x0000000100278f47 0x100000000 + 2592583
63 com.adobe.PSAutomate 0x00000001231ffd35 CPsWActionControl::PlayNoThrow(CPsWActionDescriptor&, unsigned int, CPsWActionDescriptor const&) + 25
64 com.adobe.PSAutomate 0x00000001231fffc9 CPsWActionControl::Play(CPsWActionDescriptor&, unsigned int, CPsWActionDescriptor const&) + 17
65 com.adobe.PSAutomate 0x00000001231c477e CPsApplication::DoExecuteAction(int, MultiScript::InterfacePtr<CPsActionDescriptor> const*, HostDialogModes const*, MultiScript::InterfacePtr<CPsActionDescriptor>&) + 220
66 com.adobe.PSAutomate 0x000000012317adc7 CPsApplication::HostCall(int, ScCore::Array const&, ScCore::Variant&) + 4621
67 com.adobe.PSAutomate 0x0000000123217784 MultiScript::TProxyBase<ScCore::LiveObject>::call(int, ScCore::Array const&, ScCore::Variant&, ScCore::Error*) + 110
68 com.adobe.AdobeScCore 0x00000001236facc6 ScCore::LiveObject::call(ScCore::String const&, ScCore::Array const&, ScCore::Variant&, ScCore::Error*) + 246
69 com.adobe.AdobeScCore 0x0000000123754836 APEObjectInvokeMethodCB(Opaque_APEPlayer*, void*, void*, APEOpaqueAtom*, unsigned int, APEOpaqueAtom* const*) + 854
70 com.adobe.adobeswfl 0x00000001248343eb APXGetHostAPI + 27483
71 ??? 0x000000012a289276 0 + 5002269302
72 ??? 0x000000012a282de7 0 + 5002243559
73 ??? 0x000000012a28a1d3 0 + 5002273235
74 ??? 0x000000012a28a2c0 0 + 5002273472
75 ??? 0x000000012a28a5cb 0 + 5002274251
76 ??? 0x000000012a28a743 0 + 5002274627
77 com.adobe.adobeswfl 0x0000000124ea3b2d SWFLPlayer_Initialize + 2204989
78 com.adobe.adobeswfl 0x000000012491b1ae APXGetHostAPI + 973086
79 com.adobe.adobeswfl 0x0000000124912cd3 APXGetHostAPI + 939075
80 com.adobe.adobeswfl 0x000000012491ece3 APXGetHostAPI + 988243
81 com.adobe.adobeswfl 0x0000000124a9885c APXGetHostAPI + 2535372
82 ??? 0x00000001296c719e 0 + 4989940126
83 ??? 0x000000012a3b93ff 0 + 5003514879
84 ??? 0x000000012a28a9fb 0 + 5002275323
85 com.adobe.adobeswfl 0x0000000124ea3b2d SWFLPlayer_Initialize + 2204989
86 com.adobe.adobeswfl 0x000000012491b1ae APXGetHostAPI + 973086
87 com.adobe.adobeswfl 0x0000000124912dfd APXGetHostAPI + 939373
88 com.adobe.adobeswfl 0x000000012491e064 APXGetHostAPI + 985044
89 com.adobe.adobeswfl 0x0000000124c3027c APXGetHostAPI + 4205036
90 com.adobe.adobeswfl 0x0000000124d1cf33 SWFLPlayer_Initialize + 604483
91 com.adobe.adobeswfl 0x0000000124c8c50f SWFLPlayer_Initialize + 12063
92 com.adobe.adobeswfl 0x0000000124c9077f SWFLPlayer_Initialize + 29071
93 com.adobe.ape 0x00000001237d9abd APEStreamWrite + 10285
94 com.adobe.ape 0x00000001237dcf8e APEStreamWrite + 23806
95 com.adobe.ape 0x00000001237df05b APEStreamWrite + 32203
96 com.apple.AppKit 0x00007fff80fa93d9 -[NSWindow sendEvent:] + 5547
97 com.adobe.owl 0x0000000103676f55 OWLRemoveObjCExceptionCallback + 617
98 com.adobe.owl 0x0000000103678fa4 OWLRemoveObjCExceptionCallback + 8888
99 com.apple.AppKit 0x00007fff80edea86 -[NSApplication sendEvent:] + 4719
100 com.adobe.Photoshop 0x00000001012e251e AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 16798526
101 com.adobe.Photoshop 0x00000001012e1cd1 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 16796401
102 com.apple.AppKit 0x00007fff80e754da -[NSApplication run] + 474
103 com.adobe.Photoshop 0x00000001012e0594 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 16790452
104 com.adobe.Photoshop 0x00000001012e0ff1 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 16793105
105 com.adobe.Photoshop 0x0000000100068dd2 0x100000000 + 429522
106 com.adobe.Photoshop 0x0000000100238151 0x100000000 + 2326865
107 com.adobe.Photoshop 0x00000001002381e1 0x100000000 + 2327009
108 com.adobe.Photoshop 0x0000000100002df4 0x100000000 + 11764
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x00007fff8495512a kevent + 10
1 libSystem.B.dylib 0x00007fff84956ffd _dispatch_mgr_invoke + 154
2 libSystem.B.dylib 0x00007fff84956cd4 _dispatch_queue_invoke + 185
3 libSystem.B.dylib 0x00007fff849567fe _dispatch_worker_thread2 + 252
4 libSystem.B.dylib 0x00007fff84956128 _pthread_wqthread + 353
5 libSystem.B.dylib 0x00007fff84955fc5 start_wqthread + 13
Thread 2:
0 libSystem.B.dylib 0x00007fff84976f8a __semwait_signal + 10
1 libSystem.B.dylib 0x00007fff8497ada1 _pthread_cond_wait + 1286
2 com.adobe.amt.services 0x0000000108563c53 AMTConditionLock::LockWhenCondition(int) + 37
3 com.adobe.amt.services 0x000000010855ccce _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 92
4 com.adobe.amt.services 0x0000000108563cbe AMTThread::Worker(void*) + 28
5 libSystem.B.dylib 0x00007fff849754f6 _pthread_start + 331
6 libSystem.B.dylib 0x00007fff849753a9 thread_start + 13
Thread 3:
0 libSystem.B.dylib 0x00007fff8493c2ee semaphore_timedwait_trap + 10
1 ...ple.CoreServices.CarbonCore 0x00007fff87e461de MPWaitOnSemaphore + 96
2 MultiProcessor Support 0x000000011ede5b9b ThreadFunction(void*) + 69
3 ...ple.CoreServices.CarbonCore 0x00007fff87db1335 PrivateMPEntryPoint + 63
4 libSystem.B.dylib 0x00007fff849754f6 _pthread_start + 331
5 libSystem.B.dylib 0x00007fff849753a9 thread_start + 13
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
2 ...ple.CoreServices.CarbonCore 0x00007fff87e6fe13 TSWaitOnCondition + 118
3 ...ple.CoreServices.CarbonCore 0x00007fff87ddf268 TSWaitOnConditionTimedRelative + 177
4 ...ple.CoreServices.CarbonCore 0x00007fff87dd9173 MPWaitOnQueue + 215
5 AdobeACE 0x000000010597718d 0x10593d000 + 237965
6 AdobeACE 0x0000000105976b3a 0x10593d000 + 236346
7 ...ple.CoreServices.CarbonCore 0x00007fff87db1335 PrivateMPEntryPoint + 63
8 libSystem.B.dylib 0x00007fff849754f6 _pthread_start + 331
9 libSystem.B.dylib 0x00007fff849753a9 thread_start + 13
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
1 libSystem.B.dylib 0x00007fff84976e19 nanosleep + 148
2 com.adobe.PSAutomate 0x00000001232f109b ScObjects::Thread::sleep(unsigned int) + 59
3 com.adobe.PSAutomate 0x00000001232d2fd3 ScObjects::BridgeTalkThread::run() + 163
4 com.adobe.PSAutomate 0x00000001232f1196 ScObjects::Thread::go(void*) + 166
Thread 42:
2 com.adobe.adobeswfl 0x0000000124a8789d APXGetHostAPI + 2465805
3 com.adobe.adobeswfl 0x00000001248405e9 APXGetHostAPI + 77145
4 com.adobe.adobeswfl 0x0000000124a879b1 APXGetHostAPI + 2466081
5 com.adobe.adobeswfl 0x0000000124a87d1a APXGetHostAPI + 2466954
6 com.adobe.adobeswfl 0x0000000124a87e49 APXGetHostAPI + 2467257
7 libSystem.B.dylib 0x00007fff849754f6 _pthread_start + 331
8 libSystem.B.dylib 0x00007fff849753a9 thread_start + 13
Thread 43:
Thread 44:
Thread 45:
Thread 46:
Thread 47:
Thread 48:
Thread 49:
Thread 50:
Thread 51:
Thread 52:
Thread 53:
Thread 54:
0 libSystem.B.dylib 0x00007fff8493c29a mach_msg_trap + 10
1 libSystem.B.dylib 0x00007fff8493c90d mach_msg + 59
2 com.apple.CoreFoundation 0x00007fff85a24932 __CFRunLoopRun + 1698
3 com.apple.CoreFoundation 0x00007fff85a23dbf CFRunLoopRunSpecific + 575
4 com.apple.CoreMediaIOServices 0x00007fff82b0662b MIO::DAL::RunLoop::OwnThread(void*) + 147
5 com.apple.CoreMediaIOServices 0x00007fff82b081f6 CAPThread::Entry(CAPThread*) + 140
6 libSystem.B.dylib 0x00007fff849754f6 _pthread_start + 331
7 libSystem.B.dylib 0x00007fff849753a9 thread_start + 13
Thread 55:
0 libSystem.B.dylib 0x00007fff8493c2fa semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x00007fff8497ac92 _pthread_cond_wait + 1015
2 com.adobe.adobeswfl 0x0000000124a87869 APXGetHostAPI + 2465753
3 com.adobe.adobeswfl 0x0000000124aa40ec APXGetHostAPI + 2582620
Thread 56:
3 com.adobe.adobeswfl 0x0000000124c21ef3 APXGetHostAPI + 4146787
Thread 57:
0 libSystem.B.dylib 0x00007fff8497fe76 recvfrom + 10
1 ServiceManager-Launcher.dylib 0x0000000129596982 Invoke + 54020
2 ServiceManager-Launcher.dylib 0x0000000129595adf Invoke + 50273
3 ServiceManager-Launcher.dylib 0x0000000129594b26 Invoke + 46248
4 ServiceManager-Launcher.dylib 0x0000000129594b81 Invoke + 46339
5 ServiceManager-Launcher.dylib 0x0000000129594c02 Invoke + 46468
6 ServiceManager-Launcher.dylib 0x000000012958f30d Invoke + 23695
7 ServiceManager-Launcher.dylib 0x000000012958f4a6 Invoke + 24104
8 ServiceManager-Launcher.dylib 0x000000012958ff2f Invoke + 26801
9 ServiceManager-Launcher.dylib 0x000000012959001d Invoke + 27039
10 ServiceManager-Launcher.dylib 0x000000012959331f Invoke + 40097
11 ServiceManager-Launcher.dylib 0x00000001295935c5 Invoke + 40775
12 ServiceManager-Launcher.dylib 0x0000000129593b84 Invoke + 42246
13 ServiceManager-Launcher.dylib 0x0000000129593d71 Invoke + 42739
14 ServiceManager-Launcher.dylib 0x0000000129585daf Login + 1773
15 ServiceManager-Launcher.dylib 0x0000000129587295 Login + 7123
16 ServiceManager-Launcher.dylib 0x00000001295942a8 Invoke + 44074
17 ServiceManager-Launcher.dylib 0x00000001295966c1 Invoke + 53315
18 libSystem.B.dylib 0x00007fff849754f6 _pthread_start + 331
19 libSystem.B.dylib 0x00007fff849753a9 thread_start + 13
Thread 58:
Thread 59:
Thread 60:
2 libtbb.dylib 0x0000000106aab22c tbb::internal::GenericScheduler::wait_while_pool_is_empty() + 92
3 libtbb.dylib 0x0000000106ab5b84 tbb::internal::CustomScheduler<tbb::internal::IntelSchedulerTraits>::wait_for_all(tbb::ta sk&, tbb::task*) + 1858
4 libtbb.dylib 0x0000000106aade3a tbb::internal::GenericScheduler::worker_routine(void*) + 632
Thread 61:
Thread 62:
Thread 63:
Thread 64:
Thread 65:
Thread 66:
Thread 67:
Thread 68:
Thread 69:
Thread 70:
Thread 71:
Thread 72:
Thread 73:
Thread 74:
Thread 75:
Thread 76:
Thread 77:
Thread 78:
Thread 79:
Thread 80:
Thread 81:
Thread 82:
Thread 83:
Thread 84:
2 com.apple.Foundation 0x00007fff8022b5d8 -[NSCondition wait] + 277
3 com.apple.Foundation 0x00007fff80218bc3 -[NSObject(NSThreadPerformAdditions) performSelector:onThread:withObject:waitUntilDone:modes:] + 916
4 com.apple.Foundation 0x00007fff8022b92c -[NSObject(NSThreadPerformAdditions) performSelectorOnMainThread:withObject:waitUntilDone:] + 143
5 com.apple.AppKit 0x00007fff810eaa63 -[NSApplication _doModalLoop:peek:] + 180
6 com.apple.AppKit 0x00007fff81108a13 -[NSApplication runModalSession:] + 57
7 ...toframe45.professional.auto 0x0000000122dada54 -[PFBatchProgressDialogMac runDialog:] + 148
8 com.apple.Foundation 0x00007fff80201f29 __NSThread__main__ + 1429
9 libSystem.B.dylib 0x00007fff849754f6 _pthread_start + 331
10 libSystem.B.dylib 0x00007fff849753a9 thread_start + 13
Thread 85:
2 com.ononesoftware.ONCore 0x000000017d2ea6e3 CBaseCondition::Wait(__ONMutex*, unsigned int) + 55
3 ...frame45.professional.filter 0x000000017d11c4c1 CPSCtrlr::ListenForRequests() + 179
4 ...frame45.professional.filter 0x000000017d11c580 CPSCtrlr::sThreadProc(__ONThread*, void*) + 12
5 com.ononesoftware.ONCore 0x000000017d2ef155 CBaseThread::sThreadProc(void*) + 43
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00000001030000c0 rbx: 0x000000013ad0e4f0 rcx: 0x0000000000000000 rdx: 0x000000010383fe70
rdi: 0x0000000000000000 rsi: 0x000000010383fe50 rbp: 0x00007fff5fbf5aa0 rsp: 0x00007fff5fbf5a50
r8: 0x000000013ad0e4f0 r9: 0x00000001084fc0a4 r10: 0x000000000000001a r11: 0x000000010849a950
r12: 0x000000010383fe50 r13: 0x0000000000000000 r14: 0x000000010383fe70 r15: 0x00000001036a900e
rip: 0x00007fff806ea7cd rfl: 0x0000000000010206 cr2: 0x0000000000000000
Binary Images:
0x100000000 - 0x1026ebfff +com.adobe.Photoshop 12.0.2 (12.0.2x20101122.r.1204) (12.0.2) <A7C6FF45-FF8B-5ECA-247C-D09BA0BBF589> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/MacOS/Adobe Photoshop CS5
0x1032e0000 - 0x103358fef +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <4A355686-1451-B19A-0C55-DFE49FD2539E> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
0x10336e000 - 0x103375fff org.twain.dsm 1.9.4 (1.9.4) <D32C2B79-7DE8-1609-6BD4-FB55215BD75B> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
0x10337d000 - 0x10338dff8 +com.adobe.ahclientframework 1.5.0.30 (1.5.0.30) <5D6FFC4E-7B81-3E8C-F0D4-66A3FA94A837> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0x103398000 - 0x10339eff7 com.apple.agl 3.0.12 (AGL-3.0.12) <014CA38F-CB49-8214-4C16-DF73FC6EFCE1> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x1033a5000 - 0x1035abfef +com.adobe.linguistic.LinguisticManager 5.0.0 (11696) <499B4E7A-08BB-80FC-C220-D57D45CA424F> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
0x10363e000 - 0x1037ecfef +com.adobe.owl AdobeOwl version 3.0.93 (3.0.93) <74CF40F6-B216-DB73-5C8F-FC5533220CD9> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x10388e000 - 0x103cbefef +AdobeMPS ??? (???) <0F44873E-F5B1-D538-0BEB-8FDFD09102D6> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x103e18000 - 0x104143ff7 +AdobeAGM ??? (???) <52E17D56-6E7A-A635-82ED-5DE1F3E5045D> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x104210000 - 0x104538fe7 +AdobeCoolType ??? (???) <9979447D-9477-BC48-A84E-8A6A6AF380B5> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x1045d0000 - 0x1045f1ff7 +AdobeBIBUtils ??? (???) <F7150688-2C15-0F0C-AF24-93ED82FC321A> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x1045fe000 - 0x104629ff6 +AdobeAXE8SharedExpat ??? (???) <7E809606-BF97-DB3A-E465-156446E56D00> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
0x10463b000 - 0x10477ffef +WRServices ??? (???) <76354373-F0BD-0BAF-6FC0-B96DBB371755> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
0x1047c6000 - 0x10482bfff +aif_core ??? (???) <12FA670E-05A8-1FCB-A7A2-AAE68728EA30> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
0x104847000 - 0x10485dfff +data_flow ??? (???) <9C5D39A6-D2A2-9B6A-8B64-D1B59396C112> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
0x104875000 - 0x10490bfff +image_flow ??? (???) <B72AA922-0D68-D57E-96B1-2E009B0AD4AE> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flow
0x104982000 - 0x1049a0fff +image_runtime ??? (???) <32786637-C9BF-4CB6-2DF9-5D99220E00BE> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
0x1049bd000 - 0x104becfff +aif_ogl ??? (???) <615E7DF6-09B1-857A-74AC-E224A636BEE1> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
0x104ccb000 - 0x104d5efff +AdobeOwlCanvas ??? (???) <EC667F6D-0BB6-03EA-41E8-624425B2BF4B> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeOwlCanvas.framework/Versions/A/AdobeOwlCanvas
0x104d7e000 - 0x1050c7fef +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.0) <023E0760-0223-AB5D-758C-2C5A052F6AF4> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0x105257000 - 0x1053d9fe7 +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.0) <42077295-9026-D519-C057-35E07029D97B> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x10547b000 - 0x1057f3fff +com.adobe.dvaadameve.framework dvaadameve version 5.0.0 (5.0.0.0) <0E95A0DF-038A-CFF2-EC7B-BDB905CDF5C5> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
0x10593d000 - 0x105a52fff +AdobeACE ??? (???) <C544307E-C1E6-FCA8-4D32-2EC0D5820BBD> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x105a77000 - 0x105a93fff +AdobeBIB ??? (???) <7A792F27-42CC-2DCA-D5DF-88A2CE6C2626> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x105a9d000 - 0x105b07ff7 +com.adobe.amtlib amtlib 3.0.0.64 (3.0.0.64) <6B2F73C2-10AB-08B3-4AB0-A31C83D1E5E0> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x105b3a000 - 0x105c0dffb +AdobeJP2K ??? (???) <465D1693-BE79-590E-E1AA-BAA8061B4746> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x105c2d000 - 0x105c31ff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <0C380604-C686-C2E4-0535-C1FAB230187E> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
0x105c35000 - 0x105cacfff +FileInfo ??? (???) <6D5235B9-0EB6-17CA-6457-A2507A87EA8F> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
0x105ccd000 - 0x105d2bffd +AdobeXMP ??? (???) <561026BB-C6EA-29CE-4790-CABCB81E8884> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x105d39000 - 0x1061d4fff +com.nvidia.cg 2.2.0006 (???) /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/Cg.framework/Cg
0x10675a000 - 0x1067b0feb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.011) <03B80698-2C3B-A232-F15F-8F08F8963A19> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
0x1067f5000 - 0x10681affe +adobepdfsettings ??? (???) <56E7F033-6032-2EC2-250E-43F1EBD123B1> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/adobepdfsettings.framework/Versions/A/adobepdfsettings
0x106854000 - 0x106859ffd +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <DFFB9A08-8369-D65F-161F-7C61D562E307> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
0x10685e000 - 0x1069fafff +com.adobe.PlugPlug 2.0.0.109 (2.0.0.109) <83092855-E671-F64A-EE0D-1110CF669634> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
0x106aa2000 - 0x106abbfeb +libtbb.dylib ??? (???) /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/libtbb.dylib
0x106acc000 - 0x106ad2feb +libtbbmalloc.dylib ??? (???) /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/libtbbmalloc.dylib
0x106ad9000 - 0x106ad9ff7 libmx.A.dylib 315.0.0 (compatibility 1.0.0) <B146C134-CE18-EC95-12F8-E5C2BCB43A6B> /usr/lib/libmx.A.dylib
0x106adc000 - 0x106ae4ff3 +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.0) <6858DF5A-F020-22A7-B945-14EC277724D4> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
0x106aeb000 - 0x106bd1fe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <2D39CB30-54D9-B03E-5FCF-E53122F87484> /usr/lib/libcrypto.0.9.7.dylib
0x106ced000 - 0x106ceffef com.apple.textencoding.unicode 2.3 (2.3) <B254327D-2C4A-3296-5812-6F74C7FFECD9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x106f5f000 - 0x106f79fff +com.adobe.pip ??? (5.0.0.2021) <47380937-5088-41F7-50FA-ADAC9B15C783> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
0x106f9d000 - 0x106f9efff +com.yourcompany.ONProxySupport 1.0 (1) <BDADC3F6-7A6A-CA24-B40B-614DA75381B6> /Library/Frameworks/ONProxySupport.framework/Versions/A/ONProxySupport
0x108540000 - 0x1085b0ff6 +com.adobe.amt.services AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) (3.0.0.64) <52FF1F9B-9991-ECE2-C7E3-09DA1B368CBE> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/amtservices.framework/Versions/a/amtservices
0x1087fb000 - 0x1087fcfff libCyrillicConverter.dylib 49.0.0 (compatibility 1.0.0) <C1616113-2CD4-FBB7-CFF0-8824852CECEE> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
0x10bd8a000 - 0x10bda1fe7 libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <75DC170B-0D94-57DA-C5F3-D0B839BEA9B9> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0x10bda5000 - 0x10bdc6fef libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <79091060-6CC8-0EF2-FED7-DC0A2B7DEB9B> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0x10bdca000 - 0x10bdd9fe7 libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <EBBC176A-0D0D-C2FB-7A0D-D45061F123D9> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x10bddd000 - 0x10bdeffff libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <AC92D96F-885B-FA97-2445-C3C88DF6EE70> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x10c4ae000 - 0x10c4b6fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <3D59CB21-F5C7-4232-AB00-DFEB04206024> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/asneu.framework/Versions/a/asneu
0x10c4d3000 - 0x10c4dafff +Enable Async IO ??? (???) <9C98DC9E-5974-FE5D-75C3-16BC4738DCC8> /Applications/Adobe Photoshop CS5/Plug-ins/Extensions/Enable Async IO.plugin/Contents/MacOS/Enable Async IO
0x10c4e3000 - 0x10c4ecfff +FastCore ??? (???) <F1D1C94D-4FE1-F969-6FC2-8D81837CA5E1> /Applications/Adobe Photoshop CS5/Plug-ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
0x11d5f6000 - 0x11d5f6fff +com.ononesoftware.phototune3.batch 3.0.6 (3.0.6) <8674F362-D0E0-7E1E-BF37-FC18BA92869E> /Applications/Adobe Photoshop CS5/Plug-ins/PhotoTune 3.plugin/PhotoTune Batch.plugin/Contents/MacOS/PhotoTune Batch
0x11ecc7000 - 0x11ed2aff3 +MMXCore ??? (???) <2DB6FA8E-4373-9823-C4F5-A9F5F8F80717> /Applications/Adobe Photoshop CS5/Plug-ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
0x11edb0000 - 0x11ee1bff0 +MultiProcessor Support ??? (???) <9C6E0C9E-50AC-B0CD-D705-C9760289C298> /Applications/Adobe Photoshop CS5/Plug-ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
0x1201d9000 - 0x1201e2fff +com.ononesoftware.photoframe45.professional.batch ??? (4.6.1) <74994533-88BF-CDF6-553B-3E7EA427CC35> /Applications/Adobe Photoshop CS5/Plug-ins/PhotoFrame 4.6 Professional Edition 64.plugin/PhotoFrame 4.6 Professional Edition Batch.plugin/Contents/MacOS/PhotoFrame 4.6 Professional Edition Batch
0x1201f7000 - 0x1201fbfef +com.stclairsoft.DefaultFolderX.osax Default Folder X Addition version 1.0 (4.3.10) <81B82668-8B62-6D55-F2A9-6A6202DB0E6E> /Users/john/Library/ScriptingAdditions/Default Folder X Addition.osax/Contents/MacOS/Default Folder X Addition
0x121ad2000 - 0x121ae3ff7 +com.ononesoftware.onOneToolbox 3.0 (3.0) <9D79E218-29AC-F75D-A225-184BDF2A9463> /Library/Frameworks/onOneToolbox.framework/Versions/A/onOneToolbox
0x121dc5000 - 0x121ddeff7 CoreImageFilterLib.dylib 3.6.4 (compatibility 2.2.1) <023DF1E0-D194-029F-E633-F834ECCB6BDA> /System/Library/CoreServices/RawCamera.bundle/Contents/Resources/CoreImageFilterLib.dylib
0x122d00000 - 0x122d1cff7 +MeasurementCore ??? (???) <0E3BE9B3-FF3D-78A6-38EC-5CB0828B80EB> /Applications/Adobe Photoshop CS5/Plug-ins/Measurements/MeasurementCore.plugin/Contents/MacOS/MeasurementCore
0x122d3c000 - 0x122d6cfe7 +com.ononesoftware.FocalPoint2.Automation 2.0.5 (Suite 5.5.1) (2.0.5) <786D1E56-2EF9-D84F-8D4F-AF03BBFC96A1> /Applications/Adobe Photoshop CS5/Plug-ins/FocalPoint 2.plugin/FocalPointAutomation.plugin/Contents/MacOS/FocalPointAutomation
0x122d7e000 - 0x122df8fff +com.ononesoftware.photoframe45.professional.auto 4.6.1 (4.6.1) <3B319C4E-25CF-2FE0-2884-ACA279F87E16> /Applications/Adobe Photoshop CS5/Plug-ins/PhotoFrame 4.6 Professional Edition 64.plugin/PhotoFrame 4.6 Professional Edition Automation.plugin/Contents/MacOS/PhotoFrame 4.6 Professional Edition Automation
0x122e1b000 - 0x122f53fff +com.ononesoftware.phototools25 2.6.1 (Suite 5.5.1) (2.6.1) <550F8293-3F83-7957-0900-9A8971D6B168> /Applications/Adobe Photoshop CS5/Plug-ins/PhotoTools 2.6 Professional Edition.plugin/PhotoTools 2.6 Professional Edition.plugin/Contents/MacOS/PhotoTools 2.6 Professional Edition
0x122fe4000 - 0x123030fe7 com.apple.glut 3.4.4 (GLUT-3.4.4) <78324374-C4AC-2358-3D61-55060E44FC38> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
0x1230b1000 - 0x1230d8fff +com.ononesoftware.ononewidgets ??? (2.0) <1F5DCF46-A346-BA2C-10E9-DE28E6097F89> /Library/Frameworks/OnOneWidgets.framework/Versions/A/OnOneWidgets
0x1230fb000 - 0x123147fef +com.ononesoftware.phototune3 3.0.6 (Suite 5.5.1) (3.0.6) <5869B7BC-D4A8-34CE-A6E2-2A4885B0C984> /Applications/Adobe Photoshop CS5/Plug-ins/PhotoTune 3.plugin/PhotoTune.plugin/Contents/MacOS/PhotoTune
0x12316f000 - 0x1233cbfef +com.adobe.PSAutomate 12.0.2 (12.0.2) <3A8E6CC2-B410-EBEE-32FD-509FC674AE28> /Applications/Adobe Photoshop CS5/Plug-ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/ScriptingSupport
0x1235e1000 - 0x123685ffb +com.adobe.AdobeExtendScript ExtendScript 4.1.26 (4.1.26.11099) <00717496-ACE1-7D2F-DEE7-4316D0AB52D5> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
0x1236e7000 - 0x123787fef +com.adobe.AdobeScCore ScCore 4.1.26 (4.1.26.11099) <036DBC1F-0576-705F-3507-213E9F455222> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
0x1237cd000 - 0x1237edffb +com.adobe.ape adbeapecore version 3.1.70.10055 (3.1.70.10055) <66373ADB-0865-ECDB-D3D0-B3373FC43919> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
0x1239aa000 - 0x1239c8ff7 +Cocoa Patcher ??? (???) <E1C05D5E-8800-4CE8-600F-7FEECF71FF73> /Users/john/Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Cocoa Patcher.bundle/Contents/MacOS/Cocoa Patcher
0x1239dc000 - 0x1239e0fff com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <5D9C8E0B-2B62-6EC8-0590-476A73C006FB> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
0x1239e5000 - 0x1239ebfff com.apple.audio.AppleHDAHALPlugIn 1.9.9 (1.9.9f12) <DDDE04F6-09A4-2DE5-CD04-B6DA707D3713> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
0x12438e000 - 0x1243cbfff com.apple.DP.ScreenInputDevice 15.0 (15.0) <69919162-3E04-C270-B8AB-8E26634D4BBB> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/AppleScreenInpu tDevice.plugin/Contents/MacOS/AppleScreenInputDevice
0x124800000 - 0x125668ff3 +com.adobe.adobeswfl ??? (2.0.0.10053) <ADE7E8AA-80B6-7BAC-8205-13D7A0E89DF8> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/Resources/AdobeSWFL.bundle/Contents/MacOS/Ado beSWFL
0x126f88000 - 0x126fc5feb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.0.0.64 (1.0.0.64) <CD8BD7C7-0F66-29B6-C158-A6EF8DF69996> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/updaternotifications.framework/Versions/a/UpdaterNotification s
0x126fe0000 - 0x126ff2fef +libFileMgmt.dylib ??? (???) <E30B2480-F911-9DC2-C554-B8ABF392B1F6> /Applications/Adobe Photoshop CS5/Plug-ins/PhotoFrame 4.6 Professional Edition 64.plugin/PhotoFrame 4.6 Professional Edition.plugin/Contents/MacOS/libFileMgmt.dylib
0x1290d9000 - 0x1290dffe7 libFontStreams.A.dylib 545.0.0 (compatibility 64.0.0) <64D5FAC3-7910-685B-4F67-F04EA353D9EF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libFontStreams.A.dylib
0x129583000 - 0x1295abfef +ServiceManager-Launcher.dylib ??? (???) <4608E5E7-7F22-A4FF-527C-E97EA339FCCC> /Library/Application Support/Adobe/CS5ServiceManager/lib/ServiceManager-Launcher.dylib
0x12aecf000 - 0x12aef5fff GLRendererFloat ??? (???) <0AF0FF0D-6FD6-B5FA-9991-C8F58E8F1DD4> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
0x13f800000 - 0x13f991fef GLEngine ??? (???) <7B2CD458-D828-6A44-C918-C194838974D5> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x13f9c2000 - 0x13fd96ff7 com.apple.ATIRadeonX3000GLDriver 1.6.26 (6.2.6) <F2951F13-41D9-E6D7-D421-CB09F910ACA1> /System/Library/Extensions/ATIRadeonX3000GLDriver.bundle/Contents/MacOS/ATIRadeonX3000GLD river
0x17cfcb000 - 0x17cfe4ff7 +com.ononesoftware.ONDocument 1.0 (1) <7DA2A9F4-ED0C-E3EC-07A5-829529A83FB3> /Library/Frameworks/ONDocument2.framework/Versions/A/ONDocument2
0x17d11a000 - 0x17d14cfff +com.ononesoftware.photoframe45.professional.filter 1.0 (1) <768CDF96-F526-1590-CF43-ECB311C743BF> /Applications/Adobe Photoshop CS5/Plug-ins/PhotoFrame 4.6 Professional Edition 64.plugin/PhotoFrame 4.6 Professional Edition.plugin/Contents/MacOS/PhotoFrame 4.6 Professional Edition
0x17d2e9000 - 0x17d309fff +com.ononesoftware.ONCore 1.0 (1) <24F4DA62-5B3F-6271-84C6-F984F3836A04> /Library/Frameworks/ONCore2.framework/Versions/A/ONCore2
0x18b3e9000 - 0x18b3eafff ATSHI.dylib ??? (???) <C3BF96C6-C170-B0DD-7541-78AD91B4BD70> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
0x7fff5fc00000 - 0x7fff5fc3bdef dyld 132.1 (???) <69130DA3-7CB3-54C8-ABC5-423DECDD2AF7> /usr/lib/dyld
0x7fff80003000 - 0x7fff800b8fe7 com.apple.ink.framework 1.3.3 (107) <8C36373C-5473-3A6A-4972-BC29D504250F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
0x7fff800b9000 - 0x7fff800b9ff7 com.apple.Carbon 150 (152) <C0E61968-57F3-6EE1-8524-32A18955BAF0> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff800ba000 - 0x7fff800bcfff com.apple.print.framework.Print 6.1 (237.1) <CA8564FB-B366-7413-B12E-9892DA3C6157> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
0x7fff80150000 - 0x7fff8016dff7 libPng.dylib ??? (???) <0C232C1E-49C8-F7A9-9634-DF2BDA1AB722> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
0x7fff8016e000 - 0x7fff801f0fff com.apple.QuickLookUIFramework 2.3 (327.6) <9093682A-0E2D-7D27-5F22-C96FD00AE970> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
0x7fff801f1000 - 0x7fff80474fe7 com.apple.Foundation 6.6.6 (751.53) <476E617B-B59B-53DE-991D-98C1993BCBCE> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff80475000 - 0x7fff80478ff7 libCoreVMClient.dylib ??? (???) <00C97B96-8D3B-45EB-F503-DB49712DC42D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff80479000 - 0x7fff8049afff libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <9F322F47-0584-CB7D-5B73-9EBD670851CD> /usr/lib/libresolv.9.dylib
0x7fff8049b000 - 0x7fff804ccfff libGLImage.dylib ??? (???) <6925991A-9B1B-B9FA-645A-807F9BCC3DE7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff804cd000 - 0x7fff8058efff libFontParser.dylib ??? (???) <244BCE74-7EEE-C9DE-9779-F3AEF5869BE6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
0x7fff805d3000 - 0x7fff805e7fff libGL.dylib ??? (???) <0FA671EB-6FA0-BA97-C00A-C42247C22B26> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff8069f000 - 0x7fff8071cfef libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
0x7fff8071d000 - 0x7fff80731ff7 com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <621B7415-A0B9-07A7-F313-36BEEDD7B132> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
0x7fff80739000 - 0x7fff807beff7 com.apple.print.framework.PrintCore 6.3 (312.7) <CDFE82DD-D811-A091-179F-6E76069B432D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
0x7fff807bf000 - 0x7fff80802ff7 libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <2C596A24-8B86-79D6-1A8E-5E8FFB6A1558> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff80803000 - 0x7fff80832ff7 com.apple.quartzfilters 1.6.0 (1.6.0) <9CECB4FC-1CCF-B8A2-B935-5888B21CBEEF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
0x7fff808eb000 - 0x7fff80a13ff7 com.apple.MediaToolbox 0.484.20 (484.20) <1C80C29E-6FDB-71F3-B465-FF92A30BBF9D> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff80aed000 - 0x7fff80b37ff7 com.apple.Metadata 10.6.3 (507.15) <DE238BE4-5E22-C4D5-CF5C-3D50FDEE4701> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
0x7fff80b38000 - 0x7fff80b53ff7 com.apple.openscripting 1.3.1 (???) <9D50701D-54AC-405B-CC65-026FCB28258B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
0x7fff80b54000 - 0x7fff80b55fff liblangid.dylib ??? (???) <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
0x7fff80b56000 - 0x7fff80b81ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <87A0B228-B24A-C426-C3FB-B40D7258DD49> /usr/lib/libxslt.1.dylib
0x7fff80e08000 - 0x7fff80e50ff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <98FC4457-F405-0262-00F7-56119CA107B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
0x7fff80e67000 - 0x7fff80e6bff7 libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <49E6AF5D-AF9B-67CF-A6B8-C79F6BA8A627> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
0x7fff80e6c000 - 0x7fff81862fff com.apple.AppKit 6.6.7 (1038.35) <9F4DF818-9DB9-98DA-490C-EF29EA757A97> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff81863000 - 0x7fff818affff libauto.dylib ??? (???) <F7221B46-DC4F-3153-CE61-7F52C8C293CF> /usr/lib/libauto.dylib
0x7fff818b0000 - 0x7fff818d3fff com.apple.opencl 12.3.6 (12.3.6) <42FA5783-EB80-1168-4015-B8C68F55842F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff81b17000 - 0x7fff81d52fef com.apple.imageKit 2.0.3 (1.0) <5D18C246-303A-6580-9DC9-79BE79467C95> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
0x7fff81d53000 - 0x7fff81d5eff7 com.apple.speech.recognition.framework 3.11.1 (3.11.1) <3D65E89B-FFC6-4AAF-D5CC-104F967C8131> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
0x7fff81d5f000 - 0x7fff81db1ff7 com.apple.HIServices 1.8.2 (???) <80D63B54-3F43-080C-038A-70038D9AF325> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
0x7fff81db2000 - 0x7fff81db2ff7 com.apple.Cocoa 6.6 (???) <68B0BE46-6E24-C96F-B341-054CF9E8F3B6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff81e26000 - 0x7fff81eb2fef SecurityFoundation ??? (???) <8A74D45E-9FE9-DD58-42F5-C7474FFDD0C1> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff81eb3000 - 0x7fff81efaff7 com.apple.coreui 2 (114) <923E33CC-83FC-7D35-5603-FB8F348EE34B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff820a0000 - 0x7fff828aafe7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <FC941ECB-71D0-FAE3-DCBF-C5A619E594B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
0x7fff828ab000 - 0x7fff828fafef libTIFF.dylib ??? (???) <F0F7F0B7-7253-F88F-9E2D-FA3770143758> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
0x7fff828fb000 - 0x7fff82ab9fff libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <2C6ECACF-CD56-1714-6F63-CB6F5EE7A1E2> /usr/lib/libicucore.A.dylib
0x7fff82aba000 - 0x7fff82af7ff7 libFontRegistry.dylib ??? (???) <8C69F685-3507-1B8F-51AD-6183D5E88979> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
0x7fff82af8000 - 0x7fff82b3dfff com.apple.CoreMediaIOServices 134.0 (1160) <BA22EA4A-4572-749A-4FE0-1323E0B6F6F3> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
0x7fff82b3e000 - 0x7fff82b40fff libRadiance.dylib ??? (???) <73257486-8E94-E758-1A5A-5B521F27EE12> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
0x7fff82b5c000 - 0x7fff82bbcfe7 com.apple.framework.IOKit 2.0 (???) <D107CB8A-5182-3AC4-35D0-07068A695C05> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff82be5000 - 0x7fff82beeff7 com.apple.DisplayServicesFW 2.3.0 (283) <4F1220F7-D576-B761-9881-5810C03F87FA> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff82c20000 - 0x7fff82d55ff7 com.apple.audio.toolbox.AudioToolbox 1.6.6 (1.6.6) <AFAB42A2-A3A8-83D8-D583-613625706690> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff82d56000 - 0x7fff83181fef com.apple.RawCamera.bundle 3.6.4 (561) <C4AB0054-B2C8-246E-0F17-98F4BD5BE94C> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff83182000 - 0x7fff83183fff com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <5062DACE-FCE7-8E41-F5F6-58821778629C> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x7fff83236000 - 0x7fff834a0fef com.apple.QuartzComposer 4.2 ({156.28}) <248C697E-B2DD-4F27-27CD-6E6B99B9B0A8> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
0x7fff834dc000 - 0x7fff834ebfff com.apple.opengl 1.6.12 (1.6.12) <29482652-1E44-1C47-428F-1209AA65336D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff83519000 - 0x7fff836d1fef com.apple.ImageIO.framework 3.0.4 (3.0.4) <EFB373AE-FE02-40C4-ABDC-09D61AFD25EA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
0x7fff836d2000 - 0x7fff837f3fe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <48AEAFE1-21F4-B3C8-4199-35AD5E8D0613> /usr/lib/libcrypto.0.9.8.dylib
0x7fff83818000 - 0x7fff838b2ff7 com.apple.ApplicationServices.ATS 4.4 (???) <55B528A6-0C88-6CB8-152B-A34A440FACFE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
0x7fff838b3000 - 0x7fff838b3ff7 com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff838b4000 - 0x7fff83db8fe7 com.apple.VideoToolbox 0.484.20 (484.20) <B01F6A80-D197-2127-2A05-49F9446EF6E5> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff83db9000 - 0x7fff83dc7ff7 libkxld.dylib ??? (???) <F90EDFE8-708A-3046-E403-A3B536FCFA43> /usr/lib/system/libkxld.dylib
0x7fff83dc8000 - 0x7fff83ea5fff com.apple.vImage 4.1 (4.1) <C3F44AA9-6F71-0684-2686-D3BBC903F020> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
0x7fff83ea6000 - 0x7fff83eadfff com.apple.OpenDirectory 10.6 (10.6) <4FF6AD25-0916-B21C-9E88-2CC42D90EAC7> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff83f53000 - 0x7fff83fe3fff com.apple.SearchKit 1.3.0 (1.3.0) <4175DC31-1506-228A-08FD-C704AC9DF642> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
0x7fff83fe4000 - 0x7fff84094fff edu.mit.Kerberos 6.5.11 (6.5.11) <085D80F5-C9DC-E252-C21B-03295E660C91> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff84138000 - 0x7fff841a0fff com.apple.MeshKitRuntime 1.1 (49.2) <4D3045D0-0D50-7053-3A05-0AECE86E39F8> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
0x7fff841a1000 - 0x7fff841c7fe7 libJPEG.dylib ??? (???) <AD42F658-7C32-EEE5-8341-A8EE6476BF46> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
0x7fff841c8000 - 0x7fff84201fef libcups.2.dylib 2.8.0 (compatibility 2.0.0) <F8E0672F-C0B4-B161-E50D-A1405D14F21C> /usr/lib/libcups.2.dylib
0x7fff84207000 - 0x7fff84214fe7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <45B5B514-7CEB-38A9-F34A-1D96F010EC42> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
0x7fff84215000 - 0x7fff84218ff7 com.apple.securityhi 4.0 (36638) <EABABBA8-AB59-599A-1884-0010C059DE62> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
0x7fff843e3000 - 0x7fff843e4ff7 com.apple.audio.units.AudioUnit 1.6.6 (1.6.6) <BE4E577D-87EC-8FD0-5341-AE99CE4ADC99> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff843e5000 - 0x7fff843f7fe7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib
0x7fff84446000 - 0x7fff8445ffff com.apple.CFOpenDirectory 10.6 (10.6) <401557B1-C6D1-7E1A-0D7E-941715C37BFA> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
0x7fff8446c000 - 0x7fff8450cfff com.apple.LaunchServices 362.2 (362.2) <87E172DB-2C0E-E2E5-2A75-FB4284AECDAF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
0x7fff8450d000 - 0x7fff846f1ff7 libType1Scaler.dylib ??? (???) <2C7624EC-01D5-5E9E-3FB8-8ADA460ED6DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
0x7fff846f2000 - 0x7fff847a8fff libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <99CB3A0F-64CF-1D16-70CD-8AED2EF06C30> /usr/lib/libobjc.A.dylib
0x7fff847a9000 - 0x7fff847bafff com.apple.DSObjCWrappers.Framework 10.6 (134) <3C08225D-517E-2822-6152-F6EB13A4ADF9> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x7fff847bb000 - 0x7fff847e3fff com.apple.DictionaryServices 1.1.2 (1.1.2) <E9269069-93FA-2B71-F9BA-FDDD23C4A65E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
0x7fff84824000 - 0x7fff84879ff7 com.apple.framework.familycontrols 2.0.2 (2020) <F09541B6-5E28-1C01-C1AE-F6A2508670C7> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x7fff8487a000 - 0x7fff84933fff libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <2C5ED312-E646-9ADE-73A9-6199A2A43150> /usr/lib/libsqlite3.dylib
0x7fff8493b000 - 0x7fff84afcfff libSystem.B.dylib 125.2.10 (compatibility 1.0.0) <9BAEB2F2-B485-6349-E1AB-637FE12EE770> /usr/lib/libSystem.B.dylib
0x7fff84afd000 - 0x7fff84b7cfe7 com.apple.audio.CoreAudio 3.2.6 (3.2.6) <1CF0AE2D-0E85-D41B-EC2D-8CFD298AB5A0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff84c0a000 - 0x7fff84c45fff com.apple.AE 496.4 (496.4) <55AAD5CA-7160-7899-1C68-562ED8160DF7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
0x7fff84c46000 - 0x7fff84c6bff7 com.apple.CoreVideo 1.6.2 (45.6) <E138C8E7-3CB6-55A9-0A2C-B73FE63EA288> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff84c7c000 - 0x7fff84cedff7 com.apple.AppleVAFramework 4.10.23 (4.10.23) <3304268B-A93D-9F79-09C0-AA9081406352> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff851cb000 - 0x7fff851dafff com.apple.NetFS 3.2.2 (3.2.2) <7CCBD70E-BF31-A7A7-DB98-230687773145> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff851db000 - 0x7fff851dfff7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
0x7fff851e0000 - 0x7fff854defff com.apple.HIToolbox 1.6.5 (???) <AD1C18F6-51CB-7E39-35DD-F16B1EB978A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
0x7fff854e1000 - 0x7fff854e1ff7 com.apple.CoreServices 44 (44) <DC7400FB-851E-7B8A-5BF6-6F50094302FB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff85548000 - 0x7fff8561afe7 com.apple.CFNetwork 454.11.12 (454.11.12) <B1C9008A-4A5D-609D-5D10-C93DAD6FFB4C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
0x7fff8561b000 - 0x7fff858a3fef com.apple.security 6.1.1 (37594) <34DC0C3E-4546-D7ED-D855-390750954245> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff858a4000 - 0x7fff85961fff com.apple.CoreServices.OSServices 359 (359) <8F509D8D-4C94-9A1C-3A87-5B775D9F6075> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
0x7fff85962000 - 0x7fff859ceff7 com.apple.CorePDF 1.3 (1.3) <FF2F3F1B-D1D6-684C-B174-6A455E04FF91> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff859d8000 - 0x7fff85b4ffe7 com.apple.CoreFoundation 6.6.4 (550.42) <770C572A-CF70-168F-F43C-242B9114FCB5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff85b50000 - 0x7fff85b53fff com.apple.help 1.3.1 (41) <54B79BA2-B71B-268E-8752-5C8EE00E49E4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
0x7fff85b54000 - 0x7fff85c3afef com.apple.DesktopServices 1.5.10 (1.5.10) <B7E00D85-F971-D85B-0217-482E15E9E924> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
0x7fff85c3b000 - 0x7fff85c40fff libGIF.dylib ??? (???) <1B9DCB7F-CD1D-B23F-8AC6-5292B94A4D0E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
0x7fff85c41000 - 0x7fff85c46ff7 com.apple.CommonPanels 1.2.4 (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
0x7fff85c47000 - 0x7fff85c88fef com.apple.QD 3.36 (???) <5DC41E81-32C9-65B2-5528-B33E934D5BB4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
0x7fff85c89000 - 0x7fff85ca9ff7 com.apple.DirectoryService.Framework 3.6 (621.11) <AD76C757-6701-BDB5-631E-1CB77D669586> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff85caa000 - 0x7fff85dc3fef libGLProgrammability.dylib ??? (???) <C4BB281B-629D-08ED-2991-3D51671B0B02> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
0x7fff85dc4000 - 0x7fff85dc9fff libGFXShared.dylib ??? (???) <878C429B-44D4-875C-1A35-4FD8C6152695> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff85dd8000 - 0x7fff85e11ff7 com.apple.MeshKit 1.1 (49.2) <832A074D-7601-F7C9-6D3A-E1C58965C3A1> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
0x7fff85e12000 - 0x7fff85e27ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <1AE1FE8F-2204-4410-C94E-0E93B003BEDA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
0x7fff85e28000 - 0x7fff85e69ff7 com.apple.CoreMedia 0.484.20 (484.20) <C1CC2CE5-0606-5F87-9445-ED7AF1DA31B6> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff85e83000 - 0x7fff85eb6fff libTrueTypeScaler.dylib ??? (???) <632BAC10-4C24-D1F2-3943-DF5F2326318B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff85eb7000 - 0x7fff85f06ff7 com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <01B370FB-D524-F660-3826-E85B7F0D85CD> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x7fff85f07000 - 0x7fff85f71fe7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <AF0EA96D-000F-8C12-B952-CB7E00566E08> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
0x7fff85f8e000 - 0x7fff860ccfff com.apple.CoreData 102.1 (251) <9DFE798D-AA52-6A9A-924A-DA73CB94D81A> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff860cd000 - 0x7fff8615cfff com.apple.PDFKit 2.5.1 (2.5.1) <38BEE9BB-3716-49BA-7E14-687FE9E066EB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
0x7fff86165000 - 0x7fff862d4fe7 com.apple.QTKit 7.6.6 (1756.15) <B35EDB1D-FCB0-1D40-629E-6ACB56D57C68> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff862f1000 - 0x7fff8633afef libGLU.dylib ??? (???) <0FCD57C5-D7AA-F2DD-D2EC-C1C8B931F65C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff8633b000 - 0x7fff863fcfef com.apple.ColorSync 4.6.6 (4.6.6) <EC6C8119-23F6-A96E-47A3-5CD31E462AE3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
0x7fff8640b000 - 0x7fff86489ff7 com.apple.CoreText 3.151.8 (???) <5DCD6BD9-63FB-767E-5993-5AEBE890145B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
0x7fff8648a000 - 0x7fff86582ff7 libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <44AADE50-15BC-BC6B-BEF0-5029A30766AC> /usr/lib/libiconv.2.dylib
0x7fff86583000 - 0x7fff86583ff7 com.apple.quartzframework 1.5 (1.5) <5BFE5998-26D9-0AF1-1522-55C78E41F778> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff86584000 - 0x7fff871fffef com.apple.WebCore 6533.20 (6533.20.24) <FB4CBEAE-106E-1B22-6C97-1B38A06EB569> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
0x7fff87200000 - 0x7fff87262fe7 com.apple.datadetectorscore 2.0 (80.7) <34592AFF-B1B8-2277-B013-70193E4E1691> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
0x7fff87263000 - 0x7fff87600fe7 com.apple.QuartzCore 1.6.3 (227.36) <6FD8E129-135E-2F89-E9F0-A3CD0C6FCEF1> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff87601000 - 0x7fff876ccfff ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <D3242F40-AA41-022C-1345-6BFC0E560460> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
0x7fff876cd000 - 0x7fff876d3ff7 com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff876d4000 - 0x7fff8771dff7 com.apple.securityinterface 4.0.1 (40418) <77FDB498-B502-050C-6AF4-1DAB17F64B6F> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff878a8000 - 0x7fff87a98fef com.apple.JavaScriptCore 6533.20 (6533.20.20) <5626170D-00AE-33B1-03FF-256E9794150D> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff87c20000 - 0x7fff87d37fef libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <1B27AFDD-DF87-2009-170E-C129E1572E8B> /usr/lib/libxml2.2.dylib
0x7fff87d38000 - 0x7fff87d38ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <15DF8B4A-96B2-CB4E-368D-DEC7DF6B62BB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff87daa000 - 0x7fff880defff com.apple.CoreServices.CarbonCore 861.34 (861.34) <B5680539-CB31-6C6D-C0AD-606D4D46E7F5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
0x7fff880df000 - 0x7fff88120fff com.apple.SystemConfiguration 1.10.5 (1.10.2) <FB39F09C-57BB-D8CC-348D-93E00C602F7D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff88121000 - 0x7fff8822bff7 com.apple.MeshKitIO 1.1 (49.2) <C19D0CCD-1DCB-7EDE-76FA-BF74079AFC6A> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
0x7fff8822c000 - 0x7fff88232ff7 com.apple.CommerceCore 1.0 (9) <4C66D962-91B5-F25C-A6FF-DFD5F924A0DD> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
0x7fff88233000 - 0x7fff88244ff7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <97019C74-161A-3488-41EC-A6CA8738418C> /usr/lib/libz.1.dylib
0x7fff88245000 - 0x7fff88246ff7 com.apple.TrustEvaluationAgent 1.1 (1) <5952A9FA-BC2B-16EF-91A7-43902A5C07B6> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
0x7fff882fd000 - 0x7fff88740fef libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <0CC61C98-FF51-67B3-F3D8-C5E430C201A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
0x7fff88741000 - 0x7fff88757fff com.apple.ImageCapture 6.0.2 (6.0.2) <06E4103B-9BE4-7EAD-B532-89FC5EB06ED4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
0x7fff88758000 - 0x7fff8876efe7 com.apple.MultitouchSupport.framework 207.10 (207.10) <F006B2C9-C03F-F863-1FBB-952EC77AE699> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
0x7fff8877b000 - 0x7fff8877bff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <4CCE5D69-F1B3-8FD3-1483-E0271DB2CCF3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
0x7fff8877c000 - 0x7fff88782ff7 IOSurface ??? (???) <6AF28EC1-BCC4-9F65-AF7D-ABE60B91072A> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff88783000 - 0x7fff88e8006f com.apple.CoreGraphics 1.545.0 (???) <F0A5F62D-4C66-5B1F-4F13-322932915901> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
0x7fff88e81000 - 0x7fff88fffff7 com.apple.WebKit 6533.20 (6533.20.25) <AD4C3C2F-8781-F2A7-EB6A-CCFC41E3FA04> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff89164000 - 0x7fff891a8fe7 com.apple.ImageCaptureCore 1.0.4 (1.0.4) <F4ED3329-1A86-EB10-CFC2-999D8699B5E6> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff891a9000 - 0x7fff891bffef libbsm.0.dylib ??? (???) <42D3023A-A1F7-4121-6417-FCC6B51B3E90> /usr/lib/libbsm.0.dylib
0x7fff891c0000 - 0x7fff89207fff com.apple.QuickLookFramework 2.3 (327.6) <11DFB135-24A6-C0BC-5B97-ECE352A4B488> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff89208000 - 0x7fff89208ff7 com.apple.vecLib 3.6 (vecLib 3.6) <96FB6BAD-5568-C4E0-6FA7-02791A58B584> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fffffe00000 - 0x7fffffe01fff libSystem.B.dylib ??? (???) <9BAEB2F2-B485-6349-E1AB-637FE12EE770> /usr/lib/libSystem.B.dylib
Model: MacPro5,1, BootROM MP51.007F.B03, 12 processors, 6-Core Intel Xeon, 2.66 GHz, 12 GB, SMC 1.39f11
Graphics: ATI Radeon HD 5870, ATI Radeon HD 5870, PCIe, 1024 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.10.131.36.9)
Bluetooth: Version 2.4.0f1, 2 service, 19 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
PCI Card: ATI Radeon HD 5870, Display, Slot-1
Serial ATA Device: HL-DT-ST DVD-RW GH61N
Serial ATA Device: WDC WD20EARS-00MVWB0, 1.82 TB
USB Device: FreeAgent, 0x0bc2, 0x3001, 0xfa200000
USB Device: Desktop, 0x0bc2, 0x3300, 0xfd300000
USB Device: Hub, 0x05ac (Apple Inc.), 0x9131, 0xfd100000
USB Device: Keyboard Hub, 0x05ac (Apple Inc.), 0x1006, 0xfd130000
USB Device: Apple Keyboard, 0x05ac (Apple Inc.), 0x0221, 0xfd132000
USB Device: Hub, 0x050d (Belkin Corporation), 0x0706, 0xfd110000
USB Device: Hub, 0x050d (Belkin Corporation), 0x706a, 0xfd114000
USB Device: Iomega eGo HDD, 0x059b (Iomega Corporation), 0x047b, 0xfd114300
USB Device: Griffin PowerMate, 0x077d, 0x0410, 0xfd114200
USB Device: PTZ-431W, 0x056a (WACOM Co., Ltd.), 0x00b7, 0xfd114100
USB Device: Apple Cinema HD Display, 0x05ac (Apple Inc.), 0x9223, 0xfd120000
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x5a100000
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8215, 0x5a110000
FireWire Device: built-in_hub, Up to 800 Mb/sec
FireWire Device: My Book, WD, Up to 800 Mb/sec
FireWire Device: LaCie Rugged LUN 0, LaCie Group SA, Up to 400 Mb/sec
FireWire Device: Hard Drive FW/USB, LaCie, Up to 400 Mb/sec
FireWire Device: GSA-5163D Super Multi DVD Rewriter, HL-DT-ST, Up to 400 Mb/sec
FireWire Device: unknown_device, Unknown
9. Re: Photoshop crashes in OSX 10.6.7
Trophy92 Apr 13, 2011 9:25 AM (in response to Trophy92)Took the image into Photoshop today as an 8 bit image and had no problems with Photoframes applying frame. Tested out Focal point and Phototools and all worked as they should.
Thought this had cured everything but then after about 1.5 hrs, blue screen.
After Finder had relaunched everything was unstable. Finder windows in list view scrolling uncontrollably so could not select anything. Safari the same everything shaking and scrolling so fast could not click on anything. CMD Tab just switching between apps so quick could not select one.
Had to do a full reboot. It must be OSX 10.6.7. I hope it is sorted soon as I cannot afford the time to re-install everything from Time Machine.
Before 10.6.7 had done a panel of 5 images all same size in 16 bit with same frame in PhotoFrames. Now can only get Photoframes to work in 8 bit and Finder crashes when using Photoshop CS5.
Perhaps I have to go back to running CS3 which I have installed to do the other image(s) in 16 bit.
10. Re: Photoshop crashes in OSX 10.6.7
Chris Cox Apr 13, 2011 2:56 PM (in response to Trophy92)The crash reports go into our database to be examined and fixed.
But without your email address or other identifying information, I can't find them in the database to look at the cause.
The crash you posted does appear to be due to a third party plugin messing up the window stack such that the OS attempts to send a message to a window that no longer exists.
I think you have a system wide problem -- a bad haxie, or a bad OS install, possibly corrupt hard disk or bad RAM.
11. Re: Photoshop crashes in OSX 10.6.7
Trophy92 Apr 13, 2011 11:41 PM (in response to Chris Cox)I tried putting in an e-mail address but it just says invalid address so I gave up. What is a bad 'haxie'.
If I do have a system wide problem why does Photoframes work in CS3?
12. Re: Photoshop crashes in OSX 10.6.7
Chris Cox Apr 14, 2011 12:01 AM (in response to Trophy92)I tried putting in an e-mail address but it just says invalid address so I gave up
Huh? The crash reporter dialog just asks for an email address, it doesn't try to validate the address in any way.
A haxie is a kind of system extension that tries to patch OS behavior, and frequently causes problems.
Again, you are describing some system wide problems that have nothing to do with Photoshop, plus some possible problems with your plugins.
13. Re: Photoshop crashes in OSX 10.6.7
c.pfaffenbichler Apr 14, 2011 12:06 AM (in response to Trophy92)If I do have a system wide problem why does Photoframes work in CS3?
That may seem curious but is not really a relevant observation as Photoshop CS3 and CS5 are even written in different programming languages.
And Photoframes for CS5 would have to be different from the version for CS3, too, if I understand correctly.
14. Re: Photoshop crashes in OSX 10.6.7
Trophy92 Apr 14, 2011 1:29 AM (in response to Chris Cox)Do you think I should use Time Machine and reinstall from a date prior to updating to OSX 10.6.7? Is there a way of knowing which date I updated to 10.6.7?
15. Re: Photoshop crashes in OSX 10.6.7
Chris Cox Apr 14, 2011 7:55 AM (in response to c.pfaffenbichler)Photoshop CS3 and CS5 are even written in different programming languages.
Um, no. What gave you that impression?
Both are written in C++.
No, not if it was written correctly.
16. Re: Photoshop crashes in OSX 10.6.7
c.pfaffenbichler Apr 14, 2011 8:01 AM (in response to Chris Cox)Both are written in C++.
Sorry, a (edit: longtime) misunderstanding on my part then – I thought the Carbon/Cocoa divide referred to the programming language.
17. Re: Photoshop crashes in OSX 10.6.7
Chris Cox Apr 14, 2011 8:10 AM (in response to c.pfaffenbichler)No, Carbon and Cocoa are APIs.
Cocoa does require using Objective C, but that can be minimized to just the parts of the code calling the Cocoa APIs.
There is no need to harm the rest of the app by converting to ObjectiveC.
18. Re: Photoshop crashes in OSX 10.6.7
c.pfaffenbichler Apr 14, 2011 8:15 AM (in response to Chris Cox)Thanks for setting me straight on that.
I can’t deny it: I am a programming layman …
19. Re: Photoshop crashes in OSX 10.6.7
Trophy92 Apr 15, 2011 11:03 AM (in response to c.pfaffenbichler)Update:
I opened an image in CS5 from Aperture today and applied a Photoframe and Photoshop crashed as expected. (Again could not add my e-mail address as says not in correct format!!).
I then opened the same image in CS3 and applied frame and did other work as necessary with no crashing. I have been working all day in CS3 with 16 bit images having up to 6 images at a time open to make sure the colours balance in my panel. I have done cloning, increasing canvas size, cropping etc and apart from when 6 images were open (each one >750 MB) a slight slowing down, no crashes or blue screens. It has been very stable.
In the background Aperture has been open, Safari, Mail, Word all the time and sometimes I have opened and closed other programmes.
This suggests that there must be an incompatibility issue somewhere between OSX 10.6.7 and Photoshop CS5. Based on this I would assume my computer has no issues.
Do you agree?
20. Re: Photoshop crashes in OSX 10.6.7
Chris Cox Apr 15, 2011 2:57 PM (in response to Trophy92)No, you're still looking at a bug in the PhotoFrame plugin.
Until you get a new version of that plugin that fixes the bug in the plugin, that plugin will continue to crash.
Yes, that plugin works most of the time in CS3, but it needs fixes to work correctly in CS5 because the plugin has bugs in the code for the plugin.
Either stop using the plugin that you know has bugs in it, or get an update to the plugin that fixes the bugs in the plugin.
21. Re: Photoshop crashes in OSX 10.6.7
Trophy92 Apr 16, 2011 1:04 AM (in response to Chris Cox)What I did mean was my blue screen issue. Using CS5 I get the random blue screens and Finder relaunching. Using CS3 all day I had no blue screens and everything was stable.
This suggests to me that either OSX10.6.7 is unstable when running CS5 (and someone else has reported this on the Apple discussions web pages) or there is something in CS5 which is not compatible with OSX 10.6.7.
Rather than reinstall everything I will use CS3 until it is sorted out, but it is annoying after having updated the whole CS5 Premium suite. I still think it must be OSX 10.6.7 as everything was OK until I did that update.
22. Re: Photoshop crashes in OSX 10.6.7
You do not realize it, obviously, but your last post (#21) confirms exactly what Mr. Cox is telling you in post #20.
23. Re: Photoshop crashes in OSX 10.6.7
BayerIn Apr 16, 2011 5:56 AM (in response to Tai Lao)then why is this discussion still going on?
24. Re: Photoshop crashes in OSX 10.6.7
peterpica Apr 16, 2011 6:49 AM (in response to BayerIn)I had similar problems with OnOne plug-ins (more than just PhotoFrame, and they kept sending me the 'uninstall' thing, etc. Never really worked until I just reinstalled the CS5 Suite from scratch. A real PITA, but it worked for me with 10.6.7.
Now I'm having issues with Acrobat Pro... Adobe's updater refuses to work, but that's another issue. I get a kick out of the screen error report... something to the effect that "Something's changed and app cannot be upgraded." I'd love to know who writes these error messages for Adobe. Their specificity can really be challenging.
25. Re: Photoshop crashes in OSX 10.6.7
Trophy92 Apr 16, 2011 8:42 AM (in response to peterpica)They sent me the uninstall as well but after uninstalling and re-installing it still crashed. I will contact OnOne and ask them to look at their plugin again. They said they only test with 100-200MB files usually but I think it is more to do with 10.6.7 than the size of the file.
26. Re: Photoshop crashes in OSX 10.6.7
Chris Cox Apr 16, 2011 10:47 AM (in response to BayerIn)I think the discussion is still going because some people are having difficulty separating the problems and causes.
Problem 1: bugs in a third party plugin cause Photoshop to crash.
Fix 1: disable or update the plugin.
Problem 2: OS bluescreen/reboot/Finder restart.
Fix 2: This is an OS level problem, and has nothing to do with applications or plugins. Solving this will either require cleaning out problematic system components (drivers, haxies, etc.) or reinstalling the OS. In some rare cases, this could even be due to defective hardware (like the video card/GPU) which get used by some versions of software and not others -- but the cause is still bad hardware, not the application software, and the fix would require replacing the defective hardware.
27. Re: Photoshop crashes in OSX 10.6.7
Was DYP Apr 16, 2011 2:07 PM (in response to Chris Cox)I guess you can never say it enough that 10.6 introduced much more corrupted caches than we have ever seen before. Once you get any crashes it becomes very likely that caches will get corrupted and you will continue to get crashes.
I find it necessary when getting crashes that I have to delete all system, user, and font caches. My preferred quick method is to use OnyX. Of course you want to repair permissions before you delete caches and then reboot immediately after deleting these caches.
28. Re: Photoshop crashes in OSX 10.6.7
Chris Cox Apr 16, 2011 6:59 PM (in response to Was DYP)I guess you can never say it enough that 10.6 introduced much more corrupted caches than we have ever seen before.
True, and Cocoa font APIs make it even worse.
But Apple is still working on fixes to their font code.
