10 Replies Latest reply on Jan 11, 2013 1:26 AM by MeisterKris
    Problem with TLF in SWC from Flash
    John R Nyquist Level 1
      I've created an asset in Flash Professional CS5 and brought it into Flash Builder 4 by way of a SWC. When I use the component from Flash inside of the Flex application, it messes up the Arial fonts. The Flash component is using TLF for some text.
      If I load the SWF version at runtime, it works.
      If I switch to Classic Text in the SWC, it works.
      It is only when I try and use the TLF in the SWC that messes up the fonts.
      I've tried setting the ActionScript Settings > Default linkage to Merged into code, that did not help.
      I assume that since the Flex app is specifying Arial as a font that there is a name collision between the embedded font from Flash and Flex, but I'm not sure how to resolve. Suggestions would be appreciated.
      Regards,
      John
