1 Reply Latest reply on Apr 14, 2011 10:00 PM by ManishPali
    Reader X Protected Mode Issue- MyPlugin Working fine when Protected Mode is disabled
    chetanrajakumar Level 1
      Hi ,
      The issues with Reader-X are listed below :
      1. In Reader-X, there is an option which we can select for 'Enable Protected-Mode'.
           a. If this is enabled i am able to see all the buttons of MyPlugin but when i clicked on each button it wont do its task instead i get error message saying unable to create HelperObject (Class not Registered Error) .
           b.If i disable the Protected-Mode , i will see to see all the buttons of MyPlugin and the when i click on those buttons it will be  able to do its task as expected.
      Here is what my application does,
      The plug-in is written in VC++ and it interacts with C# .
      The C# code reads\writes to registry and file system. It also accesses Acrobat APIs using DDE.
      Implementing the Broker Process will solve the issue ?
      Is there any sample available for implementing the Broker Process ?
      OR
      I read the thread "Trusted Mechanisms with Acrobat X" and found that folks using 'ProtectedModeWhitelistConfig.txt' concept.
      I tried to implement the same but i was not success in doing it. Please let me know what i have to write in 'ProtectedModeWhitelistConfig.txt' for the below written log error :
      OpenEvent: STATUS_ACCESS_DENIED
      Consider modifying policy using these policy rules: EVENTS_ALLOW_ANY
      Please some one help me out to solve this issue..
      Thanks in advance.
