Hi all,
Am having a real issue with inserting an image into a rollover slidlet.
No matter what I do the iamge just sits on the background of the full slide.
I'm obvioulsy doing something stupid.
Can someone enlighten me please?
Cheers
Rollover slidelets have two parts. The rollover area that triggers the slidelet itself to appear, and the slidelet where you can add objects such as images and captions etc.
In Captivate, the rollover area is named Rollover Slidelet when it is in Edit Mode, which can be a bit confusing. You don't add images to the rollover area.
You need to select the OTHER part of the slidelet (usually the larger part) and while it is selected, then you need to Insert > Image.
Classification: NOT PROTECTIVELY MARKED
Im an idiot.
Ignore me.
I had the placings of the rollover area and the slidelet reversed!
DOH! (Slaps head in disgrace)
